marcelomoti
Mostre aqui seus "Pezinhos" personalizados
post_old.gif 03-07-2011 #133
ALL4SQ
DIYMA freshman
Rep Power: 63 reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gif
icon1.gif Re: Show off your kickpanels!!!!
Finally finished the changes to my Kick panels tonight.
Using Hybrid Audio L4SE Mids and L1Pro Tweeters.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kick_drivers_with_grill.JPG
Ended up Forming perforated steel for the Grills.
The Vinyl work and the fit and finish of the trim panel was all done by Hzemall Customs.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kick_passengers_with_grill.JPG
A view of the Passengers side finished Kick panel.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kick_drivers_no_grill.JPG
With the grill removed you can see the new enclosure.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kick_pasengers_cloth(1).JPG
A stretch velvet Grill cloth like material was used to wrap the new enclosure. With grills on its really hard to see the velvet material.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kicks_L4_Baffle_front.JPG
A baffle was made using my new Blade Runner. It took me a couple attempts to get the hang of the blade runner, after getting the hang of it I found I really liked it.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kicks_l4_baffle_back.JPG
A view of the back side of the baffle. Threaded inserts were used for mounting the speaker to the baffle.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kicks_l4_baffle_with_driver.JPG
An angled router bit was used to clear away material from the baffle that blocked the back wave of the speaker.I'm not sure this makes a big difference but I didn't see any harm in giving it a shot.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kicks_laser_pointer.JPG
Used a Laser pointer to aim the new mids to the same location the previous mids were set at. I haven't had a chance to get the system up and running so I'm hoping the same angles will work.
wol_error.gif This image has been resized. Click this bar to view the full image. The original image is sized %1%2. kicks_3.5_vent.JPG
The L4 has a 3.5" vent to the wheel well area, with really fine select products grill material to keep the bugs out.
There will be a few inches of space between the plastic fender well liner and the vent. With the new kicks I can use standard wheel well liners without any modifications.
Looking forward to finally getting it all back together over the next few weekends.
Thanks
Bases dos pezinhos
esquerdo
direito
pezinho direito totalmente bruto, sem lixa sem nada... só fechado...
pezinho esquerdo, mais bruto ainda....
Nas próximas fotos eles já sofreram uma razoável lixada
agora bem mais lixados e já reinstalados pra teste no carro.
Nas próximas fotos, os pezinhos encapados
encapados e instalados no carro.
direito
esquerdo
http://autoforum.com.br/topic/95555-palio-weekend/
Esse do post #10 vejo todo santo dia Hahaha.
esse do post 10 é o seu gariba?
é um kadett?
to achando que esse pezinho ai é plug and play no monza ein... apesar que o meu é o tubarão...
se possivel me passe mais ou menos a litragem que deu e as medidas ai... vou estudar oq fazer, heheh
o trampo será do lado direito, que tem a porcaria do modulo de injeção.... acho que vou tirar aquela merd@ e por carburador... kkkkk Tudo pelo som!
zueira... :vts
Logo serao os meus que estarão aqui, assim espero, rsrs
Olhando assim parece uma coisa tão simples de se conviver no carro... mas vai calçar 46, vai...
:+1 :+1
por isso que eu não gosto de pezinhos.
Mas tem uns aí de tirar o chapéu!
Editado por Fortes
Olha, mandando a real, esteticamente é difícil ficar bom hein, mas de performance deve ser imbatível mesmo.
p.s.: celular travou não conseguiu abrir as fotos!!! tive que abrir o pc :vts
Esteticamente não fica bonito mesmo! Mas rende absurdos!
Meu 207 no passado.
Pezinhos feitos por mim, toca 100x melhor que hj no Punto.
http://autoforum.com.br/topic/187137-regulagem-clarion-dxz785upgrade-de-todo-o-settroca-de-carro/page__st__525
http://autoforum.com.br/topic/187137-regulagem-clarion-dxz785upgrade-de-todo-o-settroca-de-carro/page__st__550
Minha contribuição!
Pezinhos do "meu" civic, mas pode-se dizer carro da patroa!!! Ela usa pra ir trabalhar!
Volume interno aproximado de 7,5 a 8 litros.
Direcionamento cruzado.
th_Imagem041_zps6ce290bc.jpgth_Imagem047_zpsd83af2b2.jpgth_Imagem048_zps7bbc38b7.jpgth_Imagem051_zpsb276b2dd.jpgth_Imagem053_zpse08e163f.jpgth_Imagem063_zpsb8a9eb00.jpgth_Imagem064_zps0316f24f.jpgth_Imagem065_zps7df9b55c.jpgth_Imagem070_zps39d3f798.jpgth_Imagem081_zps87a19ef0.jpgth_Imagem071_zpsa0ff84d8.jpgth_Imagem077_zpsd29fe426.jpgth_Imagem080_zps565360d3.jpg
Minha contribuição!
Putz, q covardia! Show de bola!
