erto
[vendo] hertz he4(R$350,00) e mtx 1200d(R$600,00) baixei p/
Modulos :
Hertz he4:
R$400,00
Mtx rfl1200d:
  • RMS Power Rating:
    • 4 ohms: 400 watts x 1 chan.
    • 2 ohms: 800 watts x 1 chan.
    • 1 ohm: 1200 watts x 1 chan.
    [*]Max power output: 2400 watts x 1 chan.
    [*]MOSFET power supply
    [*]Electronic Bass Control allows the user to adjust the bass from a remote controller that can be installed near the drivers seat
    [*]Power and protection LED indicators
    [*]Tuned Bass EQ (0-12 dB bass boost)
    [*]1 channel operation
    [*]Active Fan Cooling technology has air inlets along the top of the amp and hot air outlets on the sides
    [*]Gun metal gray chassis
    [*]Black end caps
    [*]Large brushed MTX Audio Gothic logo
    [*]Unique stackable design that allows them to be installed multiple configurations
    [*]Smart Engage technology makes it easy to add RFL amplifiers to any factory or aftermarket system
    [*]Nickel-plated RCA level inputs
    [*]Nickel-plated screw terminals
    [*]Variable low-pass filter (40-200 Hz, 24 dB/octave)
    [*]Subsonic Filter (20-50 Hz, 12 Hz)
    [*]CEA-2006 compliant amplifier
    [*]Frequency Response: 20-200 Hz
    [*]Signal-to-Noise Ratio: 62 dB
    [*]THD (Total Harmonic Distortion): <1%
    [*]Maximum Input Signal: 5V
    [*]Maximum Sensitivity: 250mV
R$700,00
Editado por erto
Novo preço hertz 400 e mtx 700 façam suas propostas
