rdgspc
AJUDAA ! quantos amperes tem essa bateria?
Galera preciso muito de uma força,
preciso saber quantos amperes tem a seguinte bateria.
o cara diz que é 250a mas nao tem isso marcado em lugar algum..
Eaton 12V 500W Battery
PWHR12500W4FR
Features
• Designed for high power density applications
• Small volume, lightweight discharge efficiency
• Can be used for more than 260 cycles at 100% discharge in
cycle service
• UL-recognized components under UL924 and certified by
ISO 9001 and ISO 14001
• Built to comply with IEC 896-2, DIN 473534 BS 6290 OT4,
Eurobat
• Exclusive three-year battery parts coverage and one-year battery
labor coverage
CONSTANT POWER DISCHARGE CHARACTERISTICS: WATTS/CELL (77°F, 25°C)
End point volts/cell 5 min 7.5 min 10 min 15 min 20 min 30 min 40 min 50 min 60 min 90 min
1.85V 561 480 433 367 327 261 220 188 163 116
1.80V 638 557 492 416 356 276 232 198 171 122
1.75V 708 625 548 458 385 290 244 206 178 126
1.70V 773 685 602 489 404 305 251 210 181 127
1.67V 813 717 632 503 415 312 253 213 182 128
1.60V 879 782 695 530 432 325 260 215 185 131
All mentioned values are average values per battery per cell.
Tolerance: X <6 min (+15% ~ -15%), 6 min X <10 min (+12%~ -12%), 10 min X <60 min (+8% ~ -8%), X 60 min (+5% ~ -5%)
DIMENSIONS [H x W x D, in (mm)]
o o
Eaton, Powerware and PowerChain
Management are trade names, trademarks,
and/or service marks of Eaton Corporation
or its subsidiaries and affiliates. All other
trademarks are the property of their respective
owners.
© 2008 Eaton Corporation
All Rights Reserved
Printed in USA
BAT04FXA
October 2008
UNITED STATES
8609 Six Forks Road
Raleigh, NC 27615 U.S.A.
Toll Free: 1.800.356.5794
or 919.872.3020
www.powerware.com/batteries
CANADA
Ontario: 416.798.0112
Toll free: 1.800.461.9166
LATIN AMERICA
Argentina: 54.11.4124.4000
Brazil: 55.11.3616.8500
México: 52.55.9000.5252
Portugal: 55.11.3616.8500
EUROPE/MIDDLE EAST/AFRICA
Denmark: 45.3686.7910
Finland: 358.94.52.661
France: 33.1.6012.7400
Germany: 49.0.7841.604.0
Italy: 39.02.66.04.05.40
Norway: 47.23.03.65.50
Sweden: 46.8.598.940.00
United Kingdom: 44.1753.608.700
ASIA PACIFIC
Australia: 61.2.9693.9366
New Zealand: 64.0.3.343.3314
China: 86.21.6361.5599
HK/Korea/Taiwan: 852.2745.6682
India: 91.11.2649.9414 to 18
Singapore/SEA: 65.6825.1668
Technical specifications
Cells per unit 6
Voltage per unit 12
Capacity 500W @ 15-minute rate to 1.67V per cell @
77°F (25°C)
Weight Approximately 100.75 lb (45.7 kg)
Maximum 800A (5 sec)
discharge current
Internal Approximately 3.7 mΩ
resistance
Operating Discharge: 5°F~122°F (-15°C~50°C)
temperature Charge: 5°F~104°F (-15°C~40°C)
range Storage: 5°F~104°F (-15°C~40°C)
Nominal 77°F ± 5°F (25°C ± 3°C)
operating
temperature range
Float charging 13.5 to 13.8 Vdc/unit
voltage Average at 77°F (25˚C)
Recommended 50A
maximum
charging
current limit
Equalization and 14.4 to 15.0 Vdc/unit
cycle service Average at 77°F (25˚C)
Self discharge Batteries can be stored for six months at 77°F (25°C).
Please charge batteries before using. For higher
temperatures the time interval will be shorter. Voltage
test prior to battery installation is recommended.
Terminal 12-thread lead alloy recessed terminal to accept
M6 bolt
Container Polypropylene UL94-V0/File E50955
material Flammability resistance of UL94-HB/File E216959
is available upon request.
Recommended 50A
maximum
charging
current limit
Não sei a capacidade, mas com certeza não é de 250 Ah.
500 W  /  12 V  =  41,666 A
Máxima corrente de carga de 50 A.
eu ate pensei nessa conta!!! mas fiquei com duvida qdo vi o peso da bateria (Weight Approximately 100.75 lb (45.7 kg))
Exatamente...
A matemática num mente!
Acho que não só 50A pois a conrrente indicada para carga da maioria das baterias é de 10% da capacidade total. Dá uma olhada no site de baterias estacionárias nacionais e compare os dados das nacionais.
