marcelomoti
[VENDO] Amplificador Focal Solid 4, 4canais, R$900 São Paulo/SP
R$900 (comprando junto com o Focal Solid 1, fica R$1600)
localizado em São Paulo/SP
Testado, funcionando
Não acompanha nenhum outro acessório como tampa, parafusos adicionais, etc que não apareceram nas fotos
Focal Solid 4 Car Amplifier
Focal makes sure that nothing stands in the way of your music, especially your amplifier. Each Focal Solid amp features low-noise inputs that let you connect to almost any receiver — even your factory stereo.
Unassuming amp features an aluminum chassis that disperses heat efficiently, so it runs cool even when you're pushing your system hard.
The power and control you need
The four-channel Solid 4 amp puts out 75 watts RMS per channel to your front and rear speakers, or you can send 200 watts RMS each to a pair of subwoofers, giving your bass some real impact. You can also bridge the rear channels to power one sub, then use the front channels to drive a set of full-range speakers. A wired remote lets you adjust gain on the fly. High- and low-pass filters shape amplifier output to match your speakers, your vehicle, and your music.
Hyper-sonic performance
The amp's ultra-high frequency response brings out all the overtones that add realism to your music. Short-circuit, over-current, and thermal overload protection circuits ensure that this full-range amp will reproduce your music with breathtaking realism for years to come.
Solid connections
Product highlights:
4-channel car amplifier
75 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
CEA-2006 compliant
variable high- and low-pass filters (50-150 Hz, 12 dB/octave)
Class-AB amplifier design
frequency response: 10-60,000 Hz
preamp- and speaker-level inputs
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 25A x 2
11-13/16"W x 2"H x 7-7/8"D
20220330011558focalSolid4_14.jpg20220330011557focalSolid4_13.jpg20220330011556focalSolid4_12.jpg20220330011556focalSolid4_10.jpg20220330011556focalSolid4_09.jpg20220330011555focalSolid4_08.jpg20220330011555focalSolid4_07.jpg20220330011555focalSolid4_06.jpg20220330011554focalSolid4_05.jpg20220330011553focalSolid4_04.jpg20220330011553focalSolid4_03.jpg20220330011554focalSolid4_02.jpg20220330011554focalSolid4_01.jpg
Visitante
