[SMD]Free Bass Beats Tested on a Real Sound System 6 12" Subs
visit: http://www.stevemeadedesigns.com
https://www.youtube.com/channel/UCAn7KfxuoxUur8dP-lFCjdA/join
Don t forget to check out the entire build start to finish here with chapters https://youtu.be/DSQmyD61Ak4 si qTcMlf84z8s5GZzm
Over the years I have always had issues using copyrighted music in my videos. I always have to chop everything up during editing so I don t get busted even though most of the time the bass drowns out the song itself. Youtube Studio has always offered in the past tons of copyright free tracks for creators such as myself to use. I usually download their tracks that fit whatever I am doing. Some are more suited for Intro s some for outro s and some for time lapse. Knowing me they are always bass heavy. I usually kinda like them also or they wouldn t even be on my channel. Yesterday it dawned on me to put these tracks on a USB and take them out to the car and try them. I was NOT disappointed This is video 1 of several I will upload and review. It was really FUN to actually bump the sh t out of these songs I have used over the years. Try them if you can find them Also don t forget to watch this video with a decent sound system that has a subwoofer if you can. Or a nice set of headphones. Watching with your phone might not give you the same experience. It is truly hard at times to hear where the REAL track stops and my system recording the actual playback starts. Check it out and thanks for watching though if you did
System consists of:
4 D amore Engineering qA seriesq Super High End Class A/AB 1500w Amplifiers 2 4 channels 2 2 channels doing over 3kw each and backed up by XS Power Titan 8 Lithium 14v Batteries charging at 16.4v pushed by a Mechman 400a alternator. A lithium 12v battery up front for the actual vehicle which get s it s juice via a custom voltage step-down box i made see previous video s . B2 Audio 3 ways 2 set s in each door on the highs in custom made door pods and 6 B2 Audio 12q subs on the lows in an all acrylic slot ported enclosure. Plenty of 2/0 and even 4/0 power wire from Skyhigh car audio delivering the massive power needed to push these amplifiers.
Every single thing i have done to this Caddy probably missed some stuff
NavTV Factory integration - http://www.navtv.com
For info on the b2Audio Rampage subwoofers and qManiq 3 ways visit http://www.b2audio.com
For info on my amps visit: https://damoreengineering.com/collect...
Processor by Audiocontrol http://www.audiocontrol.com
Batteries Step down modules http://www.4xspower.com
Alternator http://www.mechman.com
Wire http://www.skyhighcaraudio.com
Second Skin Sound Deadner http://www.secondskinaudio.com
How is it 1000hp read below.
Engine Parts List might be missing a few items
Armageddon L861000 Shortblock
Forged Pistons Rods and Crank
New Main and Rod Bearings
Total Seal Ring Set
ARP Mainstuds
Armageddon Street Fighter Cam Package
LT1 Camshaft lobe lash cap
Comp Cams Cam Phaser Limiter
Pushrods
Pac racing polished dual valve springs
PRC Viton valve seals
Titanium retainers hardened spring seats
DOD Delete Kit
Balanced and Blueprinted
Upgraded Fuel Pumps Engine and Tank
Upgraded Injectors
Ceramic Spark Plug Wires
Dual Armageddon Catch Cans
Kooks Headers / Midpipe
Kooks High Flow Cats
QTP Electric Cutouts
Magnaflow 3.5q Stainless Exhaust
Armageddon Coolent Reservoir
Fully built Tranny / DaP Torque converter Triple lock 2400 Stall
.....and more
28q Forgiato 3 Piece Wheels
Lexani 295/25/28 Tires
Lowering kit: 1.5q Front / 3q Rear Slightly modded for more drop
Wilwood TX6R / Aero4 Big Brake Kit
Custom Powdercoat White
Front: 6 Piston Caliper / 16q Rotor
Rear: 4 Piston Caliper / 14.25q Rotor
Steel Braided Lines
Blacked out chrome trim
cadillac sound bass
For Business Inquiries: smdbizinq gmail.com
