Leandrinhom
[FOTOS] Trocando as rodas de uma Ferrari F430 Scuderia
Opening them up!
Some yummy goodness.
Moving my car into place
Carefully lifting the Scuderia. Because my car is lowered they had to drive onto platforms to get it high enough for the lift pads
Look at that sexy rear!
One of the last time I'd be seeing these wheels on my car
These titanium lug bolts are super light!
I couldn't believe how heavy this wheel/tire setup seemed to be
That is a big rotor!
Carefully removing the rear
Stock vs BBS FI
Proper placement
Removing the tire stem
Removing the tire
Some good looking curves there
Look how flat the undersides look
So light Jake could lift it with one arm
Sexy curves ahead
stock vs BBS
TPMS (Tire Pressure Monitoring System) sensor
Rear suspension components
Front suspension components
Flat bottom
Testing the fit
She looks great!
Yummy spokes!
All the parts
Everything in place. On the stock wheel, the wheel weights were on the outside because of minimal clearance. We managed to put the weights on the inside edge this time so it looks better.
Balancing the wheel/tire
Removing the tire
The rear is much harder to remove because of its thickness
Weighing the BBS wheel
21 lbs!!!
Weighing the stock wheel
28 lbs!!!
One side is finished
Love that concave look!
She looks good!
é com as bbs ficou bonito tambem, mas eu achei mais intereçante com as originais.
questao de gosto msm, mas por mim essa ferrari fica bonita até nos cavaletes sem roda alguma :vts
A original é linda... mas a BBS PQP..... mas o que eu mais gostei foi do elevador combinando com a cor do carro... os caras devem ter de várias cores para ficar legal nas fotos huauahuahu
EDIT: Não pude deixar de lembrar do vídeo dos caras montando as rodas 30" a marretada aqui no Barsil....
Editado por Marcelook
Não é nem questão de gosto, nem sempre troca-se as rodas pensando em beleza, e sim em desempenho, pode ter certeza que as rodas mais leves vão influenciar em muito no desempenho do carro... Claro, se as rodas forem bonitas, melhor ainda! ;)
pra mim tb trocou 6 por meia duzia,se for p botar roda q mude pelo menos trocasse a cor da roda, e 12kg a menos em uma carro de rua n vai nem vem,se fosse p trocar as rodas q fosse por umas mais diferentes ou de aro maior
