Henrique A3
JBL 1004, Focal solid 4, Kenwood Excelon XR-4S
Boa Noite a todos do forum.
Estou na reta final do meu set mas preciso definir o amp
Minha intenção é colocar so 1 amp para o set inteiro
SET
Portas tratadas com KIT MB quart pvf 213
Sub JL10w1
Fiação audiophonic
As opções de amp são:
120 Watts (RMS) x 4 @ 4ohms
• 150 Watts (RMS) x 4 @ 2 Ohms
• 300 Watts (RMS) x 2 @ 4 Ohms (em bridge)
• Fonte Dupla de Energia
• Capacidade de "bi-amplificação"
• HPF Variável (Alta): 2,5~10 kHz -12dB/oct
• HPF Variável (Baixa): 50~200Hz -12dB/oct
• LPF Variável (Alta): 2,5~10 kHz -12dB/oct
• LPF Variável (Baixa): 50~200Hz -12dB/oct
JBL 1004
Description 600-Watt 4-Channel Full-Range Amplifier
Series Grand Touring
THD + N 0.05% (rated power @ 4 ohms)
Output power (RMS, ≤1% THD + N; 2 ohms) 150W RMS x 4 channels
Output power (RMS, ≤1% THD + N; 4 ohms) 100W RMS x 4 channels
Crossover Built-in variable electronic crossover
Signal-to-noise (@ 1W) 85dBA
Frequency Response 10Hz – 100kHz (–3dB)
Maximum power 600W
Inputs RCA low-level preamp inputs
Outputs RCA low-level preamp outputs
Back-lit JBL logo badge & dual LED light bars
Bass boost (+6dB @ 50Hz) Variable bass boost (0 to +12dB @ 50Hz)
Focal SOLID 4
4-channel car amplifier
75 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
CEA-2006 compliant
variable high- and low-pass filters (50-150 Hz, 12 dB/octave)
Class-AB amplifier design
frequency response: 10-60,000 Hz
preamp- and speaker-level inputs
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 25A x 2
11-13/16"W x 2"H x 7-7/8"D
ME ajudem por favor.
O Clarion está bem caro hein, dá pra conseguir por menos de R$800,00 ZERO!
Dos citados eu não ouvi nenhum, mas arriscaria no Clarion.
Cara, nessa faixa de preço, voce consegue um arc audio ks300.4 por R$1200 novo e com garantia de 1 ano. Toca demais mesmo.
Da pra conseguir esse apx 4361 por 600, 650 usado em perfeito estado aqui no fórum. Não fica muito pra tras do arc não, e voce ira economizar um bom dinheiro.
Abraços.
Eu com certeza iria no PPI PC450 dos classificados...
Quase certeza que da um banho nesses amps, ja que esse focal solid é comparado ao Hertz EP4, e o PPI é superior ao EP4, e de quebra vai economizar uma grana !
Tva trocando uma ideia com um Gringo, ele disse que PPI + MB + JL = Sucesso com certeza !
Abraco !
Abraco !
Meu medo é pegar um amp que detalhe muito os tw pois dizem que são bem estridentes, vc acha que esse amp vai cair direitinho no set.
Vi tbm o arc que o tugaria falou, parece ser bom tbm, oque vc tem a dizer?
Obrigado pela paciencia
Abraços.
E ai Tugaria, sera que esse amp não vai valorizar muito os tw do mb, pois dizem que são bem estridentes?
A caracteristica dos PPI é de serem flat, terem um detalhamento muito bom, na minha opiniao cairia como uma luva !
Abraco !
E ai vinicius, tava olhando esse ppi pc450, mas vi que são 4 canais de 50 rms a 4 onhs, sera que não vai ficar muito fraco para o set, levando em conta que quero usar so 1 ampl.
VAlew, abrç
VAlew, abrç
Ficaria nao meu rei, eu tenho mids Mb Quart com um PPI PC250, toca muito bem !
O bridge do PC450 da 200 rms, que de acordo com a JL, seria a faixa de potencia OPTIMUM, para o seu subwoofer !
Esse amp cairia muito bem !
Abraco
Abraco
To pendendo mais para o ARC audio KS300.4 são 4 canias de 90 em 4 onhs.
Oque vc acha desse ampl?
Se vc procurar no DIYMA, achará infos sobre arc e clarion. Mesmo designer. Mesmo projetista.
E ai beraldo, vc ta querendo dizer que são apm parecidos ou ate mesmo iguais???
Abcos
Ambos são designs do Robert Zeff, mas tem alguns detalhes diferentes internamente, além de componentes diferentes.
A Arc Audio é dona da fábrica na Ásia. Alguns designs antigos, ou que não são mais usados, são terceirizados para outras marcas.
Oque vc acha mais interesante para meu SET, esse ARC KS 300.4, Clarion APX4361, JBL 1004, Kenwood excelon xr 4s, ou alguma outra opção?
Obrigado
na R2audio tem o JBL 1004 por 799 se não me engano
Verdade o preço esta otimo, mas ningeum me disse se esse ampl e realmente bom.
Vc conheçe esse ampl?
Valeu
Henrique, como representante da Ianaconi Imports, importador/distribuidor no Brasil da Arc Audio, sou suspeito a dizer. Se possível tente escutar alguns sistemas diferentes, para tirar suas dúvidas. Caso possa investir, posso te garantir que ficará muito satisfeito com o Arc Audio KS300.4.
Que preço ta saindo o KS 300.4? vc tambem vende esses ampl?
Receita de bolo pra acalmar tw mb quart é xtant. Eu já ouvi e recomendo! e tem uns baum e barato nos classificados :legal: !!
Ja haviam me faldo sobre esse amp, onde posso encontar esse amp novo, algum site americano que vende on-line?
ME LA UMA COISA SE EU POR UM PPI OU ARC E ATENUAR O TW EM -3 OU -5, VAI FICAR LEGAL?
Editado por Henrique A3
