marcelomoti
[f] Testando cabos CCA e OFC
https://www.facebook.com/AClassSounds/videos/1228047330598450/
CCA wire is bad mmmmkDon't be fooled by cheap wire or cable prices. You are likely buying aluminum wire that is dipped in copper. And depending on the quality control of that factory you may be buying wire that is doomed to corrosion because of a bad calding process. Overall... At least buy OFC wire or at A best case scenario buy silver tinned OFC!
Veja a publicação original/mais informações
