erto
    453
Tudo que erto postou
  1. Modulos : Hertz he4: R$400,00 Mtx rfl1200d: RMS Power Rating: 4 ohms: 400 watts x 1 chan. 2 ohms: 800 watts x 1 chan. 1 ohm: 1200 watts x 1 chan. [*]Max power output: 2400 watts x 1 chan. [*]MOSFET power supply [*]Electronic Bass Control allows the user to adjust the bass from a remote controller that can be installed near the drivers seat [*]Power and protection LED indicators [*]Tuned Bass EQ (0-12 dB bass boost) [*]1 channel operation [*]Active Fan Cooling technology has air inlets along the top of the amp and hot air outlets on the sides [*]Gun metal gray chassis [*]Black end caps [*]Large brushed MTX Audio Gothic logo [*]Unique stackable design that allows them to be installed multiple configurations [*]Smart Engage technology makes it easy to add RFL amplifiers to any factory or aftermarket system [*]Nickel-plated RCA level inputs [*]Nickel-plated screw terminals [*]Variable low-pass filter (40-200 Hz, 24 dB/octave) [*]Subsonic Filter (20-50 Hz, 12 Hz) [*]CEA-2006 compliant amplifier [*]Frequency Response: 20-200 Hz [*]Signal-to-Noise Ratio: 62 dB [*]THD (Total Harmonic Distortion): <1% [*]Maximum Input Signal: 5V [*]Maximum Sensitivity: 250mV R$700,00
  2. Amigos estou vendendo meus subs usados, por apenas R$280,00 cada tenho 2 und. r$240,00.Sub muito macio com qualidade.Especificações: 10" Subwoofer Dual 4 Ohm voice coils 500W RMS Handling 1000W Max Power Large Butyl Rubber Surrounds Rugged Die-Cast Basket Dual Spiders Massive 2.5" Voice Coils Works in 0.42cu.ft sealed enclosure
  3. Funcionando 100% Utilizo um hertz he4.1 para tocar eles. kit dsk 165- R$ 250,00
  4. Voltando as vendasss... UP cotação só me mandar MP.
  5. link do fabricante.: http://www.teaccaraudio.com/
  6. eu usei um stetsom 2k5 num dd1515, um dia não cuidei clipo e fudeu. Mas no mais era tranquilo e forte. Eu to usando 2 cerwin vega de 10 polegas 500 rms cada no fusca e tá forte pra kcte.
  7. Som tocando já :D
  8. Depois de algum tempo o set está tomando forma. 2 cerwin vega v-max 500 rms 10 polegadas. 1 mtx 1200d 1 bateria freedom 115 amp. 1 player Clarion dxz 786 1 kit hertz dsk 165 No momento estou sem amplificador para médio.. Mas o negocio ficou forte d+ tenho até medo de aumentar o volume.
  9. Valeu ae pessoal, amigo nao achei esse focal....vamo que vamo.
  10. amigo do dr dree não achei mas tem outras dock legais....
  11. ficou top hein amigo.
