100%sub
2 mtx T9 e SD5000 (novos videos pag.16)
GOLF 03
1 PIONEER DEH-P7150UB
1 BOOSTER BA-604.4
1 SD5000
2 KIT 2 VIAS BRAVOX
2 MTX 9515-04
2 BATERIA 150AH HELIAR FROTA
1 HELIAR 60AH
1 ALTERNADOR DE 90AH
Sai Par de Extreme e Banda ice
OgAAACO2g4BCyzXztye5VMHbCSvuV2Wa88OYM37eRCyOQO4KHo2uxNviOEafhuxJE_T0wL6Z0J3S7n4jZQrKYww-7rAAm1T1UAdB4xlvnZoMnwE90DLEqztbsyKF.jpg
OgAAAJyFWU8gdaq43c_BqALo_4CfvHRoCDNv-Psb2dRd3Oxc7yL_5JeqY3pRti5nYP1hyANIFJYm5IfwTxD4LH8ecAcAm1T1UCMe7wdVehGTs5WaeKXu4cP_8I12.jpg
Novo Set Par T9515 e SD5000
OgAAAK1_a6ZX-NxizbQfcGwv3dHH0tGkjozyB7G_XMXMg4d5uyev2dbxnXfQr25a2JoZRSPv0Ns0WOnnyA5HkZsAcAUAm1T1UPRb3ssyZVHm2mo3DUwgNqvDPUoI.jpg
OgAAAC0Qm-uakOgs5S4RM64mEGcaWEfd3Fwen2qrkdwDXXWaLOSnNRkJsNhud2Zu5504CNVOaGp9eL-X7WikqYd9VcUAm1T1UI-c5g6NPoU4E5INxAVfjFKw8LHj.jpg
Player P850 começo a da pane trocado P7150UB
OgAAAHuQRx9itDF9AdkqD1-mHeU-Pnc_LtYfQvT30QCqh6-CP9sjRT7NVT81zzZ49q-z2fa03WiLUdGn_fCZLBsqR6wAm1T1UONeNHP-fFc11avdq1ydQS6Glrts.jpg
OgAAACMnXe63vG546bl76_P0qhep3LZ9SOB78zCgIHFqXDFK08kisn_Tt5RBSV1wC4XCSdPnUPrbTKFqJfZmVK3ha04Am1T1UJUhIrltMBMw-AobuACqAvILtwJN.jpg
Pra tocar os Kits
OgAAAF44G3b429XcpqbiR_EC7EpnfXefgFqUehHCQGE3J2Tcpwq-xD9j253rrxpIjNy5fvod-R0PUveBeck23HZjJhwAm1T1UHbCeFok08rm3s7y5KYDbvoGEwXo.jpg
Baterias dando uma carga lenta
OgAAAMzQ2gX1CY6APrS0FCkQVmj0bPwvN9KKqvktIQLU933_3gMHRjAS2NDlrmCzTOHBveOe88TFSVa-138nqmd5bbMAm1T1UIA0IFuTap3JcImEOcbE1hcpnKBE.jpg
Caixa
1° caixa camara separada
OgAAAKlK6vI1j1k6gCky8QtTQQV5PyF5yNlhV-Gz_ArnyD7K-l78L83iFnD0NaLWjRzBlPNMPlZtGUXFwkWkg488KzoAm1T1UMzbj3ZRfAgGsExXw95oJle4joUP.jpg
OgAAAJpgOOVnsRjCrkam8TV9JTmDlBQs6wwrPTYfmNiJfaY9KevTECZ535WptR3M08QjEIJMSar3NJpJnkmZAmvFd8AAm1T1UApSjnJlL_GcRs0G21tbPJe16giK.jpg
2ºcaixa modificada pra camara unica
OgAAAK9_MJqFnX54Q6h2J0OyHq5zgAx7bnTuBMJHjTy3d2Vl2PBuZgBk4L7fN3wJM_CwEO3wPTA_2pwwXfweJz3d_iUAm1T1UMZqNd4XY4scTNpZRUky4WD6ME2v.jpg
OgAAACntGyTB-5vRnXOu6LbEFJpwXq5b5gLhtANwEErVnov59_y1vC9Ba0yRSZCmk-KgjkTrt6eGhCYMXrBLb-GXBUgAm1T1UGkE-T0ndzr6QP1cnc2qmP-LR54r.jpg
OgAAAM4Ev1RZBlSaYDIm50UQu6_xq5SK1SqyDvtW9DXzTyqoSUVAd5-S8OhlMJOgOPWCo2dnpP0guHUXbYQ08YNVFHYAm1T1UCGX6lYJqNeTo7UmRYKvmSfwk3Fj.jpg
OgAAANk_F_feaKHsNH_UV70gHYgHRDkxP29GCH2E-hQ5UAQx6NsBJZP_41k9Bl8WQExir0vAi-9VLxfzpJv2BKbuJiMAm1T1UGv9ldbo_X5cYg7Pcfj5oEDzPkBp.jpg
OgAAAHl-V-5lvGyNN19Kwon7dqi-hVfHiHlWweVE_zSuaBxMTylRZo-cZqqhb5N8wnPqwlsUx3Yv98WDtPpLdBtcTGwAm1T1UC6AqGGGl7N16N6lEJT6YsCVpuAb.jpg
Editado por 100%sub
Esse Booster se for como os modelos menores, ele dá potência de acordo com o nome, então seria 2500w, o Roadstar pouca coisa mais forte seria melhor.
Mas o ideal, seria um módulo desses para cada sub. Então eu se fosse você pegaria um modelo nacional de módulo de 4000 a 6000wrms da Stetsom ou SD. Sem dúvidas!
Pega um SD3000 (se tiver grana, um SD4000) e alimenta MUIIITO bem. Tenho certeza que vai se impressionar com o seu som...
(eu acho que pra caber na litragem certa, vai ter q tirar o encosto traseiro do golf...)
SD3000.1D só tem modelos de 2 ohm assim como o stetsom 4K2D
o ideal seria comprar os 9515 - 4 para finalizar em 4 ohm, para casar com os amplificadores acima
mais o para os que vc citou
o agressive tem um rendimento baixo, pelo tanto que ele exige de bateria e para tocar forte.
2 mtx 9500 com ampli xiling :banghead
coloca 1 9500 e 1 amplí mtx e uma boa bateria
com certeza vai tocar muito mais e com muito mais qualidade
mtx 9500 merece coisa boa pasmafaute
esse sub da 1000 rms ne?^se for isso um agrecive(6800d) toca de boa,ja vi um modulo desses toca e nao eh fraco nao
tem tambem os taramps e os stetson q valem bastante a pena
mas se vc quer um modulo cavalao pra esses subs te recomendo o roadstar 10000d terremoto de 5000rms,ou um taramps 4.5kw (ja vi um desse tocar um shocker 20k e batia d+)
essa eh minha opiniao,espero ter ajudado
vlws
cara vai por min !
experiencia de quem ja teve...
roadstar tem varios modulos bons.. pena q o 6800D n seja um deles...
eh quase impossivel alimentar esse amp
ele puxa muita bateria..
queima facil..
qql baixa tensao ele queima..
n keh se encomodar.. pega um nascional sd3000 ou algo parecido
alto custo beneficio. !
se a grana ta curta parcela.. mais n pega esses xing ling n..
cara vai por min !
queima facil..
Isso aí falo tudo :legal:
2 9515 é muita coisa ...
cavalo que anda é cavalo que bebe ...
vai precisar de MUITA potencia , a 6800d precisa de uns 450 AH em pico para SPL .
Tenha em mente que os 9515 só tem SPL / SUBGRAVE ... mala aberta ele MORRE .
eu iria de 1501D + 9515 + 300 Ah de bateria
Tipo se eu colocar um sub 9515-44 e um banda ice de 1500rms( ja tenho)vai tocar melhor que 2 num modulo destes?tipo toca vai toca n vo tira o maximo desenpenho dos T9 mas agora é a grana que tenho mais pra frente vendo este modulo aqui na cidade e compro outro ,mas isso la pela metade do ano. Mesmo sendo uns modulo caco vai fica mais forte que quando eu tinha um ice 1800 e dois extreme de 15" acho eu n sei?
eu gosto de grave dentro do carro mas da queles de fazer o coração sai pela boca
porta malar aberto aki na minha cidade ja eras ,policia ambiental cai de multa na hora
1 T9 + 1 amp mtx ia ficar SHOW!
:+1 :+1
Cara 2 T9 eh coisa ignorante mesmo, sim vc vai ter td isso q vc quer mas vai ter espaço e alimentaçao pra 2 canhão desses??? essa eh 1 primeira coisa a se pensar, que carro q é?? vai ter q mexer no alternador?? vai ter no minimo ai uns 300-400ah de bateria pra 2 subs desse, tem porta malas GRANDE pra bota a caixa pros 2????
te aconselho a pegar 1 sub soh pra ver como é, se eh seu propósito e dpois pega outro, como ta sem grana pega 1 e poe na tua banda vai tocar bem já mas tenha em mente q da pra tocar mais 1 poko, mas assim vc ve se gosta do sub.
abrasss essa eh minha opiniao
:+1 :+1
O problema é qual?
TE1501D nao da... So se quiser mandar 1000w rms.
Sugiro o TA91002, mas achá-lo no PY vai ser dificil (além de ser bem mais caro que o TE1501D)... Outro seria o TA92001, mas este deve ser uma fortuna... Outro carissimo é o TE4001D...
Dificil, hein
bateria n tem galho ,ando bem pouco com o carro e vo colocalas no lugar do esterpe cabe duas de 100 ou 150 meu motor é 1.6 cabe mais uma do lado da bateria original la na frente meu o carro é um golf 2003 alternador de 90ah ,vo tira o tampão n tem problema se subir um pouco a caixa para dar a litragem que n tenho nem noção de qual seja se puderem dizer mais ou menos agradesso.
A litragem vai entre 80 e 130 litros brutos, à depender da resposta que espera.
Cara, conselho de quem tem um 9515: Bota UM apenas... se vc achar necessário, acrescenta um segundo! Um mtx desmonta MUITO carro por aí, dois é de quebrar parabrisa mesmo! Sinceramente, não aconselho NINGUEM a colocar 2 MTX 9515 sem nunca ter ouvido um num sistema bem montado!
Olha do que UM mtx é capaz:
São vídeos do meu t9! Sendo que no último vídeo, a camera não é boa de captar os graves.. mas se vc prestar atenção, um cara passa gritando: "paaauuu..... wooohooooo!!" sendo que o som da voz dele sai "distorcida" por causa do sub! (clipa o microfone)
alguem podia me passar o manual de pra min da uma olhada do 9515-44 ?
mas com a caixa que o manual manda cabe no golf acho vai fica muito locokkkkkkkkkkkkkk
achei este video na net
Editado por 100%sub
rsrsrs
so acompanhando o resultado rsrsrs
se ele realmente colocar tudo isso no carro prepara o bolso pra fazer amortecedores trazeiros pq vai ficar um peso isso ahauahauhaha... voltando ao topico se nao tiver muita grana pega um SD5000 ou Stetsom equivalente e muita bateria !!!! vai ficar um peso do caraio isso ai.....
