[Nakamichi]Nakamichi NBS210A 10" Active Subwoofer Box SPECIFICATIONS N-Power: 100W Peak Power: 1000W Distortion(THD): <0.1%... Sign...
186080024_3075678602668234_4801927299486455244_n.jpg?_nc_cat=110&ccb=1-3&_nc_sid=8024bb&_nc_ohc=LikrkJBJzOUAX_mpfgl&_nc_ht=scontent-sjc3-1.xx&tp=6&oh=c00a7dc32bc6301dedaafde99c0ac17b&oe=60C23EAB
Nakamichi NBS210A 10" Active Subwoofer Box SPECIFICATIONS N-Power: 100W Peak Power: 1000W Distortion(THD): <0.1%... Signal To Noise Ratio: >90dB Frequency Response: 40Hz -160Hz Input Sensitivity:0.5 - 280mV Subsonic Filter: 20Hz(Fixed) Fuse Rating: 20A Unit Dimension: 300x275x318mm Net Weight: Approx. 7.2kg NAKAMICHI NBX210A 10" DUAL ACTIVE SUBWOOFER BOX Woofer: 10" Power: 120W Peak Power: 1200W Impedance: 2 ohm Frequency Response: 50Hz-1.3kHz Sensitivity(SPL/1W/1m): 83±2dB Subwoofer Magnet: 17.6 oz Power Supply Voltage: 14.4V(10.5V~16V) Unit Dimensions: 820x355x150mm
