headshok
[Mit L200 Triton] Shok Industries Demo Car ( SQ Ground Pounder)
hey people!
now got the good stuff.
its time for the BIG DADDY to be mounted! for those asking, amp is just a simple 8.5kw amp :)
the amp base
some holes for some kind of ventilation
time to soder up the wires
test fitting the inputs :)
top view
RCA may look whimpy, but looks can be deceiving :)
getting ready to wire up the amps.. 9 positive and 9 negatives inputs.. heheh
all with the SHok Reference Pro 5285 :)
More fun coming up soon!
cheers!
Hi guys!
and now for more fun!!!
Time to get the Big Daddy Hooked up!
Man i love these inputs!
but a big pain to wire up! haha
a little acrylic cover
finally done
Now to hook up the rear batteries:
now to hook up the front battery
i have 4 runs of +ve and 4 runs of -ve.
Since i have easy access to some copper buss bars, might as well use them :)
making a little stand for the fuse holders
and getting the ground wires and big 3 wires all hooked up
a little cover test fit
and finally done
and a little sneak on whats coming up next
insano! creio que esse seja um dos trabalhos mais tops que já vi!
não sabia que tinha um tópico desse set além do smd forum...
congratulations for u!
one word AMAZING...!!!
The rim and Tyre setup is simply one of the best I've seen in a truck!
PS: Gotta have balls to drill 2 big holes in a brand new car!!
hi guys!
and now, as request by some, its time for what goes inside the cabin :)
Since this is a pick up truck, and there's no way i can do a blow through and no way in hell i'm doing a wall ( truck's too expensive to mess it up that way)
It'll be easier to just have a massive box in the back seats.
BUt anyway, first thigns first, gotta build a frame to hold the box down to the truck :)
so here goes:
guess there'll be more more back seat action for me now :(
test fitting
all done
heehhe..
and now lets see what we hve here
stay tuned in for more :)
hi guys!
now its time for the woofer box
This box is sort of a temp box as I have something in the works and those motors are kinda big, not too sure if they'll fit inside this box as space is a little tight
Total volume is around 9 cub ft. It was supposed to be tuned around 32hz, but i think i kinda mis-calculated the port length ( too long), so its tuned a little lower :)
anyway, here are the pcis
using 1" MDF all around,
i got dual 6" precision ports
cutting out the port hole
test fitting
checking out the front baffle
sub lying around
sub hole cut out
gluing on the 2nd baffle
screwing it down
now test fitting it into the truck
checking to see if the mounting holes line up with the mounting points
taking a quick snooze :)
Stay tuned for more!
cheers!
isso é o que 15" ? 18" ?
deve embolar um horror num rock ou qualquer coisa mais rápida
Às vezes o que passa a sensação de som embolado não é nem o Subwoofer, e sim a acústica da cabine, que não tem espaço para a propagação da onda na velocidade que foi produzida!
Parabéns pelo Projeto!
OFF: Até vc por aqui, Rennan?! o-o-
kkkk....vi o nik e ja imaginei q era vc..huahua
mundo pequeno..
largo da bike entao?
abraço
mundo pequeno..
abraço
Nem! Deixei o som de lado um pouco, faz um bom tempo atrás, eu voltei pro antigo vício que já era a bike!
Não tenho como conciliar os 2 juntos... Vai muito $$! hauhauhau
Editado por Vinícius MB
Devia ter ouvido o focal de 16" do rick... Melhor que muito falante de 10".
Desconheço esse Focal, mas não da pra generalizar a coisa! Que subs maiores são mais lentos que menores...
Já tive um 15" Kicker antigo (linha Solobaric, porém quando era redondo ainda, não lembro do ano, coisa de 2002 talvez), e garanto que não passava feio para alguns 10, em agilidade...
Não generalizei de forma alguma Vinicius, por isso falei "melhor que MUITO falante de 10", e não todos.
O focal dele era o 40v1. que inclusive está a venda.
Não me referi a vc, Scult! Só quis dizer que muitos acham que subs maiores são sempre mais lentos que menores.
E que voce quotou justamente o meu post né, ai achei que era pra mim.
