cirso
[VENDO] Amplificador Rockford Fosgate Punch 250.1 Mono, Old School
Amplificador ainda "Made in the USA", dispensa comentários, símbolo de qualidade sonora os Rockford Fosgate até hoje são muito valorizados pela comunidade do som automotivo que busca qualidade e potência
Lacres da garantia original intactos
R$ 499 reais
Link no ML: http://produto.mercadolivre.com.br/MLB-897247379-amplificador-rockford-fosgate-punch-2501-mono-old-school-_JM
250.1 SPECIFICATIONS
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4V
Mono into a 4¿ load = 420 Watts
Mono into a 2¿ load = 710 Watts
Bridged (using 2 Punch 250m) into a 4¿ load = 1420 Watts*
Continuous Power Rating (Competition Standard) – Measured at 13.8 Volts
RMS continuous power mono, into a 4¿ load from 20-20,000Hz with less than 0.10% THD = 250 Watts
RMS continuous power mono, into a 2¿ load from 20-20,000Hz with less than 0.15% THD = 500 Watts
RMS continuous power bridged, (using 2 Punch 250.1 Power amplifiers in the same system) into a 4¿ load from 20-20,000Hz with less than 0.15% THD = 1000 Watts
Signal-to-Noise Ratio: >100dB (A-weighted)
Frequency Response: 20Hz-20,000Hz ±0.5dB
Bandwidth: 10Hz–250kHz ±3dB
Damping Factor @ 4¿ (at output connector): >200
Slew Rate: 50V ms
IM Distortion (IHF): <0.05%
Input Impedance: 20k Ohms
Source Unit Compatibility (+15dB Gain Overlap): 28V max. input
Input Sensitivity (+0dB Gain Overlap): Variable from 300mV to 5V
Pass-Thru Output: Unity Gain
B+ Fuse Size: (External to amplifier) 60 Amp or two 30 Amp
Fuse Type: AGU / Maxi Fuse
Crossover Slope: 12dB or 24dB/octave Butterworth
Factory Crossover Frequency: 80Hz (0.047mf)
Factory Default Crossover Setting: Full Range
Dimensions: 9-5/8"W x 14-9/32"L x 2-5/8"H (24.4cm) x (36.27cm) x (6.6cm)
FOTOS REAIS DO PRODUTO A VENDA
Repetindo o Link: http://produto.mercadolivre.com.br/MLB-897247379-amplificador-rockford-fosgate-punch-2501-mono-old-school-_JM
Repetindo o preço: R$ 499
Repetindo: com lacre original (raro num RF old school hj em dia)
Se ainda sobraram dúvidas, só dar um alô
hahahahaha
Pode comprar pelo ML que em caso de problemas fazemos a devolução por lá mesmo, está funcionando perfeitamente, tirei funcionando do meu penúltimo carro tem uns anos e não usei mais, empurrava um NAR 12sw3d6
