ViihBass
[Focus Ghia Hatch] Instalado by KBLO Som !
Veículo: Chevrolet Corsa Classic 2012/2013
Hu: Pioneer DEX-P99RS - OK
Sistema Multimídia: Tela Alpine Tme S370 6.5" (GPS + Tv Digital + Câmera de Ré) - OK
Kit 3-Way: Focal KRX3 - OK
Ampli Stéreo: [[-- DÚVIDA --]] Soundstream Human Reign HRU.4 OU Phoenix Gold Outlaw 1845 Ltd Edition - OK
Speaker MID: Canare 4s11 - OK
Speaker MR: Canare 4s8 - OK
Speaker TW: Chord SS - OK
Cabo RCA MID: ?
Cabo RCA MR: Tchernov ORIGINAL IC (5mts) - Aguardando Chegar!
Cabo RCA TW: Tchernov ORIGINAL IC (5mts) - Aguardando Chegar!
Subwoofer: Focal 40Kx - OK
Ampli Sub: [[-- DÚVIDA --]] Soundstream Human Reign HRU.4 OU Phoenix Gold Outlaw 1845 Ltd Edition - OK
Speaker Sub: Canare 4s11 - OK
Cabo RCA Sub: Audison Connection ST2 2,5m - OK
Bat. Cofre: Optima Yellow D34/78 (55ah) - OK
Bat. Aux: Optima Yellow D34/78 (55ah) - X
Cabo Positivo: Shock Insústries Referençe Pro 54mm + Shock Insústries Referençe Pro 21mm - OK
Cabo Negativo: Shock Insústries Referençe Pro 54 mm + Shock Insústries Referençe Pro 21mm - OK
Porta-Fúsivel: Connection SFD41C - OK
Tratamento Acústico: Manta Technoise 4 Folhas 2,2mm (30x90cm) + Manta Technoise 5 Folhas 2,2mm (45x80cm) + Dynamat Extreme 9 Folhas (81x45cm) - OK
Editado por ViihBass
:vts AEEEE!!!
gALERA procureiii pacaaaaas !!! O SS HRU.4 e desisti pois no meio do caminho encontrei outro ampli 4ch que acredito me satisfazer ! shsuhsuhsu
potencia tbm não faltará ! hasuhasuashuash, da uma olhada ai no bixi!! detalhe: NOVO, NUNCA INSTALADO ! OpO OpO :legal:
20140102_200708_zps671d5c66.jpg20140102_200203_zps781af9cc.jpg20140102_200212_zps81bdcf83.jpg20140102_200353_zps6a887639.jpg20140102_200254_zpse80670e3.jpg20140102_200330_zpsc5b97f42.jpg20140102_200635_zpsdfb979b5.jpg20140102_200833_zpsb17b54d0.jpg20140102_200928_zps7ab1de8a.jpg20140102_200749_zps7c5b0c85.jpg20140102_201726_zps41773835.jpg20140102_201624_zpsbd957493.jpg20140102_201614_zps44058126.jpg20140102_201710_zpsc2fea1b6.jpg20140102_201704_zps98922a2f.jpg20140102_202348_zps37bf64bc.jpg20140102_202824_zps6d4e8b17.jpg20140102_202832_zps5f1ff3f5.jpg20140102_202820_zps04c74ef2.jpg20140102_202828_zps3a069c47.jpg20140102_203124_zps9f4cfe3b.jpg20140102_203133_zps3e70832f.jpg20140102_202856_zpsf6fc4ae2.jpg20140102_202837_zpsf36e63ea.jpg20140102_202837_zpsf36e63ea.jpg20140102_203336_zps63b37c42.jpg
Agora é corsa Surf Edition só as pranchas !!!! hsauhasuhasuashuashasuhasuhasu [^] pasmafaute
:vts :vts :vts
kkkkk vc nao presta! Precisa de espaço e pega um amp do tamanho do carro! kkkk
Ta ligado que vc daqui a pouco nem com o krx3 ta mais ne. Vc nao sossega
Pois é... tem q trocar de carro!:vts
To sussa hahahahaha!
Mais man lateral e fininha poxa!! Kkkkk
Hahahahahaha
Helix A1?
A não pera!!!! Esse aqui vi num tal de classificados!! ;D hahahahahahaha
:vts :vts :vts
Irado cara, posta as specs do amp pra gente babar mais ainda. Hahahaha
AS ideia!!!! huahsuashuashuashuahasu o-o- o-o-
Specification-
OUTLAW Specification
Gold Plated 2 Layer, 2 ounce Copper G10 Glass-Epoxy Printed Circuit Board
Dual power inputs
High-Current Triple-Darlington Output Stage design
Tri-Linear output capacity (simultaneous stereo & bridged mono operation)
Stereo 12dB per octave, continuously variable crossover from 30 to 500Hz
Selectable HP, LP or Full Range for the internal amplifier and HP or LP for the external output
Adjustable High-Q Bass EQ (0 to + 12dB) @ 45Hz
Pulse width Modulated MOSFET Switching Power Supply
Stable into 1 ohm stereo or 2 ohm mono loads
Variable input sensitivity (200mV to 2V)
Thermal Overload Protection
Superior muting circuitry assures no turn on / off noise
Optically isolated power supply
VI limiting circuitry with over-current LED
Low RFI/EMI design
Bridgeable Outputs
Extensive burn-in and QC testing for the ultimate in reliability
Made in the good ol' USA
4 ohm stereo @ 12/13.8 VDC
(M50, M100) 50/85, 100/185 WRMS
2 ohm stereo @ 13.8 VDC
(M50, M100) 120/230 WRMS
4 ohm bridged @ 13.8 VDC
(M50, M100) 245/500 WRMS
Crossover Frequencies
30Hz to 600Hz
Crossover Slopes
12dB per Octave
Bass EQ
0 to + 12dB @ 45Hz
Input Sensitivity
200mV to 2 Volts
Case Dimensions
29.25"L x 10.63"W x 2.0"H
Dimensions with Flanges and Terminal Blocks
29.25"L x 11.63"W x 2.0"H
M100 section:
2 x 100W @ 4 ohms (12.0V)
2 x 185W @ 4 ohms (13.8V)
2 x 200W @ 2 ohms (12.0V)
2 x 230W @ 2 ohms (13.8V)
1 x 500W @ 4 ohms bridged (13.8V)
M50 section :
2 x 50W @ 4 ohms (12.0V)
2 x 80W @ 4 ohms (13.8V)
2 x 100W @ 2 ohms (12.0V)
2 x 120W @ 2 ohms (13.8V)
1 x 245W @ 4 ohms bridged (13.8V)
É noiz manolo!! Valeeu !!
As baterias vão embora por causa do peso...
Mas o Vitão já mandou MP para usina de Fukushima e já tá a caminho uma barrinha de urânio...
#contrataeucarlosalberto
:vts
Caceta! Que usina!
é bruto !! auhauhauhauhauh
:vts
#contrataomeninUsagaZdasPiadas
:vts :vts :vts
kkkkkkkkkkkkkkkkkkk
Chega parei...
#SQN
pra falta de espaço na mala.... amigo traz a solução... tó!!!!
http://produto.merca...has-de-surf-_JM
:vts :vts
:vts
Isso pode até ser BEEM útil hein! tem algum que seja impermeável ? essas pranchas tem só um problema, não podem molhar !! hashuashuashuash
:vts
Mano rachei o bico aqui !!! shauhasuhasusahuashuash
Tardeeeeee !!!! :vts
Fala ai Rapaziada !! Fiquei meio sumido esses dias por aqui, malz que a correria tava demais !! pasmafaute
Bom vamos lá, como todos ja sabem já montei e desmontei BAGARAIIII saporra aqui desse som ! shushushush
da última vez tive muitos conselhos de que o grave ia ser tenso e talz... fo**-se montei e desmontei ! [^] lkkkkkkkkkkkk o grave ficou muito insano, e como estou velho ja não tenho mais ouvido/saco pra isso ! ahauhauhauh ainda mais o dia todo na rua, tireis as baterias e os 2x JL 10w7 pois para meu carro (no diaxdia) alem de ser exagero é muito peso! fora a principal complicação! ESPAÇO !!! pois carrego um treco na mala ! hauhauahuah
- para com essas po*** de trocar equips de 5x5 dis ! huashsuahasuhasuhasuashuashuash :blink::legal:
Nós (eu, Everton, Alves, e o fórum inteiro ) avisamos hhauhauhauhauah.....
:vts
:vts :vts :vts
Vitão! Que achado mesmo hein!
Bom, já que vc tem 2 pranchas.... diga aDeus as laterais do pm.
Sobre a caixa do sub, cara, (imagina vc olhando o pm do carro de frente ok) pq vc não faz uma "esticada" que preencha todo o fundo do pm E no final dela, tipo, do lado direito, olhando de frente, faça um compartimento para a bateria.
Acho que não comeria tanto espaço assim do pm. Um amp em cada lado, mais essa caixa bem de fundo, ia ficar um bom espaço livre no centro.
Caramba...
Mas é um doido mesmo....
Corsa Usina!
Gostei do nome do Corsa!!
:vts :vts :vts
Editado por Kired
