_Julio_
Focal x Alpine x MB Quartz
Boa noite pessoal.
Estou fazendo algumas pesquisas pra um novo kit 2 vias e fiquei na dúvida: :banghead
Fiquei interessado em uma das 3 opções abaixo, e venho humildimente pedir uma ajuda daqueles que certamente entendem do assunto.
No caso gostaria que casasse, se possivel, com um módulo Alpine MRP-F300 e um sub pioneer TS-W257D2, uma vez que não to podendo trocar tudo de uma vez só.
Penso em montar um SQPL. Ouço rock, eletronica, black....
Os kits 2 vias que me interessaram:
MB Quart PVI 216
6-1/2" Premium Series 2-Way Component Speakers System
Power Handling:
Peak: 280 watts per set / 140 watts each side
RMS: 140 watts per set / 70 watts each side
Polypropylene cone woofer
Rubber surround
1.5" Titanium "Widesphere" tweeters with neodymium magnets
Magnet system with silver lacquered specially designed metal cover for additional cooling and protection
Connection terminals gold-plated allowing for the best possible signal transfer
Premium Performance-crossovers with new and unique FleXX Mount system for limitless mounting possibilities
Three-level tweeter attenuator with rotary switch (0, 1, 3, 5 dB)
Bi-wiring and bi-amping capable
Crossover filter (2900 Hz, 6/12 dB/octave)
4 ohms impedance
1" Voice coil
Top-mount depth: 2-1/2"
Focal 165 KF
6-1/2" K2 Power Series 2-way component system
Power Handling:
Peak: 320 watts per set / 160 watts each side
RMS: 160 watts per set / 80 watts each side
6.5" Composite Sandwich cone
Butyl Rubber surround type
TN 45 Inverted Tioxid 5 Tweeter
Adjustable tweeter level
Separate crossovers 12/18 dB/octaves
4 ohms impedance
1" (25mm) voice coil
3-1/3" (85mm) Neodyme Magnet
Top-mount depth: 2.80" (70mm)
Alpine SPR-17S
Type-R 6-1/2" 2-way Component System
Power Handling:
Peak: 660 watts per set / 330 watts each side
RMS: 220 watts per set / 110 watts each side
Impedance: 4 ohms
Hybrid layered-pulp woofer with rubber surround
1" Textile ring-dome tweeter
External crossovers — 12 dB/octave (high -pass) and 6 dB/octave (low-pass) crossover points
Frequency response: 65 Hz - 27 kHz
Sensitivity: 87 dB
Top-mount depth: 2-5/16"
Me deem uma ajuda por favor :legal:
e aí pessoal ? alguem arrisca ?
Eu só posso dar opniao no SPR 17s pois possuo um....o kit tem uma potencia extraordinaria, o tweeter é muito equilibrado e agradavel...o mid não tocou como eu esperava....mesmo com a porta tratada !!! :legal:
Como a dúvida é referente ao kit, vou transferir pro SQ! Eles conhecem melhor os kits que vc citou!
Eu iria de Focal. Apesar de possuir um MB Quart, se não me engano a linha PVI já não é mais fabricada na alemanha, e perdeu mt qualidade
A Linha Acess e polyglass da focal tbm não é mais feita na frança...........somente a K e a Utopia...........
Cara, o melhor jeito de escolher é ouvir. Se isso não for possivel, tente ler alguns reviews no forum (vide busca) ou sites (vide google) e depois, se ainda tiver duvida, vai no que o seu coração curtir mais :rolleyes:
Eu posso falar do Focal KF, pois possuo ele...............porem instalei ele a 2 dias no meu carro, e ainda não fechoei meu set..............o que posso falar inicialmente é que o Tw é muito suave e profundo............muito gosto de se ouvir. O Mid é muito gostoso tambem, em comparação ao meu antigo Fosgate, o Focal tem menos "pressão", para musica eletronica o fosgate era animal........ o Fosgate é um pouco mais sutil, mas para sons tipo, o cara batendo no violão, ou um bongo, ele dá de 10!
obrigado pelas respostas.
o pessoal da loja onde vou fazer, tem os 2 pra vender - focal e alpine, vou pedir pra testar antes e sentir o que mais agrada. Quero aproveitar q tem um amigo indo pros EUA nesse feriado, pra pedir pra ele trazer pra mim.
valeu...
Rapaz, eu to com um PVF 216, pelo menos no meu caso, com uma porta meio tratada (serviço tabajara de final de semana), o MB quart tá tocando muito.
Sempre ouvi o pessoal falando dos MB mas só ouvindo mesmo para acreditar... E agora virei fã, ehehehhehehe
Editado por leorbolato
Mids da MQ Quart realmente sao FODAS, unico porem sao os tweeters, troquei o meu tweeter do PCE216 por um DLS Iridium 1i e to pra achar kit (compravel, leia-se abaixo dos 800 reais) que toque melhor
abraco
Bessa, vc sabe desde quando que o access e o polyglass pararam de ser fabricados na frança????
Eu comprei o meu em Junho/2009 e na caixa e no manual ta MADE IN FRANCE.........
Eh, acho que nao sao todos nao...................mas ja vi nuns 3 falantes o eskema assim:
"Desenhado pela Focal, na Franca......montado na china........."
pasmafaute
Provavelmente não altera em nada o falante, se manteve as mesmas specs.
Editado por Ianaconi
Poxa tava pensando em comprar um FOCAL ACCESS1 ou então o POLYGLASS...mas essa de ser feito na china quebrou as pernas agora. Será que todos estão vondo de lá mesmo? Será que a focal vai piorar?
Até onde sei Focal Access (linha de entrada), sempre foi fabricado na Ásia. Isso não altera em nada o falante.
Sua televisão provavelmente é feita na China... Seu aparelho de som também... e por ai vai.. rs
isso de feito na China é algo interessante... e temos de nos acostumar com a idéia, e aprender a diferenciar o que é feito na China sem muito controle de qualidade (falsificações, marcas inferiores, etc) do que é feito na China sob supervisão responsável, com engenharia de ponta, etc. Até alguns anos atrás eu tinha um enorme preconceito contra produtos chineses, justamente porque a imensa maioria do que chegava até mim de lá eram produtos ridiculamente baratos e mal-feitos. Hoje, dificlimente eu conseguiria comprar algum bem durável eletrônico que não tenha mão-de-obra chinesa, malaia, filipina, coreana envolvida.
Só pra citar um exemplo: meu Pioneer 880prs era... malaio. Meu Alpino 9887, idem. Montei um som pra casa, nada high-end, só alguns componentes simples de boa qualidade - ampli integrado Marantz, dvd Marantz e caixas Kef. Todos vieram da... China. Tocam muito bem, são produtos que dão a impressão de que vão me acompanhar por pelo menos uns 10, 15 anos, acabamento excelente, etc... mas são chineses. Fabricados lá sob supervisão das fábricas inglesas, com engenharia inglesa, padrão de qualidade inglês, etc. O que é imensamente diferente de equipamentos projetados por lá para serem vendidos pelo menor custo possível, usando componentes de péssima qualidade, acabamento inferior, durabilidade pífia, etc. Eu não descartaria um bom kit automotivo por ter sido fabricado na China, se houvesse a garantia de autenticidade (não-falsificação) e uma empresa de renome e responsabilidade garantindo-o. :legal:
No fundo isso é verdade sou representante comercial e alguns produtos que vendo são feitos na china, tenho produtos de primeira feitos lá, como também tenho de segunda, existe uma enorme diferença de preço e qualidade. Acho que a focal não iria colocar seu nome de 30 anos em jogo produzindo seus produtos em uma fábrica medíocre lá. Uma antiga estatal, daquelas que produz em massa e só muda a marca dos produtos, como poderia fazer um Fogal... pra não dizer Focal...bem coisa de china hehe. Acredito que eles mesmo abriram uma fábrica lá supervisionada etc, com tecnicos e engenheiros da p'ropria focal, mas com mão de obra chinesa, fazendo com que o preço baixasse. O que podem falar da linha access? To pensando em um kit access, mas será que vale a pena por ser de entrada? dá muita diferença de um polyglass ou um k2? Tipo fusquinha, astra, bmw?? hehe... o que podem dizer quem já ouviu?
