179 -
Tudo que Motta Slp postou
[Vendido] Subwoofer JL 10w3v3 4ohm - - Fechar
' Motta Slp' respondeu tópico de ' Motta Slp' em Classificados SUBWOOFERS, woofers, CAIXAS
MP repondida! -
[VENDO] Rockford Fosgate Punch 225.2 e MB Quart PAB 4100
' Motta Slp' respondeu tópico de ' Motta Slp' em Classificados AMPLIFICADORES e módulos
Up! -
sobe! -
[VENDIDO] Player JVC KW-R900BT 2 din - Fechar
' Motta Slp' postou um tópico no fórum em Classificados PLAYERS, Head Unit (HU), CD-players, DVD-players...
Player JVC KW-R900BT 2 din - vendido Aparencia 9,5/10 Funcionamento 10/10 https://produto.mercadolivre.com.br/MLB-1029747916-player-jvc-kw-r900bt-sq-_JM Player automotivo 2 din em excelente estado para som de qualidade! - ajustes e cortes de frequências (crossover) - bluetooth - T.A - 3 saídas 5v banhadas a ouro - equalizador de 5 bandas - compatibilidade com iphone, ipod e dispositivos Android. General Features: JVC KW-R900BT In-dash Receiver 4-line Dot-Matrix text display A2DP audio streaming with compatible Bluetooth phone Integrated Pandora internet radio control with attached iPhone 2-location Variable Color Illumination with 30,000 color options CEA-2006 compliant amplifier Power Output: Peak: 50 watts x 4 channels RMS: 20 watts x 4 channels Remote control included CD text information display 12 or 24 hours digital clock display MP3 ID3 Tag Display (Title/Artist/Album) Playback and Audio Features: CD/CD-R/RW, MP3/WMA Playback AM/FM tuner with 18FM/12AM presets 5-band parametric equalizer with 9 selectable tone curves (5 Preset, 4 User) 24bit DAC enhances MP3/WMA playback Low Pass and High Pass crossover filter control Separate subwoofer level control Expandability Options: 3 Sets of 5V preamp outputs (front, rear and subwoofer) SIRIUS or XM Satellite Radio Ready: SIRIUS Radio Package or XM Radio Package and subscription required and sold separately Bluetooth technology supports hands-free calling with a compatible Bluetooth phone iPod and iPhone Ready: Standard USB-to-iPod Cable compatible Plays music stored on the iPhone 5 via Apple’s supplied Lightning-to-USB cable 3.5mm Front Auxiliary Input Front and Rear USB Inputs Steering Wheel Control Ready: PAC SWI-JACKv1 or the Axxess ASWC required and sold separately Bluetooth Features: Bluetooth version 2.1 +EDR certified Supports A2DP audio streaming Works with most Bluetooth enabled cell phones Includes an external wired microphone for clear, distortion-free talking -
' Motta Slp' postou um tópico no fórum em Classificados AMPLIFICADORES e módulos
Amplificardor MB Quart Premium PAB 4100 4 canais R$ 600 Funcionamento 8/10 Aparencia 8/10 https://produto.mercadolivre.com.br/MLB-1029734557-amplificardor-mb-quart-premium-pab-4100-4-canais-_JM Amplicador em bom estado sem as abas. Foi feito um pequeno reparo na chave manual de seleção de 2ch/4ch. Um terminal está com leve oxidação externa mas não interfere no funcionamento. 4-Channel Amplifier Focused mass aluminium heat sink RMS Power Rating: 4 ohms: 100 watts x 4 chan. 2 ohms: 150 watts x 4 chan. Bridged, 4 ohms: 300 watts x 2 chan. MOSFET power supply Ultra-flexible and variable adjustable active crossover network Vario bass equalizer circuit up to +18 dB 24 dB subsonic filter Full range preamp outputs for easy daisy chaining of additional amplifiers MB QUART-Logo with illuminated red rectangle Wire concealing detachable end panels Frequency Response (-3 dB) : 10 Hz - 30 kHz Damping Factor: 200 Signal To Noise Ratio: >95 dB THD: 0.05% Channel Separation: >70 dB Input Signal: 0.2 - 6.0 V Crossover S/W: LP.BP/Full/HP Variable Hi-pass / Subsonic Filter: 10 ~ 150 Hz Variable Low-Pass (mono 24 dB): 30 ~ 150 Hz Full range Bass Boost at 45 Hz: 1 ~ 9 dB Dimensions: 18" L x 10.4" W x 2.25" H Rockford Fosgate Punch 225.2 Old School Trans.ana (com abas). Vendido Funcionamento 10/10 Aparencia 9/10 https://produto.mercadolivre.com.br/MLB-1029728877-rockford-fosgate-punch-2252-old-school-transana-_JM Ótimo estado de conservação. Quem conhece esse amplificador sabe a qualidade e força para tocar mono. Frete a combinar ou retirada em mão em jundiaí-sp. Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts Mono into a 4Ω Load 690 Watts Per channel into a 2Ω Load 345 Watts Per channel into a 4Ω Load 220 Watts Continuous Power Rating (Competition Standard) - Measured at 13.8 Battery Volts RMS continuous power per channel from 20 to 20,000 Hz with less than 0.05% Total Harmonic Distortion (THD) both channels driven into a 4Ω load 112.5 Watts both channels driven into a 2Ω load 225 Watts continuous power mono into a 4Ω load 450 Watts Signal-to-Noise Ratio > 100dB A-weighted Crossover Slope 12dB/octave Butterworth Factory Default Crossover Frequency 80Hz adjustable (.047µf) Frequency Response 20Hz to 20kHz±0.5dB Bandwidth 10Hz to 200kHz±3dB Damping Factor @ 4Ω (at output connector ) >200 Slew Rate 30 Volts µs IM Distortion (IHF) <0.05% Source Unit Compatibility (+15dB gain overlap) 17V max. Input Sensitivity (+0dB gain overlap) Variable from 150mV to 3V Protection NOMAD - Internal analog-computer output protection circuitry limits power in case of overload. Thermal switch shuts down the amplifier in case of overheating. Battery Fusing Rates (External to Amplifier) 20 amps 30 amps 40 amps 50 amps Fuse Type ATC ATC ATC AGU Equalization Bass: +18dB Maximum at 45Hz Treble: +12dB Maximum at 20kHz Input Impedance 20k ohms -
Up -
Up -
Up -
Up! -
up -
Sobe! -
UP! -
Up com preço reduzido! -
Up! -
' Motta Slp' postou um tópico no fórum em Classificados SUBWOOFERS, woofers, CAIXAS
Vendido para user geovanesantos33 Subwoofer JL 10w3v3-4 - R$ 1150,00 R$999,00 Funcionamento 10/10 Aparencia 10/10 Vendo subwoofer JL 10w3v3 bobina simples de 4ohms. Nunca foi usado. Esta perfeito no caixa. Retirada em mãos (Jundiai-SP) ou rachamos o frete. Tela original 10' - R$ 150,00 Funcionamento 10/10 Aparencia 10/10 Vendo tela original da JL para subs de 10'. Retirada em mãos (Jundiai-SP) ou rachamos o frete. -
COMPRADO obrigado pelo o espaço
' Motta Slp' respondeu tópico de ' cianureto' em Classificados CABOS, rca, speaker, força e óticos
+1 procurando !! -
Ajuda DVD/CD player 2 din SQ entrada
' Motta Slp' respondeu tópico de ' Motta Slp' em [QUALIDADE] Som de qualidade
JVC KW-R900BT comprado. Assim que instalar posto os reviews... -
Esse já esta fora da faixa... $450 ... mas obrigado pela dica O JVC KW-R900BT tem BT ta $170 ... acho que é o mais completo dos 3 porem sem DVD =/ -
' Motta Slp' postou um tópico no fórum em [QUALIDADE] Som de qualidade
Pessoal, bom dia! Estou buscando um DVD ou CD 2 din que entregue um minimo de decência em qualidade de audio. Não precisa ter muitos cortes nem ajustes. Somente o básico com qualidade. Vou trazer da gringa e meu budget é 170˜190 doletas. Meu sistema é bem simples com ampli 4 canais kit duas vias e sub. Pretendo no futuro comprar um ampli so para mono e deixar o atual para stereo. Qual das opções voces escolheriam ? DVD - Kenwood DDX271 DVD - JVC KW-V11 CD - JVC KW-R900BT Abraço -
Instalador São José dos Campos ou Zona Oeste SP
Boa noite galera! Procuro algum lugar confiável para instalar meu set e fazer a caixa do sub em São José dos Campos ou na Zona Oeste de São Paulo. Conheço ótimos lugares em SP para instalaçao de sets hi-fi mas que não justificam o preço para o meu set de entrada. Antes de roubarem meu set, havia instalado no MA Som do metal mushida (Marcos) mas infelizmente a loja fechou. Alguem conhece algum lugar para me indicar? Set a ser instalado HU Clarion Cz702 Kit 2 vias Beyma Amplificador Mb Quart PAB4100 Sub JL 10W3v3-4 Dutada 36L @32Hz RCA KnuKonceptz Twisted 4 Channel Smoke Obrigado pela ajuda! -
[Encerrado] Sub 10" e 2ways - SQ EUA
Pessoal, Decido kit duas vias polk audio $115 e Sub JL 10w1v3 $140 ! Obrigado pela ajuda de todos! -
Minha dica é sempre contemplar no orçamento o custo com os cabos (alimentação e RCA) pois fazem grande diferença no resultado do conjunto. É de grande importancia que a qualidade e custo dos cabos sejam coerentes com o conjunto de equipamentos em geral. Muitos users que estão entrando no SQ(PL) esquecem ou não priorizam esses itens e acabam utilizando produtos de baixissima qualidade prejudicando muito o conjunto.
Vlw pela dica... decidido o sub vai ser JL 10w1v3 ... Vlw pela dica... Estou considerando os kits de entrada ... mas ainda estou vendo qual tem o melhor custo x beneficio .. queria gastar até $150 mas se for muito melhor aceito até $200 -
Achei por $150 o 10w1v3 ... estou quase decidindo por ele... Quanto ao kit duas vias pensei em: Ininity Kappa 60.11 $190 Morel Maximo $140 Polk Audio DB 6501 $120 Diamond D364.5 $170 MB Quart ONX216 $150 Rockford Fosgate P165 $100 Alpine SPR60c $140 JL C2 $160 DSL Performance $180 SoundStream RC $130
