Modifications:
2JZGTE Transplant from JZA80 Supra (78,000kms on engine)
New seals throughout the front and back of the motor and new timing belt, oil pump and water pump
KKR PI-2 Intercooler with custom super short stainless tig welded piping
T78-33D turbo with 17cm rear housing
Custom 4" inlet with HKS mushroom
Fidanza Cam Gears
Helps Metal Work Merge collector steam pipe manifold
Helps Metal Work Dump pipe and screamer
Modified Kakimoto straight through catback (no cat fitted)
Ebay HKS Style 60mm gate with genuine HKS diaphram and turbosmart 12psi spring
R154 gearbox (smooth shifting and no noise)
C's Short shifter with cusco knob
OS Giken TS2BD Twinplate clutch (steel cover) with movement adaptor
Rising rate FPR with guage
Bosch 044 external pump mounted and 2 litre surge tank mounted in the boot
Microtech LTX12S with microtech dash fitted in cabin and custom wiring (minimal wiring in engine bay)
2 Recaro seats (SR2 I think) (mis matched colours) both with recaro rails
Just Alloy Radiators Aluminium 3 core radiator with custom alloy shroud and twin 12" Davies Craig Fans
Factory skirts and pods
Hard flared guards
Welded rear diff with 4.55 ratio
Cusco Zero 1 R coilovers in the front (20kg swift springs)
Cusco Zero 2 R coilovers in the back (14kg cusco springs)
Whiteline Rear swaybar (thickest solid one they make)
Modified hub ends and LCA's for increased lock
Work VS-XX wheels 17x9.5 +24 with KU36 tyres (235/45) and 17x10 +24 with Duruns (225/45)
Pioneer Headunit and 4" two ways in the front
Testando:
