Dtay
Aston Martin Dbs
Tenho que confessar... os Porsches estavam perfeitos, as ferraris lindas as Mclarens rústicas mas o DBS ..... como eu queria ver um destes ao vivo ...sou fã de carterinha dos Sushis Cars... mas este me tira o sono também ! hauah !
General specifications
Record last updated 08 / 27 / 2007
Country of origin Great Britain
Numbers built N/A
Year of introduction 2007
Engine
Engine 60º V 12
Engine Location Front , longitudinally mounted
Configuration alloy block and head
Displacement 5.935 liter / 362.2 cu in
Bore / Stroke 89.0 mm (3.5 in) / 79.5 mm (3.1 in)
Compression ratio 10.9:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body aluminum monocoque
Front suspension double wishbones, anti-dive geometry, coil springs over dampers, anti-roll bar
Rear suspension double wishbones, coil springs over dampers, anti-roll bar
Steering rack-and-pinion, power assisted, speed sensitive
Brakes carbon ceramic discs, all-round, ABS
Gearbox 6 speed Manual
Drive Rear wheel drive
Dimensions
Weight 1695 kilo / 3736.8 lbs
Length / Width / Height 4721 mm (185.9 in) / 1905 mm (75 in) / 1280 mm (50.4 in)
Wheelbase / Track (fr/r) 2740 mm (107.9 in) / N/A / N/A
Performance figures
Power 510 bhp / 380 KW @ 6500 rpm
Torque 570 Nm / 420 ft lbs @ 5750 rpm
BHP/Liter 86 bhp / liter
Power to weight ratio 0.3 bhp / kg
Top Speed 302 km/h / 188 mph
0-60 mph Acceleration 4.2 s
Abs !
