Boris
Hi-end Arsenal Da Jvc Com Hemp No Cone
Bom galera não sei se essa é o lugar certo pra postar isso, mas como é a linha Hi-End denominada da JVC resolvi postar pra galera ver e comentar, é uma linha que vem 10% do caule da ma*****, e diz dar uma redução natural no sub em medio e alta frequencia naturalmente. Então achei interessantissimo isso e acho que poucos devem ter visto. então quem quiser ver o site ta ae e vou botar alguns curtos textos mas olhem no site vcs mesmos.
http://mobile.jvc.com/Ahemp.jsp
<Speakers>
-Provides natural mid and high frequency sound
-Creates a smooth transition between woofer and tweeter crossover frequencies
-Strong and light - allows for more power capability and stunning sound quality
<Subwoofers>
-Eco-friendly Hemp Fiber reduces unwanted mid and high frequencies in subwoofers - like a natural low pass filter.
-Internal loss is reduced within the speaker diaphragm for pure fidelity
Arsenal Subwoofers and Component speakers include 10% HEMP fiber blended into each speaker cone and dust cap. Not only does HEMP fiber make the cone stronger, it also reduces internal loss within the speaker diaphragm which creates clearer sound. HEMP also acts like a low pass filter in speaker drivers and subwoofers – creating a natural low pass filter to eliminate unwanted frequencies in subs and help to smooth out the transition between driver and tweeter frequencies in Arsenal component speakers.
HEMP is an eco-friendly material used in clothing, rope, and even automobile manufacturing because of its tensile strength. Its manufacturing qualities make it a great material for speaker cones - so with the use of HEMP…JVC once again redefines the meaning of “High Fidelity!”
ABRAÇÃO E ESPERO QUE TENHAM GOSTADO E TOMARA QUE SEJAM BONS MESMO. QUEM SE ATREVE A COMPRAR E FUMAR? HEHEHE
Se eu mandar sinal clipado pra esse sub, eu posso queima ele?
Como é Q enrola esse negocio ai?
o-o-
Bonito o bixo é.
Subwoofer CS-AW8240
Cone Size 12inch
Cone Type Kevlar-Hemp Fiber
Frame Alminum Die-Cast
Edge Santoprene
Gasket ABS
Magnet 103.2oz Strontium
Terminals Copper
Frequency Response 20 - 500Hz
Power Handling Capacity (Max. music power) 3,000W
Power Handling Capacity (RMS power) 1,000W
Impedance (ohms) 4 +4 ohms (Dual Input)
Sound Pressure Level 81 dB
Mounting Depth 195.8 mm
arfe..... era só o que faltava
depois do wood cone e do pure malt speakers
Será que se sobrecarregar o falante ate queimar, a fumaça dá barato???
Ai a imagem, ambiência, etc vão ficar duca#$#!!!
Desculpa, mas não podia perder a piada...
auhauahuaqh!!!
boa!
falam q a fibra é bem resistente, será q é leve e resistente tb?? agora ja tao apelando!
abs!
Interessante o bagulho (literalmente). A fibra da Maria Joana aparentemente é tão longa que o pessoal consegue até fazer tecido dela (nada de pensarem em SEDA! Isso quem produz é a lagarta). Deve realmente ser do mesmo naipe de falantes de fibra de bambú, porém deve ser até mais leve.
No sub eu já não sei se teria efeito, até porquê o cone usa kevlar também.
Mas fica a pergunta... Se eles usam o caule, o que fazem com as folhas que sobram? Porquê não chamaram de Billie Joe Speakers? Se o pessoal abusar do sub e sair fumaça pelo cone, a polícia pode prender alguém? E será que o D2 já tá sabendo do lançamento?
ma***** está cada vez mais na moda hehe. Os vifa xt são feitos de hemp tb.
Vale a pena ver a marca hemp acoustics, mto lko o simbolo da empresa é a própia folha huahuahua.
mas se fosse fazer Bicho Papão com cone de mac0nha, teria q vender os reparos à preço de custo... pq o que ia ter de neguin comprando reparo adoidado... e colocando bass boost +18db no amp, loud on no player e etc... =P
mas galera o troço é hi-fi, tem que escutar pra ver mesmo se o troço é bom, só sei que a fibra da ma***** é uma das mais resistentes no mundo, sendo usada até em produções automotivos e entre outras coisas, isso saiu na revista superinteressante, e também tem o óleo dela que é muito bom também, não duvido que não seja bons esse sub, e outra coisa , outra NOVIDADE, a KICKER lançou um SUB com imã de NEODIMIUM, super leve e compacto, deve ser bom ein pessoal vem ele no site é o modelo COMPVT, tem de 12 e 10" com 400rms.
quyando o falante queimar so vai dar os nego tudo doidao dentro do carro hauHAUhauHAUHauuHA
bonito o sub é viu... deu gosto de ver a foto dele!
muito bonito mais ...
********* Sound Pressure Level 81 dB **********
nao gostei nao, muito pouco sensivel, deve ser uma mer**
*fuma fuma fuma, folha de bananeira, fuma da boa so de brincadeira,
*fuma um, fuma dois, nao deixa a erva pra depois, porque aki na arvore seca tem ma***** ate de dois (R$2,00), levanta a mao pro alto so quem fuma a du boldinho.
Realmente é pouco sensivel. Mas pela potencia e pela estrutura do bixo. Imagina o Q deve descer esse sub. OS MTX são pouco sensiveis tb e tocam horrores.
