[Taramps]Taramps TL 1500 - 3 Channels Automotive Module Amplifier 390 Watts RMS | Taramps
The TL 1500 amplifier from Taramps is intended for 3-channel car audio systems, and its features follow below: - 2 stereo channels (L/R) at 95 Watts RMS, at 2 ohms each, with an active cutoff filter (HPF) at 90Hz to connect the door and trunk cover speakers. - 1 SUB channel with 200 Watts RMS at 4 ohms, for subwoofer speakers. This channel is the result of the sum of the channels (L/R) with active cutoff filter (LPF) at 90Hz. It is a stereo amplifier, with a total power of 390 Watts RMS, FULL RANGE, playing all frequencies just the way you like. https://www.taramps.com.br/en/produto/tl-1500/
