diegojj
Impressões Sobre Cd Player Britania
uma vez eu vi acho que aqui no forum mesmo, uns caras q tavam desenvolvendo um sistema de falantes usando ventiladores pra desolcar o ar e fazer som! ahuhuah era pra grave obviamente!
é a britania inovando! auhauhuaha empresa nacional hi-tech!
provavelmente fumaram alguma coisa antes :pirou:
nada a ver isso
A new type of Loudspeaker
A motor controller and electric motor rotate a set of blades at a constant speed. The rotary woofer pitch mechanism uses a conventional voice coil and magnet assembly. This is connected to your amplifier to pitch blades in proportion to the applied audio signal. As the blades pitch while rotating a pressure wave is generated, the degree of pitch controls the amplitude of the pressure wave. Air is allowed to transition through the blades. Thus oscillating the pitch of the blades creates sound while they are rotating .
The advantage of the Thigpen rotary woofer (patent pending) and the conceptual jump occurs in understanding the impedance match with the air in this approach to sound reproduction versus the impedance mismatch with the air in a cone woofer.
The air density is much too low to be a good impedance match with a cone loudspeaker. Take your hand and try and grab some air or flatten your hand and try and push some air as fast as you can. This illustrates the futility of trying to move air to create a small amount of pressure at low frequencies with a cone speaker. You can barely feel the resistance of the air to the motion of your hand, the air molecules simply slip around.
Now take your hand while driving down the road and stick it outside the window of a car. The faster you go the thicker the air feels. Also a simple twisting of your hand enables you to deflect a large number of air molecules. This illustrates the way the rotary woofer works and how effectively it couples moving blade surfaces to the air to create sound pressure.
A conventional speaker cones displacement must increase four times for each halving of frequency to maintain the same output. This is why conventional cone woofer companies are trying to develop “long throw” woofers. Although inefficient, cone woofers work fine above 40Hz. Below 40Hz however cone woofers quickly run out of travel and the output diminishes rapidly.
The rotary woofer represents a much more efficient way to move air at low frequencies. Because of aerodynamic affects and swept area versus frequency, the displacement of the rotary woofer pitch mechanism barely has to increase at all as the frequency goes down. We can now listen to never heard before very low frequencie sounds.
esse memo seu kreber!
nada a ver isso
Bem engenhoso este ventilador, quem sabe a Britâneta começa a produzir em larga escala, se não servir como subwoofer pelo menos vai dar uma refrescada no carro.
Pior hein Halvaro..... acho que o lance é como o Kleber citou.... eles compram e colocam a marca....
Já perceberam quantas marcas nunca citadas estão surgindo ?? Recebi um desses folhetos do submarino e fiquei besta com a quantidade de marcas que nunca ouvi falar....
da na mesma, e como eu já disse, no caso do DVD , ta muito bom, custou 159,00 e ta melhor que alguns nacionais de "nome"
no caso do player que o nosso amigo comprou, por 200,00 não vai achar nada superior mesmo, novo, usado acharia uns pioneer, mas teria que ter muito cuidado de ver o estado, eu já entrei em furada comprando usado.
Agora os 6x9 Hbuster por 200,00 foi caro demais, acha bravox por menos na net.
Acho que não precisa ficar malhando tanto assim o camarada, e ficar tirando onda, deixa ele ser feliz.
falante de 5" se fosse em conjunto com um sub aí daria um bom som, agora só o falante de 5" sozinho nunca vai dar o mesmo grave e SPL de um 6x9, pra um som simples e barato o 6x9 é uma boa solução
do que adianta ter 2 6x9 de 100rms cada um se o player só joga 12 rms por canal...
no caso dele ele só ta jogando 24rms no carro, se fosse com os 4 de 5" seriam 48 rms xD
amigo, ta esquecendo de uma fator chamado sensibilidade do falante. Significa muito mais que a potência aplicada
1 w aplicado num 6x9 gera muito mais db que 1w aplicado num falante de 5".
ex: um 6x9 bravox ultra tem 91db, e um traixial 5" bravox 88db, são 6db a mais, isso significa 4 vezes mais SPL ou volume
Portanto, levanto em conta os falantes do ex:
24w aplicados num par de 6x9 geram ainda o dobro de spl que 48w em 4 falantes de 5"
sem contar que o 6x9 desce a frequencias mais baixas do que triaxiais de 5"
Triaxial com 88dB de sens?
Difícil... a maioria tem sensibilidade igual ou superior ao 6x9... afinal, o 6x9 é apenas um triaxial de 8" efetivo.
também acho que isso não tem nada a ver, jogar 12 rms num 6x9 de 100rms ou em um de 5" de 40rms acho que o de 5" ainda vai fazer mais som.. já que o 6x9 mal vai se mecher
bom, desde que eu comprei um dvd da powerpack pra por no meu carro, eu nao uso mais marcas cabulosas nunca na vida, perdia feio pra um pioneer bem antigo que eu tinha, eu instalei, usei um dia e tirei, fui no outro dia e comprei um player da panasonic, pois ja tinha vendido meu pioneer, dai sim, foi mudar do dia para a noite, hehehehe
By Joeyzaum
Nem sempre............pra toda regra existe exceções..............usei por um tempo um super amp de 2 X 30 RMS , tocando um kit 2 vias de 150 rms , q vou te contar viu.................... tocava mais q amp de 2 X 110 RMS , potencia num eh nada sem controle............. :legal:
Produto de qualidade é ouuuutra história !!!
Se nem pioneer ou sony são reais os Wrms (amp. do player) afirmados pelo fabricante, ou seja, falam 50 e rola 20/25, imaginem este player citado !!!
<_<
