Ir para conteĂşdo
RobĂ´Autoforum
[Nakamichi]Small Size, Big Upgrade | Nakamichi NDSE100A 6-Channel DSP Amplifier 🎶🔊 Want to transform your factory car audio witho...
785280362_2277445226409985_5702383167997614025_n.jpg?stp=dst-jpg_p565x565_tt6&_nc_cat=111&ccb=1-7&_nc_sid=3a9e82&_nc_ohc=Ah5I5w4FrwgQ7kNvwHb3M6Y&_nc_oc=AdrhxnMP6NqrmgcwfrdsIFMvUvt_288H7gPiaFDUqC0q3O4eBeRPNxNvBW7SzSrBuHc&_nc_zt=23&_nc_ht=scontent-xxc1-1.xx&_nc_gid=dwFBd4FkJ4wT6woQgypkTg&_nc_ss=79289&oh=00_AQEPE3qo9Shi2tw_3PJXj9J3dnnGjtbBR7LkKKX3_y0WYg&oe=6A977E37
Want to transform your factory car audio without tearing your car apart? The NDSE100A makes it possible – no door panel removal, no wire cutting, just pure, professional-grade sound that breathes new life into every track.
🔥 Why Choose NDSE100A:
⚡ Compact Powerhouse
At just 173×122×43mm, it hides almost anywhere. Built‑in 4‑channel amplifier delivers 4×25W RMS and 4×50W Max Power – small footprint, serious output.
🎛️ 6‑Channel Flexibility
◾ 4‑channel high‑level inputs – direct connection to factory head units, no LOC needed
◾ 6‑channel low‑level (RCA) outputs – expand with external amps and subwoofers
◾ 4‑channel high‑level outputs – drive factory or upgraded speakers directly
🎚️ 31‑Band EQ, Your Sound, Your Rules
Independent 31‑band EQ per channel with 6 user‑definable presets. Vocals, rock, classical – switch instantly to match your mood. Plus independent time alignment, active crossovers, and phase adjustment for a true soundstage.
📱 Smart Control, Total Command
Control via mobile app, PC tuning software, or optional LCD panel. Built‑in Bluetooth 5.1 and USB lossless music playback expand your source options effortlessly. Power‑on delay protection ensures safe startup.
From factory systems to full custom builds, the NDSE100A delivers professional DSP power in a compact package – total sound control, right in your hands.
🔗 Learn more:www.nakamichicaraudio.com
#Nakamichi #NDSE100A #DSPAmplifier #CarAudio #SoundUpgrade #31BandEQ #PlugAndPlay #NakamichiCarAudio
O fĂłrum para os maniacos por som automotivo e automĂłveis
