[SMD]Another Epic unbox, test & flex! This mini Audiocontrol Epic 4 is powerful! Amp dyno results inside
After testing the Audiocontrol Epic 4000 watt amp a few videos back I knew I had to get this 4 channel Epic Four on the bench and see what it could do. I was NOT dissapointed at all I probably tested this thing 20 times in a row off camera and it just keeps on going. Want to see more Stay tuned there is more where this came from. Thanks for watching
The AudioControl EPIC Series 4-Channel Amplifier delivers top-quality sound in a compact thermally efficient design. Engineered with a high-current Class D design itrs 2O stable ensuring maximum power output while maintaining efficiency. With a smart auto-reset protection circuit and solid power/speaker terminals secured by hex screws the EPIC Series amplifier offers reliable exceptional sound quality in a rugged space-saving package.
Digital Class-D Amplifier: Powerful yet compact designed to handle 2 ohm loads for high output.
Direct Wire Terminals with Hex Screws: Provide solid reliable connections.
4-Gauge Power Terminal and 8-Gauge Speaker Terminal: Designed for maximum current flow.
91dB Signal-to-Noise Ratio CEA Standard : Ultra-efficient idle draw 0.5-1A .
Smart Auto Reset Protection Circuit: Multiple protection modes are in place to prevent damage if your amplifier encounters an issue.
Output Over-Current Protection OCP
Input Over-Voltage Protection OVP
Input Under-Voltage Protection UVP
Output DC-Offset Protection DCP
Over-Temperature Protection OTP
FEATURES
b Compact High-Power Class D Amplifier
b High-Current Design n 2O Stable
b 4 x 100 Watts 4 ohms
b 4 x 200 Watts 2 ohms
b 2 x 400 Watts 4 ohms Bridged
b Smart Auto-Reset Protection Circuit
b 12 dB/octave Linkwitz-Riley Variable High Pass Filters
b Solid Power/Speaker Terminals with Hex Screws
SPECIFICATIONS:
INPUTS
Line-Level Inputs: 500mV n 12V RMS
OUTPUTS
Continuous Power RMS 14.4V
WEIGHTS a DIMENSIONS
DIMENSIONS: 6.1P W x 9.41P L x 2.01P H
PERFORMANCE
Frequency Response /- 1 dB : 10 Hz n 22 kHz
S/N Ratio: 90.1 dBa Ref 100 Watts 4 ohms
Power / Ground Wire Gauge: 4 AWG
Recommended Fuse Rating: 80 Amps
High Pass Filter: 12dB/octave Linkwitz-Riley Off 50 Hz to 500 Hz
Speaker Terminal Wire Gauge: 8 AWG
More info on Audiocontrol Epic amps here https://audiocontrol.com/collections/power-amplifiers
Visit my favorite e-tailer for all your electronics here http://www.sonicelectronix.com
Shop SMD products here: https://smdaudio.com/
The number one sound deadener and my favorite http://www.secondskinaudio.com
For Business Inquiries: info stevemeadedesigns.com
car audio amplifiers
