F207P
New Car: [LR RRover Sport SE] - Fase III (audiofilia x gosto pessoal)
hand26
NEW CAR: [LR Range Rover SE Sport Edition] - SQPL Fase II (Full DA)
Equipamentos:
HU 1: APPLE iPad Air 64GB
HU 2: DVD ALPINE INA-W910
DAC: AUDISON Bit Play HD (SSD SAMSUNG SATA 250GB + HD SAMSUNG 1TB)
Processador: ALPINE PXA-H800 / RUX-C800
Amplificadores: AUDISON LRx5.1k (02 unidades)
Kit Dianteiro: HERTZ 3 vias HSK163XL ativo (Tweeter HT28 + Fullrange HL70 + Woofer HV165XL) (D e E)
Kit Traseiro: HERTZ Woofer HV165XL) (02 unidades)
Subwoofers: RE AUDIO SEX10D2 (04 unidades)
Cabeamento:
ALPINE kwe-610a (DVD to Processor)
ALPINE AI-NET (DVD to Processor)
QED Graphitte Performance Digital Toslink (DAC to Processor)
QED Reference 40 RCA (tweeters)
QED Ruby The Anniversary SPK (tweeters)
VAN DEN HUL The Wave RCA (fullranges)
VAN DEN HUL The Clearwater SPK (fullranges)
WIREWORLD Luna RCA (woofers and subwoofers)
WIREWORLD Luna 7 SPK (woofers and subwoofers)
Alimentação:
Baterias: MOURA 110Ah (02 unidades)
MC: CONNECTION 2,5F
SHOK Power Cables
Isolamento e Detalhes:
Mantas SPK
Bafles em madeira
Tweeters direcionados
Caixa Vented (02 câmaras)
Espuma auto-adesiva
Malhas TECHFLEX
Adaptadores RCA VIABLUE
Links:
1) Idéia Inicial:
http://autoforum.com...e/?do=findComment&comment=3165794
2) A partir deste ponto (138 posts após), o projeto começou a mudar radicalmente, me fazendo abandonar 95% dos equipamentos inicialmente pensados:
http://autoforum.com...25?do=findComment&comment=3172999
3) Novo Set Proposto:
http://autoforum.com...00?do=findComment&comment=3184960
4) Set Definitivo após aperfeiçoamentos (1ª Fase):
http://autoforum.com...75?do=findComment&comment=3189743
5) Sites de compras:
http://autoforum.com...75?do=findComment&comment=3190189http://autoforum.com...75?do=findComment&comment=3191305http://autoforum.com...75?do=findComment&comment=3207259
6) Fotos (Carro e Equipamentos):
http://autoforum.com...00?do=findComment&comment=3214934http://autoforum.com...00?do=findComment&comment=3216158http://autoforum.com...25?do=findComment&comment=3216512http://autoforum.com...25?do=findComment&comment=3223578http://autoforum.com...50?do=findComment&comment=3239138
7) Fotos (Projeto em andamento):
http://autoforum.com...75?do=findComment&comment=3270579http://autoforum.com...75?do=findComment&comment=3270579http://autoforum.com...50?do=findComment&comment=3324968http://autoforum.com...50?do=findComment&comment=3325669http://autoforum.com...50?do=findComment&comment=3325675http://autoforum.com...50?do=findComment&comment=3326879http://autoforum.com...50?do=findComment&comment=3326881http://autoforum.com...50?do=findComment&comment=3326970http://autoforum.com...75?do=findComment&comment=3328111http://autoforum.com...75?do=findComment&comment=3328467http://autoforum.com...75?do=findComment&comment=3328552http://autoforum.com...00?do=findComment&comment=3330668http://autoforum.com...00?do=findComment&comment=3331159
8) 2ª Fase do projeto:
http://autoforum.com...50?do=findComment&comment=3502579
9) Fotos (2ª Fase: Carro, Equipamentos e Projeto em andamento):
É isso aí, pessoal!Sejam bem-vindos!
TEXTO INICIAL
Projeto Car Theather 6.2:
Bom dia, pessoal! Estou quebrando a cabeça para fazer o som do meu carro (Discovery 4) devido ao que quero utilizar e àquilo que é mais viável e mais correto quanto aos equipamentos. Gostaria de dividir com vcs o meu projeto, aquilo que desejo obter de resultado e contar com vcs para conseguir concluí-lo.Primeiro (disponibilidade do carro): o carro conta com um espaço em cada porta para um alto-falante de 6" e um de 4". Nas portas dianteiras, mais uma coluna em cada com espaço para um ou dois tweeters (adaptando no segundo caso). No painel, na parte central, voltado para o pára-brisas, há um espaço de 4". Entre os bancos, dois porta-copos de 3" cada. Atrás, um porta-malas de cerca de 700L.Segundo (intenção de som): gosto de som com qualidade, definição e graves exagerados, porém sem cobrir as outras freqüências. Gosto de ouvir todos os timbres, mas não gosto de médios agressivos. Gosto de médio-graves e agudos bem presentes.Terceiro (equipamentos comprados): já do outro projeto, tenho comigo, dois kits Bravox CS60CF, de 80W RMS cada lado, e 6", bem raros, com cones de fibra de carbono e tweeters de seda, com divisor externo, sensibilidade de 89 e resposta de 50-30.000. Dois midrange Bravox PM4, 4", com 40W RMS cada, com sensibilidade de 86 e resposta de 100-10.000. 4 subwoofers Bravox E2K15D, com 15", 900W cada, bobina dupla 2x4, sensibilidade de 87 e resposta de 25-1.800.Quarto (intenção de compra): em cada porta, quero fazer um canal estéreo com um dos lados do kit bravox e um alto-falante de 4" a definir, entre coaxiais e midbass, ou até outro kit duas vias. Na parte central do painel, um midbass ou coaxial de 4". Nos porta-copos, dois midranges de 3". Amplificadores, seriam banda, com um 2.4, um 4.8D e um 3500.Já me desculpando pelo texto longo, vamos às dúvidas:1. Acho os midbass de fibra de carbono bravox meio chochos, sem muita presença, mas eles estavam instalados na parte de baixo das portas de um 307 (posição não muito adequada), em portas tratadas com 3 camadas de manta aluminizada. Devo trocar o kit? Posso melhorar a resposta deles com o posicionamento?2. Os midranges PM4 são bem presentes, mas tendem à agressividade. Posso usar um deles no painel central ou devo colocar um fullrange NAR 4" serie 3?3. Nas portas, usar um midbass de fibra de carbono com seu respectivo tweeter e um midbass NAR 4" serie 3 deixaria o meio-grave mais agressivo ou alto do que os agudos? Deveria optar por um kit NAR 4" serie 3, junto ao bravox?4. Para o canal central, nos porta-copos, um par de midranges Hertz TL90 ficariam bons? Nunca usei a marca?Bem pessoal, é isso. Tudo fica a cargo dos gastos, pq minha dúvida é se os kits bravox são ruins comparados a JBL, Hertz, NAR... Sinceramente, já escutei um som morel e focal, com processador auditor e, apesar de achar o rendimento muito bom, não achei tão fenomenal assim! Cabos RCA são Stinger, duas baterias Moura Boat 150a cada, manta aluminizada em todo o carro e uma caixa de 240L líquidos para os 4 sub, separadas e dutadas. O modulo 3500 puxará os subs. O 4.8d o estéreo as portas. O 2.4 os canais do centro.Gostaria de orientação quanto ao que devo fazer melhor!
EDIT MODERAÇÃO - Alteração do tamanho da fonte, pois estava difícil a leitura.
Editado por F207P
1 - tu tem certeza do que tu disse? car theater 6.2?
2 - quanto PRETENDE gastar?
3 - quanto PODE gastar?
4 - tem disponível outro carro enquanto fica sem este aí um bom dum tempo enquanto este é montado?
5 - não falou nada sobre HU... tem, vai comprar? nem processador...
Eu trocaria tudo que voce já tem e tentaria equipamentos ao nivel do seu carro... procure algo mais refinado, Bravox sinceramente, não tem nada que se enquadre no que voce busca :legal:
Tudo depende de: foco, perspectiva e bolso... tendo uma Disco 4, dá pra iinvestir num set bacana. (eu acho) hehehehe
abs.
  Em 04/06/2013 at 17:29, Robson_Lira disse:
abs.
Montar algo tão ousado e sair de um bravox pra um nar acho é perda de tempo...
A ideia é boa, os equipamentos que você pensou nem tanto.
Eu acho que dá para usar uns equipamentos melhores em... Bravox seria para um set bem de iniciante mesmo.
Já que você gosta de bastante pegada, poderia colocar um Hertz Hi-Energy... HSK na frente...
Rapaz, lendo bem o texto, voce não acha muita "adaptação" para um veiculo desse porte $$$, a não ser que isso não seja problema?
Anyway, a eletronica embarcada desses veiculos são um tanto complexas, qq tipo de adaptação é um risco que voce irá correr, a não ser que o instalador alem disso seja um bom projetista e te garanta que saira tudo perfeito, no mais, eu não aconselharia muitas modificações severas, alem do que, os equipamentos OEM dessa linha, são bons pra caramba!
EU, não arriscaria tal feito, no maximo um processador e troca dos falando no locais originais.
Editado por Robson_Lira
  Em 04/06/2013 at 17:14, CristianoLO disse:
1. São seis canais estéreo com respostas de freqüência semelhantes e doutas caixas de grave com dois subwoofers cada, cada uma posicionada em um lado do carro.
2. Em torno de 6.000
3. No máximo 8.000
4. Acredito que quando se monta um carro assim já se saiba que vai ficar sem carro (sempre fico 7-15 dias sem).
5. DVD 2-din Pioneer AVH P8480 BT
abs.
Sinceramente, gosto de som, mas não me vejo pagando 7-13.000 em um kit duas vias. Quais seriam marcas ideais, com um custo interessante?
  Em 04/06/2013 at 19:37, felipego disse:
Gostei da idéia, pelo menos vc foi um único que sugeriu algo. Já havia pesquisado sobre este kit e vi várias pessoas falarem sobre o mid ser agressivo, procede?
  Em 04/06/2013 at 20:01, Robson_Lira disse:
Minha versão é a SE, portanto vem com uma unidade bem sem graça, com som ruinzinho. Então não cogito comprar um processador auditson para melhorar um sistema que só lê cd e mp3. Pretendo fazer tudo em paralelo e não mexer em praticamente nada na fiação original do carro.
  Em 04/06/2013 at 21:01, F207P disse:
é bem agressivo mesmo.. SPL alto, com bobina que aguenta bastante potência... porque se realmente você for colocar esses Bravox E2K, eles tem SPL extremamente alto, você vai ter que ter um kit muito agressivo para acompanhar...
Na minha concepção esse bravox e2k vai atropelar muito as frequencias, vai tremer o carro todo, eu não gosto desse tipo de som... mas gosto é gosto...
se você quiser um grave fo** mesmo, você poderia colocar 2 Questo Audio de 15" atrás... Isso sim é grave bom e macio!
  Em 04/06/2013 at 21:06, felipego disse:
Legal!!!!!! Rsrs... Bom, então, uma saída poderia ser dois kits 2 ou 3 vias HSK Hertz para as portas?
Vai mandar em alguma loja ? Procure uma de confiança, com referências... Não custa avisar.
To com um projeto em andamento, em fase de compra de equipamento (na verdade, esperando os fretes rs) e a loja que pretendo deixar faz serviços em todo tipo de carro... O mais absurdo que vi recentemente foi um Mustang Shelby 900hp, importação própria, novinho e o cara deixou lá pra eles fazerem. Os caras mandam bem, confiam no próprio taco e cliente nenhum tem medo de deixar lá.
Por que to falando isso ? Já tive problemas antes, pensei em tudo, falei como queria, pensei que tivessem entendido e fizeram mer**.
Larguei mão, desmontei tudo e levei na loja que eu falei anteriormente, pagando um preço justo ainda por cima.
Se for manter esse sistema multicanais aí, você terá que usar MUITOS amplificadores, ou seja, gastar mais do que um sistema "comum", digamos assim.
Obviamente mais canais também significam mais auto falantes.
O que você busca com esse sistema 6.2 exatamente ? As vezes um 3 vias ou até mesmo um duas vias te supra já. Um palco bem acertado não precisa mais que 2 canais estereofônicos... a imagem que se forma entre (e virtualmente, até além dos auto falantes) dá a impressão de ter mais de 2 canais. Frontais, obviamente.
Abraço.
  Em 04/06/2013 at 21:26, murillo_g_b disse:
Abraço.
Cara, sinceramente, era isso que estava esperando: opiniões, sugestões e conselhos. Bem, o que quero é realmente suprir os graves, pois não penso em trocar os E2K, e obter uma imagem estereofônica a mais realista possível. Quero tentar montar um som que m passe a impressão de não sentir o som direcionado, de não saber de onde está vindo cada resposta de freqüência! Quanto ao local de instalação, sempre faço no mesmo local, até viajando para fazer com ele pois hoje moro em outra cidade. Monto meus sons desde quando comecei o mais básico, há mais de 10 anos com ele, mas agradeço demais o aviso. Acho que todos procuramos um bom som mas não queremos gastos exorbitantes, então, o melhor set que havia pensado era em um kit 3 vias Hertz HSK na frente, mais um kit duas vias Hertz atrás e um kit de midrange Hertz no canal central, o que me daria um total de 2500 reais. Acho um valor bem interessante.
Vc tbm acha bravox e banda perda de tempo? Devo me desfazer deles mesmo?
  Em 04/06/2013 at 21:35, F207P disse:
Com certeza acho perda de tempo, se fosse pra um som sem compromisso com fidellidade, imagem estereofônica definida, precisão tonal, e tal, só tocando alto, aí tudo bem.
Pra ter uma imagem bem definida, esquece kit 2 vias atras. Você deve prezar pelo estereo na FRENTE... mais ainda, para o motorista.
Justificativa: nem fone de ouvido consegue reproduzir um palco sonoro, imagina com som vindo de tras ? O som tem que vir da frente.
Se fizer questão de ter uma ambiencia atrás (pelo carro ser grande é interessante pra quem vai atras), eu optaria no máximo por um full range ou coaxial, porque não atrapalha no palco sonoro e a imagem continua boa, principalmente se os auto falantes ficarem numa posição baixa, no pé do passageiro. E nesse caso poderia ser até o bravox mesmo, sem estar amplificado, só pra preencher o ambiente traseiro.
Eu não conheço esse hertz, mas com certeza ja ja aparece algum user que conheça pessoalmente uma variedade maior de auto falantes e indica alguma alternativa.
Eu já tive um kit morel tempo, melhor kit de entrada na minha opinião, agora to com um diamond hex em caixas de papelão só pra matar a vontade enquanto não vão pro carro, e já achei MUITO superior...
Pode ser que o som que você ouviu não estava bem acertado ou alguma linha de entrada talvez, não sei, mas com certeza não ficam no mesmo nivel de bravox e etc.
O que você ouve normalmente ? 4 subwoofers de 15 polegadas é um tanto absurdo não acha ? [""]
Você já ligou isso tudo alguma vez? Eu usava um JL 12w3 com 60% da potencia máxima dele e já tocava bem, agora vou usar com 100% e até um pouco mais pra ter headroom, imagino que terei que atenuar pra integrar bem com os mids.
  Em 04/06/2013 at 22:14, murillo_g_b disse:
Cara, já montei sim os 4, rsrs... Resultado, grave bem forte e tremendo todas as paredes do lado. Escuto de tudo, mas curto ouvir alto dance e rap!!! Gostei muito do que vc falou, bate bem com o que gosto e espero.... Achei interessante as idéias do fullrange atrás. Acredito que não "desviaria" esse palco.
Editado por F207P
Rapaz, conheço muito bem a Discovery 4 e de forma alguma trocaria o stereo original por qualquer outra marca. Não compensa! Voce iria acabar gastando dinheiro ( que poderia comprar equipamentos que realmente irá fazer diferença) e se bobiar tera o resultado praticamente igual ao original (se nao inferior).
Um bom processador seria o suficiente.
Voce postou que tem 4 e2k, deve gostar de frequencias baixas e por mais que eu admire o conjunto formulado pela Land Rover, trocaria 4 e2k por ou dois subwoofer bons, podendo citar o famoso JL W7. Para fechar um bom amplificador mono.
Isolamento acustico é otimo, nao vejo motivo de melhorar ( a nao ser na parte do porta malas).
Abs.
  Em 04/06/2013 at 22:30, Rodrigo Kalanascovic disse:
Abs.
Quando vc fala do estéreo, vc fala dos falantes internos? Nossa, eu achei tão ruins!!! A não ser qu o problema seja a unidade principal... Vc acha que o melhor seria acrescentar um processador? Mas aquela unidade nem lê DVDs... Desculpe se não entendi bem!
Edit.: Lembrando que a minha não é a HSE, é a SE, portanto não tem a central multimídia touch-screen.
Editado por F207P
Não precisa gastar tudo isso para se ter um bom resultado, existem kits bem refinados muito abaixo desse teto :legal:
Mesmo sendo a versão SE ela possui um bom sistema de audio, incluindo subwoofer, eu acho massa demais!
Somente reformularia estes equipamentos, dependendo do estilo musical e do volume que você costuma ouvir suas musicas, podemos indicar algo com valores conscientes e dentro da realidade.
Apesar que estamos falando de um projeto num veiculo de mais de 150.000,00 EU ficaria com muita dó de realizar qualquer tipo de instalação que pudesse comprometer a originalidade do veiculo... mas isso é MINHA OPINIÃO.
Abs.
  Em 05/06/2013 at 00:01, Robson_Lira disse:
O seu sistema é este?
Este mesmo...
Obs: Meu carro não tem subwoofer não...
ME AJUDA?? :pirou:
Editado por F207P
Bom, todas Disco 4 que andei tinham inclusive as SE, segue abaixo informaçoes do fabricante.
Harman/Kardon (Alpine Gen, arquitetura 2.1 MOST): 11 alto-falantes, incluindo um Subwoofer, rádio, entrada única para CD, touch screen com 7", compatibilidade com unidade mp3, EON, RDS, PTY, TA, amplificador digital de áudio, entrada auxiliar, (380 Watts) ("High ICE")
Harman/kardon® and LOGIC7® são marcas registradas da Harman International Industries, Incorporated.
Brother... Eu trocaria FACIL os 4 E2K por 2 JL 13W7, tenho certeza que o SPL ficaria insano, e com muito mais qualidade que esses outros 4. Quanto ao stereo, Hertz HSK XL 2 vias na frente, coax atras, amps Mosconi AS 300.2 pro kit, e algum amp gringo TORA pros subs, talves um Fosgate ou algo do tipo.
E na HU um peocessador legal, talvez Mosconi 4to6 mesmo.
  Em 05/06/2013 at 00:14, Robson_Lira disse:
Cara, este som, que eu saiba, é exclusivo da versão HSE. A única coisa que acho provável é que seja opcional da SE, mesmo assim, acredito que não. observe as diferenças... A própria foto que vc me demonstrou não tem a tela de 7". ela é uma tela comum, sem sensibilidade ao toque, bem distante da HSE...
SE:
HSE:
  Em 05/06/2013 at 00:38, evepainkiller disse:
O XL está descontinuado... agora soh o HSK de 250wrms!
  Em 05/06/2013 at 00:46, F207P disse:
SE:
HSE:
SE:
HSE:
De fato as especificações citam o touch de 7', porem essas são as informações que estão no site sobre a SE... vai entender ehehehe.
Bom, se gosta de uma pegada a mais nos graves, o HSK como te indicaram é uma boa, no fórum tem um user vendendo um kit 3 vias Jl Audio novinho num preço bacana, este também te atenderá tranquilamente já que sua porta possui um espaço para um mid de 4'.
Enfim, se o lance é subgrave, pense em outro sub, como já indicaram, o W7 é uma boa, porem prepare o bolso, se for a versão de aniversário, os preços são bem agressivos.
Agora esse lance dos mid range no porta copos, acho arriscado, o certo seria dar uma identidade para o seu projeto, se eh SPL, SQ,... enfim, pode ser gasto de grana e frustração certa.
abs.
Bem, olhando para algumas outras marcas, acabei achando algumas coisinhas por preços inimagináveis, rsrs... Bem, vou pedir a opinião de vcs para uma mudança radical:
Nas portas dianteiras, kit 3 vias Hertz HSK 163 150W cada lado
Canal central com par de midrange Hertz HL 70 50W cada
Amp para o estéreo Mosconi One 4 120W x 4 canais
Obs: encontrei o amp no site shop.audiomaestro.com.br
É confiável?
Críticas?????
Edit.: o que iria na parte de trás? Fullrange?
Edit 2.: cabos RCA. Havia pensado em Stinger ou audiophonic? Alguma reomendação?
Edit 3.: vou manter os sub. Qual o amp para estes 3600w?
Editado por F207P
