rfediuk
Meade vai lancar equipamento de "prevençao de clip!"
Ever wonder how to set your amp gains properly? Do you just turn them up till its loud enough for you and call it done? Do you turn them up all the way...... or do you tell your boys "my amp is ONLY up 1/4 of the way"? If you want to set them properly then the only true way to do it previously, is to us an Oscilloscope or "O-Scope" to detect a clipped signal. Well now you have a cheaper yet very accurate alternative, the SMD Distortion Listener (no official name yet). This was developed for and with SMD by Tony of D'amore Engineering and our other partner and electronic guru Juan. It was developed for those who dont have access to an O-Scope or even if they did, they might not understand how to use one. This is a pretty fool proof way to do it, without the scope. Put it this way, this device might not just force you to turn your gain down, in some cases you might have left some of your power "on the table" and werent taking advantage of it.
Use tracks ranging from 0db to -10 db (included on the disc) to set your gain overlaps according to the way you play your system. Detailed instructions will be included of course and i promise you this is EASY.
Stay tuned to my channel, there will be updates on availability soon as well as another cool little device i plan on showing.
Check out my website http://www.SteveMeadeDesigns.com/board and join today!!
also, hit up my facebook page @ http://www.facebook.com/pages/Steve-Meade-Designs/59127968198
Isso ai, aposto que logo os fosgates e outros amps tão usados por lá saem com led clip!!
Mas existe isso ha tempos nos Soundstream, a linha Rubicon tem.
D'Amore? não é o eng que criou o RF T15kw? não duvido que saia logo pros fosgates então!
Posta essa tecnologia ai da soundstream , porque achei que era invenção nacional !!
Mas isso não é o que já temos por aqui há algum tempo?
Agora quero ve os bundao que tem medo de por amp gringo rss é diz que nao poem amp gringo pq tem medo de queimar o sub pq nao tem led clip UAHUAHUAHUAHAUHAUHAUHAUHAUAH...
led clip é legal..mas te limita muito = / te gera uma medo de distorçao..SEMPRE tivemos...sempre TEREMOS...e sempre QUEIMARESMO ..led clip so mostra quando a faca entra UAHUAH
Editado por Luiz Henrique
Gente, vcs tão misturando o cu com as calças!
O equipamento aí serve pra detectar distorção por clip, pra permitir o ajuste do ganho.
O led de clip nunca foi tecnologia nacional. Nunca. Ele é uma função existente no chip que faz esses amplificadores funcionar. No máaaaaximo, pode ser chamado de teconologia da National. :vts
São coisas diferentes, o led clip permite monitorar o funcionamento do amplificador durante o uso, o da SMD é apenas para ajustes. MAS o led dos amplificadores JAMAIS vai detectar distorção vinda do player! E é BEM comum ter distorção com volume alto e bass no +12, loud e bass boost no talo, coisas MUITO comuns na quase totalidade dos sets de SPL.
QUASE todos...qquer um q tenha o minimo conhecimento sabe que bass boost e loud é ilusão de melhorar o som
Praticamente todos que eu conheço usam loud, bass boost e ainda dizem que corneta da qualidade... vai saber kkk
ué mas nem sempre usar o loud , bass boost quer dizer que a pessoa ache que está ganhando mais potência no som por causa disso...
O uso deles serve para regular , então depende muito do seu set...
Praticamente todos. Exlui-se nem 0,001%.
Editado por Kleberlpa
Qual criatura inventou a corneta ? :banghead
pra MELHORAR ...depende do ponto de vista... se voce usar um bass bost a fim de encorpar o seu som ate ficar do seu gosto...acredito que seja uma melhora... mas em referencia a qualidade realmente nao melhora...
mas eu sempre usei um bass bost... mesmo com amp gringo e nunca queimeu meu sub...olha que se meu amp tivesse led clip ele ia bater raxa com o led power!
Corneta é provavelmente um dos maiores avanços em áudio, antes mesmo da invenção do alto-falante.
A culpa é dos corneteiros.
Falou certo, e aumenta pra 0,002% isso ai. Meu player nem tem loud, o grave não aparece sem bass boost quando o ampl. é fraco pros sub. Quanto ao equipamento do Steve na de mais pro nível dele, me surpreenderia se inventassem um display remoto onde pudesse visualizar a senoide e/ou quanto de distoção na saída do amplificador.
Nem precisa, já existe há mais de 50 anos, está na bancada de toda rádio, rádio-amador de porte ou TV... só que é preciso saber usar... hehehehehehehe
Mas eu quero um no painel do carro :rolleyes:
Tem isso a tempo ja... antes dos Soundstream a Roadstar ja tinha...
Editado por Gabriel Arthur
Eita... posta ai pra nóis! :)
Faço parte dos 0,0001%... que legal...
Sei não.. ao menos aqui, o pessoal que já tem um certo nível de conhecimento sabe que loud e bass boost são estupradores de subwoofer.
E sim.. o loud realmente melhora o som em alguns casos. Em sistemas mais básicos pra ser mais específico pois quando se trata de algo mais voltado para o sq, onde se tem uma linha de resposta mais plana, o loud MATA a naturalidade do som.
