Xplod
QUEM é NAKAMICHI ou AZULÂO 19XX
Die Cast Zinc Faceplate
Heavy Machined Volume Knob
Vacuum Fluorescent Display (VFD) with Independent Power Supply
Copper-Plated Chassis
3-Layer Nickel Finish CD Mechanism
Glass Epoxy 4-Layer PC Board
Burr-Brown Volume Circuit with 0.5 dB Resolution
Zero Cross Detection Muting
24-Bit Burr-Brown D/A Converter
96 kHz Sampling Frequency Upconversion
4 DAC Differential Configuration
8x FIR Oversampling Digital Filter
Analog Devices High-Speed Operational Amps
48 kHz Frequency Response
96 kHz AKM Digital Signal Processor (DSP)
Digital Time Alignment with 0.7cm Steps
0-500cm Adjustment for Each Channel
4-Way Digital Crossover
Variable Crossover Frequency, Slope, & Phase
Fully Parametric 5-Band Equalizer
8-Channel 4-Volt Preamp Outputs
Silver-Plated Conductors
6N Oxygen Free Copper (OFC)
Gold-Plated, Metal Barrel RCA Connectors
Outboard DC/DC Converter Power Supply
Black Finish Copper Chassis
Die Cast Aluminum Casing
Custom Silmic II Filter Capacitors
Toroidal Choke Coils
Gold-Plated Power Terminals
CD-R & CD-RW Playback
Magi-Tune AM/FM Tuner with 24 Station Presets
CeNET Control for CD Changer, TV Tuner, or Sirius Satellite Tuner
Dual Rear Analog Auxiliary Inputs
Optical (S/PDIF) Digital Input & Output
Preamp Only (requires outboard amplifiers)
Included Wireless Remote Control
Step-Up Features From the Clarion DXZ945MP (and pretty much any other head unit)
Burr-Brown D/A Converters
0.7cm Step Digital Time Alignment
5-Band Parametric Equalizer
0.5 dB Burr-Brown Volume Circuit
Optical Digital Input & Output
CD Player Specifications
Anti Theft: None
Preamp Outputs: 4 sets
Preamp Output Voltage: 4 volts
CD Changer Controls: Yes
Remote Control: Yes
RMS Power: None
Peak Power: None
CD Frequency Response: 5-48,000 Hz
CD Signal-to-Noise Ratio: 100 dB ity: 9 dBf
Amp Total Harmonic Distortion: n/a
É padrão também mais não é melhor nem pior ......
Você já ouviu?! :huh:
Números não dizem nada, quando o assunto é hi-fi / hi-end.
Não vai dizer que vc já passou o player lá onde o sol não bate???
Pobre DRZ... :lol:
O Fábio Ariza!!!!!!!! Cade o Fábio??????????????? Leva o Kleber para passear de PT Cruizer turbo [] :lol: :vts
Gostaria que me falassem de Qual aparelho Descrevo pois Tenho Certeza que nem nakamichi nem azulão ala 19xx tem esse padrão
O.O
Deixe ver... O que eu ganho se acertar?
Posso pedir ajuda dos universitários???
Senti cheio da Maria Joana no ar... Será que o tópico tá meio enfumaçado? Será? Será? Marofaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!
Fumô fáaacil
Eu acho q descrição é, na realidade, uma lombra torta...
Ésto non equeziste!!!!!!
Já que vcs são os fodões do som me digam o que acham dos JBL 400GTI e 500GTI :mac1
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Cuidado... specs não significam nada em termos de sonoridade...
Se fosse pegar meu player, ia ficar atrás até dos pioneers de entrada... É um playerzinho com DAC de 1 bit, feito em 1995, 2 pares de RCA, sem saída pra sub, sem crossover, display laranja iluminado por lâmpada, sem MP3... Nada mais. Mas é um Nakamichi CD7 que toca mais que a vasta maioria dos players... aí a porta torce o rabo...
Specs são apenas specs... Aliás, pelas specs, um pioneer 860MP estaria brigando feio aí no meio tb.
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Numeros não mais precisão sim .....
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Sem falar que esse é o carro-chefe da Clarion... marca conhecida por bons players. O antecessor do DRZ, DRX, fez muito sucesso. Ainda por cima está na categoria Hi-end. Ruim não poderia ser..... A Kenwood tb tem seu carro-chefe no Japão, que ruim tb não deve ser. Assim como a Pioneer, Alpine...
Pobre DRZ...  :lol:
Guijs, vc não vale o papel higiênico ultra super hiper blaster macio plus advanced que usa...
Te odeio. :lol:
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Compre então pelas luizinhas coloridas sei lá de que cor e oussa som de vitrola...... :banghead
O.O
Fumô fáaacil
Achar por achar, eu acho q devem ser legais... MAS como nunca ouvi os bichos tocando, não posso te dizer nada... afinal, specs não dizem nada...
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Tinha pensado em tons de ciano... o que achas? :P
Aliás, vou te poupar do próximo post do Dereg... Ouça é com Ç... ;)
Vitrolas não têm extensão nos agudos e, muito menos, time alignment. Não gosto delas.
Anti Theft: None
Remote Control: Yes
RMS Power: None
Peak Power: None
Se números não, mas precisão sim...
Acho que isso é evidentemente subjetivista, não?
Logo, números apontados não são considerados...
Pelos relatos de fontes confiáveis, com ouvidos bem treinados, é que eu posso ter uma idéia do que é bom mesmo.
Eu nunca escutei nenhum desses players, o mais próximo foi um x879.
Também não usam burr brown... logo, não podem ser boas...
Se bem que tem umas da era valvulada... os valvulados tão na moda... será que cabe um vitrolão no carro?
Ah!
Não aguentei ler tudo!
Mas...
O QUE VOCÊ QUER COM ESSE TÓPICOZINHO DE mer** EINH SEU FILHO DA PUTA DO ca*****?
VOCÊ VAI SE FODER!
EU QUERO QUEBRAR A SUA CARA!
QUE RAIVA! QUE RAAAAAIVA!
CE TÁ QUERENDO ME IRRITAR?
É ISSO?
VOCÊ NÃO VALE NADA! NAAADA! NAAAAADA!
HAHAHAHAHAHAHAHAHAHAHHAHAHHAHAHAHAHHAHAHAH
:lol::lol::lol::lol:
xilikeeenta!!!
Dereg, a xilikenta da autosom!
kkkk
[ ]`z
Ah!
Mas...
VOCÊ VAI SE FODER!
É ISSO?
EEEEPPAAAAAAAA
BICHA NÃO!!!!!
Eu sou uma quase... Rebecka Pidgeon
Ah!
Mas...
VOCÊ VAI SE FODER!
É ISSO?
EEEEPPAAAAAAAA
BICHA NÃO!!!!!
Acesse: www.mundocanibal.com.br
Depois: Pequeno Delito com Donizildo
Depois: Cartão MerdCard
Uahahahahahaha!
Ô XPLOD, antes que vc XPLODA, todo mundo aqui tá de brincadeira... pelo tipo do seu tópico, só podia descambar pra esse lado mesmo...
Desculpe se te ferimos por dentro... na próxima a gente promete dar uma besuntada antes... :lol:
Ah!
Mas...
VOCÊ VAI SE FODER!
É ISSO?
Dereg desceu do salto e rodou a baiana!!!!
Eita, deixa eu me esconder, pq vai voar purpurina pra todo lado agora!
:lol: :lol: :lol:
Cadê o supositório de maracujá do dereg???????????????
Kleber, o kra deve estar com ódio de vc... tipo o tiago.
Aliás, corram pra stereo, o kit Eclipse está em promoção: de R$9.164 por R$4.990!!!
Mas... o que esse cara quer com essa po*** desse tópico do ca*****?
Einh?
Ele só quer ser seu amiguinho...
amigo... amigo... isso... tá vendo? Ele não morde...
PS: Acho q poucas vezes ri tanto num tópico "espontâneo"...
