cenorasound
PowerAcoustik + LT + UXP
Bom tópico tava bagunçado, fotos espalhadas..
Resolvi dar uma organizada:
Como tudo começou:
Pré-Amplificador Gradiente A-175
Algumas das minhas miniaturas
Fontes e o modulo estereo sem a tampa, SÒ O PÒ!!!!Mais ta aguentando!!!
Algum tempo depois:
Editado por cenorasound
Quando a brincadeira começou a ficar SÉRIA:
OQAAAMsiHlUkubZC-epntp7VRTlh7VvRY41QHxYOkx05NUc2s-BSnnNOE61M__EBwmuNOkOBEb6_JljwI4iEyqtrWokAm1T1UKmrcVha3wijjjSVQRN5GvKEHDZY.jpg
OgAAACTyflfz3fHlOWlgLceHIG6lfU8IweWb3BUNNHG3Z6IS9545RF3WP6bn6SCByiObNLhbujoRBtKh6BTnrC8z1XYAm1T1UEmhPEUpuFMF1XJkPoG25fiFT61z.jpg
OgAAAIHHK6rQtWcbkNuZFCT3FqHac9c9dNyqV99zPuJuIuq1DZGTDeOqIlViN8BBSHQN1YOEyTehBgPqyn-K9CiIv20Am1T1UCa9tYl0LqaHJjqGYfXQND3F5OCb.jpg
OgAAAAwNzQKG7TEYSiOSXRH-jAT6E9FNPDb9fMQhGMDEmckbVK7K9jKAALXRMTVslDkxxGWW3gLXJY5834Uj09zDyq8Am1T1UKqHmFsUvc_2h2Ef5WUri_4TQS7I.jpg
OgAAAB4jUlpdo8MKg8bNQsmc3wSc2FcB2kp9q4ZdsAewdygOEdsM6F7tSKOltB3sk0dvoNaF4dK_9IvpmyDiMy6UxngAm1T1UCMq-R99X5YjiTWJRWZ5oRcTpiLX.jpg
OgAAAL6y4Y8qwgUz9Ue5teUQLLiw1nNwOceqAPV0Yb8Ue2TO2j0kkXnd6R7PEboNj-TpcMkKc1RAcdJhsSeo9CT-AFUAm1T1UKYFhkVqumiyfN-S9YhztgqdM7fl.jpg
Ops, de ponta cabeça!!
OgAAAIbY3Ne-nsAoY52G74RCX2ficySeSObNu0nFUoEGyuu7GPZqFHJ490SJLcRBiKsWP0Xnuwz6PefhLQz-PKCHL3kAm1T1UPosqizlckhsiP7cUAvgVLzkNCoq.jpg
Ali atras os 4 Drivers que convenci meu primo tirar do som dele :rolleyes: To quase botando fogo neles... rsrs
OgAAAAgXywy0xRQoJRthYGpas6U-2ZQ1M1HP7_kgn7lmgYBY04u_Q8hX0rxfTZe8zRr0xm86vM68gniLT2RvAJBD8AsAm1T1UFIPR6qs0TqgugJ27fh2SPQ9xH5_.jpg
OgAAAG96JQSUY0rQustahJh3oeaLrLxLaGrQJc4G3Xif-Gf2ZJ7E3Z9Fz3cKbi96O5lZpOi0X1p_-oH_lyfIrEC9WoEAm1T1UOr8-aEFOuAvTXpk_pmFVGN4a0QK.jpg
OgAAAOLSyYwiE0Ajjg5dHlJwLAIgVn_yeYqAyp5ib8GB9NisEJSjD58lbj35ruBQn5fddADF6FHDMWpL03TcnoVSjKYAm1T1UIQS4ovJ2pDnPtS6rCpZl_v0_IPy.jpg
Caixinhas na esquerda!
OgAAAFpu65duLIA8mV9HgTJdIjt6PUUGOAfWGO1z5OFuUtG_OsQOXlSI30ZjQy180VzuLSGcgiESOI48FRUDBoeftu0Am1T1UPkas1qH9fOcTeu--DJEd_zFiePM.jpg
Nova caixa!!
OgAAABL1OWYrnl9hLvkg3XuNjhErXBeXms_AHU81zPyOslRVd9Ctb_dRb_5NGAn4Tmfpm-BTj94PYQu8erUzv9Tk98MAm1T1UPx5QNWG4CI_oXwSSRwwP9wtMADr.jpg
Ja revestida!(Nao reparem na data da foto, esta UM POUCO errada! o-o- )
OgAAAKmIiupdFotXyS-Nb8SOxNZAfsM_ABXZZD4ss6GJngYdjCm1h3R9ypYA_1S0uALr-xqqPO-iKXzHQ9FFltKbns4Am1T1UNbDFe2_viAtVcw2xE6XsKxSUNFa.jpg
É isso ai!!
Proximos ups:Ht600 e LT!!
So me falta tempo pra cortar o mdf!! Fiz um corte com o serrote mesmo.. Ficou uma mer**!Descobri que nao tenho coordenaçao suficiente pra isso!! [^]o-o-
Mas a persistencia é o que leva a perfeição! Com o tempo vou aprendendo!
Quando cortar o mdf certinho posto fotos!!
Abs!!
Po cara valew....
Fazia um tempo ki nao entrava no forum...
Comprei um modulo mono com 2 canais de 240wrms a 2Ohms...
Liguei uma bobina do sub em cada canal (4 ohms cada bobina) só q tah distorcendo o som.
Tentei ligar em BRIDGE mais nao sei se o modulo aceita, deve aceitar pq tah funcionando mais nao tive tempo de da um grau no volume pra ve se distorce...
Uma pergunta...
A caixa DENTRO do meu guarda roupas daria mais subgrave do que fora dele???
Aguardo respostas!!!
Faloww
Po cara valew....
Uma pergunta...
Faloww
sim e naum...pq se vc faiz issu vc concentra todo o grave e sai pela porta do guarda roupa...tipo caixa canhão, mas assim vc mud tbm a freq se sintonia e talz, tudo na base do teste :rolleyes:---se tem msn kra???
Editado por LoboLoko
cara nao use 2 modulos no mesmo sub nao vai da mto certo!
e no quarto nao precisa se mto forte e ja tremo tudoo aqui com um premium tocamdo 90w
ja enche o saco fica tudo tremendo e caindo!!
sim e naum...pq se vc faiz issu vc concentra todo o grave e sai pela porta do guarda roupa...tipo caixa canhão, mas assim vc mud tbm a freq se sintonia e talz, tudo na base do teste ---se tem msn kra???
Entao...jah coloquei td dento do guarda roupas....Nao testei ainda pq o meu cabo RCA pra P2 jah era, e o dvd tah muito longe da caxa!!!Amanha vo tenta faze uma super gambiarra i vejo se adianta alguma coisa!!!
Depois posto uns videos mais novos!!!
Valew!!
Cara valew pela dica mas jah comprei um modulo!!!(Silver Line MONO 2x240wrms a 2Ohms)
Oww poem mais potencia no sew Bravox mano!!!!
Aqui num sei se chega a 260wrms mais dá um som bem fortinho!!!
Pena ki minha caixa tah peidando pq tá vazando ar pelo buraco do fio e pelos parafusos do sub, jah enxi de silicone mais num deu muito certo!!!
Será ki nao vai da pau no meu modulo nao???Nao sei se ele aceita BRIDGE...Fiz a ligaçao nele e tah tocando!!!
Sera ki mais pra frente nao vai da algum problema???
MSN: vicasrs@hotmail.com
Fala galera, melhoro bastante o subgrave depois que eu coloquei a caixa no guarda roupas!!!
O sub nao distorceu mais depois do BRIDGE, to passando mal aki no quarto!!!Ateh eu assustei com o som
TAH MUITOO IGNORANTE!!!!Vamo ve ateh quando vai dura!!!
Ta tocando Bossy - Kelis, o vizinho ateh desligo o som dele!!!!
:P :P [¨]
Valew pela força ai!!!
Fala galera...
Andei lendo uns topicos aqui no forum e resolvi colocar meu sub com o imã pra fora....
Nao tava levando muita fé que ia mudar alguma coisa....Mais mudou MUITO!!!!
Sempre achei que essa minha caixa era pequena pro sub!!!!
Tenho q arrumar um jeito de iluminar dentro do guarda ropas...Colocar uns leds sei la pq nao da pra filmar!!!
Tava pensando em "grudar" os leds na parte de ferro do sub virados pro cone...Nao queria nada de muito LUMINOSO!!!
Pensei em uma luz negra que tenho aqui mais acho q nao ia adiantar muito!!!!
Bom quando resolver o que eu ponho eu tiro umas fotos pra vcs!!!
Faloww!!!
Em paralelo com o sub???
Quantos vc liga???
Eu ligue UM led hj junto com o sub(em serie).....Tocando baxinho foi di boa comecei aumenta o volume....Deu mer**!!!!
O led era VERDE i viro VERMELHO!!! <_<
Po cara o som em geral ta bem fortinho viu!!!
Ta com o A-175 como pré-amplificador, ai nas saidas dele liguei o modulo do sub e o outro modulo estereo....Desliguei corneta e tweeter pra nao fica muita gritaria!!!
Nao posso aumenta muito pq começa faze uns barulho horrivel de coisa vibrando!!!
Gostei muito desse modulo por nao ser de marca conhecida, deixei o som a tarde inteira ligado meio "alto" e o modulo nem pensou em esquentar....Talvez pq nao estou utilizando toda a potencia dele, mais jah tah MUITOO BOMM!!
Vo tenta liga o led em PARALELO e depois de falo q q deu!!!
Valeuuu
Quantos vc liga???
Valeuuu
hahaah serie nao tem que se paralelo mais com mais menos com menos eu uso a anos e nunca queimo um led tbm só uso um mesmo hahah mas é so faze assim da pra liga bastante!!
o meu cl450 tbm uso a 2ohms toca a tarde intera e mal esquenta!!
Po cara nao tive oportunidade de liga o som hj...Nao parei em casa...
Entao o modulo ta a 4ohms....Uma bobina do sub tem 130wrms e é de 4ohms.... se fosse 2ohms ia da mer** pk o modulo iria manda o dobro de potencia que as bobinas aguentam....ai liguei assim!!!
Bomm Valeuuu!!!!
Falow
Fala galera...
O Rodrigorlc me deu uma ideia de ligar LEDS no sub a un tempo atras...
Entao, botei essa ideia pra frente!!!
Primeiro liguei DOIS leds normais de 3mm em paralelo com o sub e no primeiro grave já queimaram....Depois coloquei um led de 10mm e tambem queimou...
Entao lembrei que há algum tempo meu pai fez uma placa para iluminar o aquario com Leds, entao fui ver como ele tinhe feito ele usou um diodo e um resistor (acho que é esse o nome :unsure: ) aii hoje tentei fazer essa ligaçao e consegui....
Pelo menos até agora eles nao queimaram [¨] !!!
Só que nao sei ONDE coloco os Leds, por enquanto ele esta preso no Duto da caixa (por dentro).
Estou terminando de fazer as soldas e tiro umas fotos dele ligado!!
(desculpem ai pelo TEXTO)
Fala galera..
Bom acho que estou ficando louco!!!
Hoje liguei meu som nem na metade do volume e deixei ele ligado...
De perto nao sentia nem ouvia subgrave nenhum mais quando desci la na garagem que é na frente de casa(moro em sobrado) eu senti o subgrave, nao tao forte pois o som estava baixo...
Deveria acontecer isso?
Por que de longe eu sinto/escuto o subgrave e de perto so escuto vento saindo do duto??
EDIT:Em outras palavras, isso é normal ou eu que to ficando louco?? :pirou::blink:
Faloww
é normal aqui tbm ,noss sentadinho no pc bate normal ai eu vo perto da porta noss ta forte o subgrave,isso depende de onde ta a caixa né do lado de parede ou coisa que atrapalhe a dissipaçao melhor do grave!!
a se é loko de liga os LEDS sem resistor hahahahahhaha ,só da se for em 3v a 9v . em 12v só com resistor de uns 470ohms pelo menos!!
kkk é tive que aprende isso na marra!!!
O primeiro ki eu liguei ficou até quente!!!
To devendo as fotos ainda!!!
flw
Edit:eu liguei ele no modulo!!! Ai acende conforme as batidas!!!
kkkkk
Pois é....
Gravaçao com celular é fo**...
Minha camera caiu e quebro a uns tempos atras...(BASTANTE TEMPO)E nao fui atras de otra e nem mandei arrumar....
Mais eu ainda faço um video decente!!!!
:rolleyes:
Ai galera umas fotinhos pra vcs!!!
Tá meio bagunçado pq tava colocando a luz negra, qdo tive td certo tiro mais fotos!!!
Nao tirei foto dos outros modulos pq tao escondidos, ai fica dificil...
EDIT:A corneta e o tweeter estao desligados!!! To usando duas caixinhas com um MidBass e um MidRange.
FLWW
ta showzinho o sistema ,a luz negra no sub deu um Chan!
a minha é na parede ,era né pq semana passada eu quebrei ela hehehehe
e o lance das fontes vc liga um cabo na tomada auxiliar da outra e dessa na outra e um só cabo vai
pra tomada real??
é isso!!??
