[SMD]This amp is rated 2500 watts but can it make it's power? NVX 2500.1 Monoblock unboxed & tested
I ordered this amp and an NVX sub several months back right before we even knew we were going to move our shop to a new location. I haven t had a chance to get to it while we set the new place and test bench up. Finally I got to unbox it and hook it up today It looks like a really nice well built amp. But can it make it s power Lets test it in 4 2 and 1ohm. All modes certified uncertified and dynamic RMS . As you can see it did...thanks for watching
Find this amp here: https://www.sonicelectronix.com/item-205877-NVX-XQA25001.html descriptionSection
Product Details:
XQ Series SQ Class D 1 ohm Stable Monoblock Amplifier
RMS Power Rating:
4 ohm: 1000 watts x 1 channel
2 ohm: 1500 watts x 1 channel
1 ohm: 2500 watts x 1 channel
Total RMS power output: 2500 watts
Linkable for Double Power Output 5000W RMS Strap Mode
Master Sync Capability: Enables two amplifiers to be synchronized using an RJ11 cable
LED Indicators: Power Protect Clip and X-Boost lights
Includes a Wired Bass Level Remote Control
Speaker-Level High-Level Inputs Requires adapter like the Kicker KISL
Tiffany-Style RCA Pre-Amp Inputs and Outputs
Signal-Sensing Remote Turn-On: Supports Remote DC Offset and Audio activation
4-Way Protection Circuitry: Thermal overload speaker short and DC offset protection
X-Boost Circuitry: Enhances bass response and compensates for bass roll-off
Maximum Input Level Control: Features LED optimization and clip indicators
Input sensitivity: 0.2 - 10 volts
Frequency Response: 10 - 400 Hz
Total Harmonic Distortion THD : 0.1
Signal to Noise Ratio: 96 dB
Variable low-pass filter: 50 - 250 Hz 24 dB/octave Metal Shaft with 41 Click Positions
Subsonic filter: 10 - 55 Hz 24 dB/octave
Variable Bass Boost: 0 - 18 dB 45 Hz
Adjustable Phase Control: 0d to 180d
Fuse Rating: 250A
1/0 AWG gauge amplifier wiring kit is recommended for installation
Dimensions: 17.10q L x 6.85q W x 1.89q H
Visit my favorite e-tailer for all your electronics here http://www.sonicelectronix.com
Shop SMD products here: https://smdaudio.com/
The SMD amps are a collaboration with DS18 Check out DS18 s site here http://www.ds18.com
a closer look at the Stinger Horizon 10 head unit here: https://youtu.be/iOsg46qm9TM
The number one sound deadener and my favorite http://www.secondskinaudio.com
For Business Inquiries: info stevemeadedesigns.com
car audio subwoofer
