Henrique A3
ZED audio X Sundown X ARC audio
Boa tarde!
Alguem pode me ajudar a escolher o amp do meus SET
Kit Mb Quart pvf
Sub Jl 10w1
HU kenwood excelon x994
Os amp na duvida são:
Draconia II - ZED Audio 4-Channel 400W RMS Amplifier
http://www.woofersetc.com/p-10076-draconia-ii-zed-audio-4-channel-400w-rms-amplifier.aspx
Rated power is 100 watts x 4 into 4 ohm or 200w x 4 into 2 ohm.
Bridged power is 200w x 2 into 8 ohm or 400w x 2 into 4 ohm.
The pairs of channels are independently bridgeable.
Two or four input configuration.
Channels 1+2 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 in addition feature SUB MODE which introduces a 24dB per octave variable subsonic crossovers and a 40Hz constant Q equalizer.
Level controls accommodate input levels up to 8.0v RMS.
Pre-amplifiers utilize a fully isolated power supply for zero ground loops.
Pre-amplifiers drive the main amplifiers in a fully balanced mode.
Class D amplifiers utilize high-speed high current low gate charge MOSFETs.
Fully regulated power supply delivers power independent of battery voltage.
There are a total of thirteen regulated power supplies.
The power supply utilizes six 110 amp MOSFETs in a source follower configuration for maximum bandwidth.
Low ESR 105°C capacitors are used in the power supply.
Very high efficiency owing to the smart power supply.
Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability.
Made in the USA
SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier
http://www.woofersetc.com/p-9257-sax-1004d-sundown-audio-100w-4-channel-amplifier.aspx
4/3/2 Canal Amplificador em ponte Classe-AB
Fonte de Alimentação MOSFET PWM
Estável em 4 ohms Bridged ou 2 Ohms estéreo Load
Filtro Subsonic variável
Independente 02/01 e 04/03 Canal variável Filtro High Pass
com 10 x Mudar Faixa selecionável
Independente 02/01 e 04/03 Canal Variable Low Pass Filtro
HPF / FULL / LPF Selecionável Mudar
Independente 02/01 e 04/03 Canal Selecionável Crossover Eletrônico Slope
Switch com 12dB e 24dB Octave
Controle de Nível Variável de Entrada
Sensibilidade de entrada: 200mV ~ 6V
Subsonic Filter: 10Hz ~ 500Hz
Sinal de entrada e saída de linha RCA Conectores
Way multi-circuitos Proteção (térmica / Over Current / Speaker Short / Speaker DC proteção)
Tensão Testado & THD: 14,4 V & Menos de 0,05% THD
Tensão de operação: DC10V ~ 16V Entrada de alimentação
Controle remoto com fio
FD 4150 - ARC Audio 4 Channel 640 Watt Amplifier
http://www.woofersetc.com/p-6858-fd-4150-arc-audio-4-channel-640-watt-amplifier.aspx
Output Power:
80 Watts x4 @4 ohms
160 Watts x4 @2 ohms
320 Watts x2 @4 ohms bridged
Transient distortion: < 0.005% @4ohms
Frequency response: 20Hz - 20Khz
S/N ratio (A wtg): > 105dB
Bass boost: + 18dB @45Hz
Input sensitivity: 250mV - 2.5V
Crossover: 55Hz-5.5KHz variable 12dB
Fuse: 30A x3
Dimensions: 10 3/8"(W) X 21 7/8 "(L) X 2 3/8" (H)
Algeum pode me ajudar
Cara eu nunca ouvi nenhum, mas quem já ouviu o ZED diz que é muito bom. A minha escolha seria o draconia.
Os sundown eu sei que servem bem para alimentar subs(os amps mono deles). E o Arc não conheço essa linha digital.
Corrigindo a informação, o Arc Audio FD4150, não é um amp classe D, "digital", mas AB.
A sigla "FD" do modelo é uma abreviatura de Foose Design, uma série feita pela Arc com o desenho da carcaça feito pelo famoso apresentador e projetista do programa overhaulin, Chip Foose.
Mas, se vc tem a disponibilidade e como trazer, tb iria de Zed...
Tambem estou mais inclinado para o ZED, meu unico medo é se der algum problema no amp. onde sera feita a assistencia.
Alguem sabe informar?
não sei, ZED Audio tem muitos fãs, e ao mesmo tempo tem muitos reviews negativos de amps dando defeito, de amp não tendo a potencia q declara, de mal funcionamento das linhas... isso me deixa com um pé atrás em relação a marca.
ARC audio é figurinha batida, já passaram vários aqui no fórum, é um amp muito bom, então se não quiser arriscar vá nele. não é o melhor amp q existe mas com certeza vai lhe agradar
agora se vc é um inovador, ou cobaia de testes, ou ainda ainda um gerador de opiniões, vc não vai partir pra figuras batidas e vai pegar o Sundown. Até onde sei da marca eles produzem produtos sólidos, seus subs são conceituados por serem sobredimensionados, seus amps tem fama de serem tanques de guerra qdo o quesito é um amp honesto e que não de defeito. qto a musicalidade... alguns dizem ser SQ, outros dizem ser SPL e outros dizem ser SQPL. então é algo q está nos meus olhos a algum tempo.... se puder, de uma olhada no circuito dos amps q vc pretende escolher... as vezes surpreendem
arc audio !!!!! putz eu fico curioso nesses massive audio , estão falando muito bem deles la no diyma e como satyricon falou ta até que barato até cotei com um representante deles 1 de 4 e outro de 2 canais o frete dos dois sairia 70 dolares!!!!
Editado por claytonzmvox
Ai surge a duvida sobre o ARC:
Pego o KS300.4 ou o Fd4150?
KS300.4 é superior a linha FD.
E ai Ianaconi
Estive lendo em forums gringos, o pessoal diz que o FD tem mais qualidade e componentes melhores.
Vc ja chegou a ouvir os dois?
Editado por Henrique A3
Sim. Já testei várias vezes ambos.
O FD é uma linha já descontinuada da empresa.
Beleza, obrigado pela ajuda...
como eu nçao quero dor de cabeça no meu SET vou comprar o KS300.4, ao inves de arriscar.... não quero ser cobaia...
Vc acha que vai ficar bom esse amp no meu SET?
Obrigado
Os zed tiveram problemas realmente na linha anterior a essa que está atualmente (com o Zed Leviathan I e Zed Kronos). Mas o pessoal que recebeu os últimos das linhas anteriores e esses das atuais eu não li nada ruim a respeito. Mas o Arc KS é uma excelente opção. Abs
Valeu Offtime pela informação.
Mas é aquela historia, vo pegar o ARC KS, para não correr o risco, pois pelo que andei lendo esse amp ja esta consagrado, sei que não é ol melhor, mas acho que ja vai me agradar.
Vo comprar na woofersetc amanha...
Valeu
Bom dia Henrique.
A WoofersETC não é um revendedor autorizado Arc Audio.
Recomendo a leitura: http://www.arcaudio.com/unauthorizeddealers.html
O modelo vendido no site deles é o antigo, que tem cerca de 5cm a mais de comprimento.
O modelo novo é mais compacto e teve algumas melhoras no design.
Acaba ficando mais vantajoso comprar o modelo novo no Brasil, em uma loja autorizada, e com garantia.
Cara... dependendo de COMO vc vai trazer isso até valhe a pena comprar aqui no Brasil mesmo. Os Arc (ao contrário da DLS) não tem um "fator Brasil" tão absurdo assim (coisa de +30%, contra algo como +130% no caso da DLS). Então dependendo do quanto vc ia gastar de frete até valhe a pena (pela facilidade de parcelar, garantia, assistência e tudo mais).
Isso eu tenho que elogiar, tanto a Arc como a Hybrid não enfiam tanto a faca no consumidor brasileiro, parabéns. :legal:
PS.: a woofersetc não é um lugar legal de se comprar. Primeiro, já li várias reclamações de pessoas comprando itens que aparecia como estoque e depois ficavam esperando e quando perguntavam eles diziam que não tinham mais o item. Segundo que eles vendem coisas de várias marcas sem serem os vendedores autorizados (Arc / Mcintosh). Só isso já diz muita coisa sobre como eles trabalham.
Vou pagar no amp. $390,00 + $71,00 de frete.
Totalizando em reais ja com IOF um total de R$790,00 reias.
Tenho quase certeza que não vai taxar na alfandega, pois tudo que comprei nada foi taxado.
Qual é o valor desse amp aqui no Brasil. Sera que vale a pena?
Pq vc acha que nao vai taxar?
Que milagre eh esse?
acho praticamente impossivel passar reto
Pra mim a taxa de "alívio" tá em 10%.
Das 10 vezes que comprei somente não fui taxado em uma!
E aqui no RS a facada é grande tem o Imp. de importação e mais o ICMS que é outra "facada"!
Se vier da loja então, pra mim pelo menos SEMPRE parou quando eu pedi de uma loja. E olha que eu já cansei de fazer compras fora viu...
Pode jogar 60% do valor do amp nessa tua conta aí...
Exatamente.
Se você for taxado (o que irá provavelmente ocorrer) vai acabar pagando mais caro do que o produto novo aqui no Brasil.
Além de aqui no Brasil ser um modelo menor e melhor (KS300.4v2), poderá comprar parcelado e com garantia.
Editado por Ianaconi
