headshok
[Fiat Bravo] Scanspeak A pillars build
the mid range
the modified door panel
almost there
and the finished pillar 
and the door panel
for this car, it has a 9” scanspeak sub also under the dash, but its down firing.
that’s all for today folks
Cheers all!
Editado por Ianaconi
the pod for the mid range
there a little gap, so the guys has to fill it up and sand it down.
door prepped with sound dampening
A pillar ready to be wrapped!
the mid range
almost there
and the door panel
Cheers all!
headshok, could you send some info about:
1 - the equipments used in this car;
2 - the volume and configuration of the enclosures;
3 - some pics of the subwoofer box construction.
Thanks in advance
hey guys
if i'm not wrong, volume of the midrange is around 1L.
Also, this car is running DLS RA amps ( not sure abt the models)
as for the subwoofer under the glove compartment, we didnt do th einstall, so cant show u how it was done .
sorry about that.
so far, this car sounds pretty good, only thing is that the mid range needs a lot of running in,
but the up front sub+ mid bass is pretty impressive :)
cheers!
But ideally, for this setup, what i would recommend to him would be to run Arc SE amps. the more power, the better!
Cos at the moment, personally, i feel the DLS RA amps don have enough juice to bring out the full potential of the highs ( i love the scans tweets), but though in this fiat it sounded great, the highs didnt " sparkle" enough for me.
My other friend ( i posted his build here b4), a harrier running the same scanspeak tweets + seas high mid and mid bass off Arc SE amps, sounds incredible man!
But because Arc Audio is not available in Singapore, its pretty hard to come by ( friend had to import his amplifier in from a neighboring country).
let me find those pics for u guys..
Can you post a wider photo of the FIAT Bravo, as you did with the toyota?
So far it's the most amazing install I've seen on a car that was not for competition or show. Would like to see the amps install also.
Thanks
