Broco
Mostradores No Dvd
Cara ninguem lê japonês aqui( hehehe)
pra facilitar:
The long-awaited return of HKS' CAMP system is now a reality with the release of CAMP2. CAMP2 is an all-in-one engine multi-meter system that is incorporated with a vehicle's on-board factory or aftermarket monitor.
The launch of the CAMP2 comes just as HKS celebrates its 35th Anniversary. The first generation CAMP was released by HKS in 1996. At that time, it was the first monitoring system of its kind allowing users to view vehicle engine information. During the time of CAMP's initial release, on-board factory monitors were still rarities in cars available in North America and aftermarket units were not as commonly seen as they are today. CAMP2 is now available for purchase through your authorized HKS dealer.
TECHNICAL INFORMATION:
• Users can view up to 6 simultaneous readings while monitoring up to 24 data signals
from the vehicles OBD2 port and optional HKS Sensors.
• Installation is simple and connects to the vehicle's self-diagnostic OBD2 port enabling the
CAMP2 to function on a variety of vehicles and applications.
• CAMP2’s menu features are user switchable to Metric or SAE readings according to user
region.
• ECO Drive – Programmable calculations for fuel costs, average fuel consumption, and
fuel efficiency lets the user monitor real time data readings.
• An included remote control allows the user to switch between functions and modes.
The remote control receiver is separate from the base unit allowing convenient,
user friendly placement.
• CAMP2 allows map editing for the F-CON S/SZ/iS.
Map editing can be done only for unlocked maps; please consult with your Certified HKS
Pro Dealer.
Nissan vehicles require the optional CONSULT harness and vehicles equipped with an
HKS F-Con S/SZ/iS and V-Pro can purchase an optional HKS F-CON connection harness* for
additional monitoring features.
(*For vehicles equipped with the HKS F-Con S/SZ/iS and V-Pro Engine Management system)
• Real time fuel efficiency can be monitored relative to time, distance and speed.
• Up to 6 readings can be displayed on the screen at one time: TIME (Elapsed Time),
DISTANCE (Driving distance), SPEED (Average speed), FUEL (Consumed fuel volume),
ECO (Average fuel efficiency), COST (Fuel cost).
• Real-time fuel efficiency is shown as a bar graph on the bottom right of the screen.
• Up to 6 simultaneous readings can be viewed on a time based axis by graph and digital
meter.
• VIEW function: data changes at 0.2 second intervals can be monitored.
• Logging can be conducted for up to 600 seconds (10 minutes).
• Selected item(s) can be shown in the analog meter.
• Select from two modes: either 3 analog meter displays, or 1 analog meter with 6 digital indicators below it.
• Analog meters accurately show continuously changing data.
• Selected item(s) can be shown in the digital meter.
• Select from 6 digital meters or 3 digital bar graphs to appear on the screen.
• Digital meter shows accurate data for each item.
* For vehicles equipped with HKS F Con S/SZ/iS/V-Pro Engine Management Systems
• The input value and/or the output value of each F-CON sensor can be monitored.
• F-CON S/SZ/iS data can be monitored and edited when connected to the CAMP2
(depending on the F-CON model and/or installed sensors).
Map editing can be done only for unlocked maps; please consult with your Certified HKS Pro Dealer. (Data for F-CON V-Pro cannot be edited.)
• Settings can be adjusted based on engine specification, such as exhaust type or intake type.
Part # Description MSRP Find a Dealer
48001-AK001 CAMP2 $535.00
Optional Parts
48002-AK001 CAMP2 Nissan CONSULT Harness $35.00
48002-AK002 CAMP2 F-CON Connection Harness $12.00
44008-AK011 Meter Interface Unit (I/F Unit) $88.97
44999-AK011 Optional Temp. Sensor and Harness Set $61.97
44999-AK019 Optional EGT Sensor and Harness Set $133.97
44999-AK020 Optional Pressure Sensor and Harness Set $133.97
44999-AK021 Optional Boost Pressure Sensor and Harness Set $133.97
Opa!
Então, poderiamos pensar nesse PC aqui: http://usa.asus.com/products.aspx?l1=24
É um lançamento da Asus que tem o tamanho de um daqueles DVD players portateis. Custa umas 500 doleras na gringolândia.
É muito atraente pra por em carro porque não tem HD, todo sistema de armazenamento é baseado em memória flash, então vc pode chacoalhar o quanto quiser ele sem dó.. Rsrsrr!
Aí é colocar um lcd em qq lugar e usar um sistema como o citado pelo Scooby ou algo parecido.
Fora que é fácil pra tirar o mininote do carro e levar debaixo do braço!
Abração!
