Efernandes
Soundstream Reference 800.4
Bom galera eh o seguinte, quarta feira estou indo p/ os EUA e estive pesquisando alguns AMPs e kits, decidi comprar um MB Quart QSD 213 e pra tocar ele estava pensando num Soundstream Reference 800.4. Sei que antigamente a Soundstream era muito bem vista (e acho que ouvida tambem) pelos seus amplificadores, ela continua fazendo bons Amps? A minha idéia é investir no máximo us$ 400,00 no amplificador do estéreo, estarei bem servido se comprar esse?
Bom.. aí vao algumas características dele, se puderem opinar..
Features
* Output RMS @ 4Ohm: 4 x 125W
* Output RMS @ 2Ohm: 4 x 200W
* RMS bridged @ 4Ohm: 2 x 400W
* T.H.D: < 0.02%
* Signal to noise ratio: > 115dB
* Damping factor: > 500
* Frequency response: 10-70 kHz
* Input sensitivity: 0.15-12.0
* Crossover slpoe: 18dB
* Crossover frequency: 30Hz -4 kHz
* Dimensions: 10" x 2.5" x 16"
* RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
* STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
* Trident™ amplifier protection topology
* Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
* Hawkins Bass Control™ Proprietary bass equalization topology
* IDI™ (Intelligent Distress Indicator) Gives visual indication of amplifier protection status
* Harmonic Bass Alignment™ Produces tighter and more accurate bass
* Fully regulated MOSFET power supply
* Triple Darlington output circuitry
* BIP™ Bias input protection
* Rail stabilization protection circuitry
* Bi-linear selectable 2-way crossovers for amplifier and line outputs
* Continuosly variable high and low pass crossovers
* Balanced line inputs for the highest level of noise rejection
* Gold RCA inputs and outputs
* Gold 2-gauge power connector
* Tri-mode operation
Brigadao!
Não conheço o amp mas lá fora os gringos recomendam somente as linhas antigas. Se for pegar de linha nova, a recomendação geralmente é ARC Audio, ZAPCO, DLS, Audison, entre outras.
Só tome cuidado para não se confundir!
Essa linha Tarantula, não tem nada haver com o famoso Tarantula (precursor da linha) que atingia 2800WRMS em 4ohms e custava a bagatela de U$2800 (um dólar por WRMS)!
Se for para empurrar um kit, eu recomendo procurar o Reference 1000sx, dois canais de 250WRMS em 4ohms, classe A puro e baixíssimo thd!
Era muito usado na época de "Ouro" da IASCA brasileira e não custa mais que uns U$400 nos U.S.A. (usado claro, pois não se fabricam mais essas coisas boas)!
Espero ter ajudado!
Continuo deixando claro que é apenas minha opnião, pois tem pessoas que acham que eu me entitulo "o dono da verdade" é só criticam!
Eu respondo o que foi perguntado ou no máximo, indico uma opção que eu já tive ou já testei!
Quarta foto, de cima p/ baixo, canto inferior direito:
O dourado é o Da Vinci, o cromado é o famoso Tarantula!
Os outros que tem o logo da tarantula, são uma linha nova (não muito nova) mas não tem a qualidade dos antigos, por isso, custam muito menos!
http://www.hifimobile.fr/magasin.htm
Boas compras!
:+1 Ctz , ARC Audio, ZAPCO, DLS, Audison!!! lah fora de cara seriam essas :legal:
Dá uma olhada nesses links!
Tarântula original:
http://ampguts.realmofexcursion.com/Sounds...tula_Monoblock/
Da Vinci original:
http://ampguts.realmofexcursion.com/Sounds...tream_DA_VINCI/
Detalhe: o Da Vinci, salvo engano meu, é banhado a ouro...
Compare com o nível dos amplificadores atuais. Há diversas fotos disponíveis para você apreciar. Dê uma olhada nos modelos Reference e Reference Class A... dá vontade só de olhar...
Abraços.
cara......... tenho um soundstream dessa linha nova XTA ...... não tenho o que falar mal dele ( e o XTA é a linha nova mais "furreca" que tem)..... Sempre fui fã de soundstream...... são fortes, qualidade excelente...... esses tempos eu tava procurando uns reference ou tarântula desses novos (mto forte tb).....
eu recomendo.... e como dizem: "os antigos soundstream, principalmente os Reference....... apavoram e a inda encontra-se novo por lá"..... acho que não irá se arrepender.....
Pena não ter muitos no brasil...Assim a galera fica só falando de JVC da vida, sem nunca ter ouvido um top da soundstream ou zapco mesmo.
Uma boa seria um teste com os wharf X class A soundstream x zapco class A.
Legal.........mas em termos de money eh um buraco enorme........o JVC eh estupidamente mais barato.........
Voce tem JVC para vender?? Se sim, manda uma MP para mim...
na verdade eu me refiro a amps mais antigos e não os tops que custam mais de 3k
Se eu tenho JVC para vender????? :blink:
Poxa mas o JVC 6700 novo na época custava 650 reias tenho NF aki , tudo bem mesmo vc colocando impostos ainda era bem barato......... os sound eram mto mais caros...... um sound novo dos tops passa brincando dos 3k......... custo beneficio fica ruim viu....... [¨]
Nossa... fiquei de cara...O.O primeiro kit mais top q eu comprei... mto lindo, antes tinha um Fosgate P162s..
Foi tanta empolgacao q eu me cortei todo qdo fui abrir a caixa de papelao heuaheua
Agora ainda to pensando... mais pra frente.. quem sabe eu pegue esse amp ahe.. mas ainda tem tempo..
Parabens!!! eh um QSD-213 certo???
num vejo a hora do meu chegar.............. :legal:
E módulo Precision Power PPI?
Presta para o estéreo.
Apenas os PPI antigos, mais especificamente os Art Series, os Power Class (PC), e os raríssimos Tube Drive (TD).
Mas posso dizer que a coisa é fina viu.
Isso mesmo.. eh esse modelo, o cross dele eh maravilhoso.. muito bonito mesmo..
