larrycarvalho
subwoofer -gringo
LINKS EDITADOS
LINKS EDITADOS
LINKS EDITADOS
LINKS EDITADOS
LINKS EDITADOS
LINKS EDITADOS
qual desses subs tem uma melhor qualidade ? ou qual marca teria melhor qualidade tou com duvida mais entre boss e alphalink o que acham ?
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/Alphasonik_PSW812E.jpg
General Features:
Cast Aluminum CNC Machine Finished Alpha Basket
Motor Assembly Heat Sink
Kevlar-Reinforced Cone
TLTF J-Surround
High Tinsel Strength Two-Layer Surround
Exclusive Mounting Ring
Flat Progressive Rate Nomex Damper w/ Spiral-Woven Leads
8-gauge Lug-Lock Input & Output Terminals
TLTF J-Surround
Rated at 900 Watts RMS
92dB Efficiency
Frequency Response of 28Hz to 500Hz
135 oz. Double-Stacked Magnet
Dual 4-ohm 2-1/2" Voice Coils
Mounting Dimensions: Depth: 6 5/8" (168mm) Through Hole: 10 7/8" (276mm)
Diameter: 12 5/16" (313mm)
Subwoofers are usually sold as a single unit unless otherwise noted.
Authorized Internet Dealer
Warranty: 1 Year Manufacturer warranty.
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_CW125DVC.jpg
Sensitivity: 96 dB
RMS Power Range : 1200 Watts
Peak Power Handling: 2400 Watts
Impedance: 4 Ohm
Frequency response: 25-1000 Hz
Diameter: 15 Inch
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_CW127DVC.jpg
Power Peak: 2400W
RMS: 1200W
Cone Material: Non Press Cone
Voice Coil Size and Type: 2.5"
Efficiency 1 Watt/1 Meter: 95dB
Frequency Response: 25-1.5000khz
Impedance: dual 4 ohm
Mounting Depth: 7-1/8"
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_LAC129D.jpg
Sensitivity: 96 dB
RMS Power Range : 900 Watts
Peak Power Handling: 1800 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 2200 Hz
Diameter: 12 Inch
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/BossAudio_L12.jpg
Sensitivity: 96 dB
RMS Power Range : 1000 Watts
Peak Power Handling: 2000 Watts
Impedance: 4 Ohm
Diameter: 12 Inch
http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/Boss_Audio_P128DC.jpg
Sensitivity: 96 dB
Impedance: 4 Ohm
Frequency response: 25-15000 Hz
Diameter: 12 Inch
Editado por larrycarvalho
Alphalink achei muito carnavalesco... Se as opções são realmente só estas, pega logo o último que é ajeitado e o mais forte...
Subwoofers com potências acima de 500Wrms ter qualidade, acho improvável isso!
e entre um re rx ou um fosgate t1 ????
Não conheço este primeiro, o segundo já ouvi relatos de que toca muito, mas eu mesmo nunca ouvi! Aqui na minha terra seca dos trio-goianos só se ver pelas ruas Pioneer tocando!
Então a minha opinião é: Fosgate T1.
Acho que o RE em potencia e Fosgate em Qualidade... diz aii, daonde tu vai pegar? tenho interesse também em adquirir um alphasonik desses...
Se for o caso me manda MP
Editado por Gabriel Arthur
alphasonik eh melhor que RE e fosgate t1 ?
cara tenho 2 cidadania ih pah minha familia eh americana... final do ano vou visitalos
ai vou comprar pelo onlinecarstereo e mandar deixar la ou entao no ebay.com ;X
enfin..
maiss onlinecarstereo manda pro brasil tmb...
Interessante...
Creio que os Alphasonik nao sejam melhores que os Fostage e RE nao.
Quando comprar, quero ver seu set []-[]
cara pela onlinecarstereo o shipping do alphasonik pra BR fica 80 dolleta ;X vale a pena ainda...
