Henrique A3
    76
Tudo que Henrique A3 postou
  1. Boa tarde! Alguem pode me ajudar a escolher o amp do meus SET Kit Mb Quart pvf Sub Jl 10w1 HU kenwood excelon x994 Os amp na duvida são: Draconia II - ZED Audio 4-Channel 400W RMS Amplifier http://www.woofersetc.com/p-10076-draconia-ii-zed-audio-4-channel-400w-rms-amplifier.aspx Rated power is 100 watts x 4 into 4 ohm or 200w x 4 into 2 ohm. Bridged power is 200w x 2 into 8 ohm or 400w x 2 into 4 ohm. The pairs of channels are independently bridgeable. Two or four input configuration. Channels 1+2 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers. Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass. Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers. Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass. Channels 3+4 in addition feature SUB MODE which introduces a 24dB per octave variable subsonic crossovers and a 40Hz constant Q equalizer. Level controls accommodate input levels up to 8.0v RMS. Pre-amplifiers utilize a fully isolated power supply for zero ground loops. Pre-amplifiers drive the main amplifiers in a fully balanced mode. Class D amplifiers utilize high-speed high current low gate charge MOSFETs. Fully regulated power supply delivers power independent of battery voltage. There are a total of thirteen regulated power supplies. The power supply utilizes six 110 amp MOSFETs in a source follower configuration for maximum bandwidth. Low ESR 105°C capacitors are used in the power supply. Very high efficiency owing to the smart power supply. Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability. Made in the USA SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier http://www.woofersetc.com/p-9257-sax-1004d-sundown-audio-100w-4-channel-amplifier.aspx 4/3/2 Canal Amplificador em ponte Classe-AB Fonte de Alimentação MOSFET PWM Estável em 4 ohms Bridged ou 2 Ohms estéreo Load Filtro Subsonic variável Independente 02/01 e 04/03 Canal variável Filtro High Pass com 10 x Mudar Faixa selecionável Independente 02/01 e 04/03 Canal Variable Low Pass Filtro com 10 x Mudar Faixa selecionável HPF / FULL / LPF Selecionável Mudar Independente 02/01 e 04/03 Canal Selecionável Crossover Eletrônico Slope Switch com 12dB e 24dB Octave Controle de Nível Variável de Entrada Sensibilidade de entrada: 200mV ~ 6V Subsonic Filter: 10Hz ~ 500Hz Sinal de entrada e saída de linha RCA Conectores Way multi-circuitos Proteção (térmica / Over Current / Speaker Short / Speaker DC proteção) Tensão Testado & THD: 14,4 V & Menos de 0,05% THD Tensão de operação: DC10V ~ 16V Entrada de alimentação Controle remoto com fio FD 4150 - ARC Audio 4 Channel 640 Watt Amplifier http://www.woofersetc.com/p-6858-fd-4150-arc-audio-4-channel-640-watt-amplifier.aspx Output Power: 80 Watts x4 @4 ohms 160 Watts x4 @2 ohms 320 Watts x2 @4 ohms bridged Transient distortion: < 0.005% @4ohms Frequency response: 20Hz - 20Khz S/N ratio (A wtg): > 105dB Bass boost: + 18dB @45Hz Input sensitivity: 250mV - 2.5V Crossover: 55Hz-5.5KHz variable 12dB Fuse: 30A x3 Dimensions: 10 3/8"(W) X 21 7/8 "(L) X 2 3/8" (H) Algeum pode me ajudar
  2. Boa noite, Alguem conheçe esse amp? Quem me indicou foi o Julian da woofersetc.com, mas nauca ouvi falar Alguem ai pode me ajudar? SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier Rated power output RMS power, 4 ohm stereo 100W x 4CH RMS power, 2 ohm stereo 160W x 4CH RMS power, 4 ohm bridged 320W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover 50Hz~5kHz (CH1&2) 50Hz~5KHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope High Pass Crossover 50Hz~5kHz (CH1&2) 50Hz~5kHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope Variable Subsonic Filter 10Hz to 500Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz THD@RMS Watts <0.1% Channel Separation 75dB Fuse Rating 30A x 3 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 480(L)mm
  3. O Julian, da woofersetc me indicou esse amp para meu SET, alguem conheçe? SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier Rated power output RMS power, 4 ohm stereo 100W x 4CH RMS power, 2 ohm stereo 160W x 4CH RMS power, 4 ohm bridged 320W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover 50Hz~5kHz (CH1&2) 50Hz~5KHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope High Pass Crossover 50Hz~5kHz (CH1&2) 50Hz~5kHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope Variable Subsonic Filter 10Hz to 500Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz THD@RMS Watts <0.1% Channel Separation 75dB Fuse Rating 30A x 3 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 480(L)mm
  4. O Julian, da woofersetc me indicou esse amp para meu SET, alguem conheçe? SAX-100.4D - Sundown Audio 100W 4-Channel Amplifier Rated power output RMS power, 4 ohm stereo 100W x 4CH RMS power, 2 ohm stereo 160W x 4CH RMS power, 4 ohm bridged 320W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover 50Hz~5kHz (CH1&2) 50Hz~5KHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope High Pass Crossover 50Hz~5kHz (CH1&2) 50Hz~5kHz (CH3&4) (50-500 with x10 switch) Selectable 12 or 24 dB slope Variable Subsonic Filter 10Hz to 500Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz THD@RMS Watts <0.1% Channel Separation 75dB Fuse Rating 30A x 3 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 480(L)mm
  5. TO PENSANDO EM PEGAR O AMP ARC ks300.4 OQUE VC ACHAM, VAI CAIR LEGAL NO MEU SET?oU ALGUEM SUGERI OUTRO AMP? kIT mb QUART PVF 213 SUB 10W1
  6. Ola, a woofers, mamda sim... ja comprei Kit, HU, Sub, eles declaram valor mais baixo e chega bem rapido. Chega em 20 dias em media. Vai ai a dica..... NÃO PAGUEI IMPOSTO EM NADA!!!!!!!
  7. Ola, segundo o instalador é de 5", e tambem pesquisei bastante, os originais são de 4", mas o de 5" cabe de boa.
  8. A do A3 é assim tambem.... acho que vo leva em alguma loja de ribeirão preto pra fazer o tratamento. Alguem conheçe alguma? Obrigado
  9. E ai leoberto ta sussa na montanha Russa.! Caso eu pegue o SoundStream Class A/B, sera que a bateria ta conta do consumo? Sera que vai Precisar de capacitor? Valeu
  10. Não sei te falar se esse jl vai encaixar no nosso set, mas o preço ta bom, na woofersetc ta $499,00. Da uma olhada no site woofersetc.com, comprei meu set interio la, são confiaveis é rapidos
  11. Qual escolher para o SET? REF4.920 - Soundstream 4 Ch. 920 Watt RMS Class A/B Reference Series Power Amplifier ou Alpine PDX-F6 Mesmo valor $ 400,00 mais frete.
  12. e ai oshirorossi, vc sabe qual amp vai comprar???
  13. Se for pegar um PDX fico na duvida com sobre esses, pois todos tão certo no SET Ajuda ai: PDX-5 PDX 4.150 PDX-F6 Qual é a dif deles? Valew
  14. Vc sabe qual é a diferença do x994 para x995?
  15. A duvida continua.... Cancelei a compra do SoundStream refrence, pois o vendedor não timha mais o amp. Vou comprar o amp no site www.woofersetc.com. Alguem pode me dar uma ajuda pra escolher? Lembrando que o KIT tem 110 rms por lado e Sub 300 rms. Alguem ai pra me ajudar...
  16. Acabei de chegar da loja onde vou instalar o som, conversei com o instalador sobre o tratamento acustisco, Ele me disse que não vai tirar a parte interna da porta para colocar a manta, ele falou que vai colacar a manta somente em volta do mid e na lata da porta logo atras dele pelo buraco (apenas onde a mão alcança), é apenas um pedaço e não a porta toda.... Ele disse se desmontar a porta ela vai perder o isolamento original Oque vc me diz... ta correto?????????? Se o procedimento não for esse vou levar em outro lugar. Obrigado
  17. Melhor assim então, sera que tem necessidade de colocar 2 camadas na parte interna da porta, se não me engano a manta é de 3mm. Obrigado
  18. Tem alguem pra falar sobre o tratamento acustico???
  19. Boa Noite Henrique, meu chara!!!! Esse é meu primeiro SET, não tenho conhecimento em instalação, mas estou aprendendo bastante com os users aqui do fórum... Queria muito saber fazer a instalação, mas infelizmente por falta de conhecimento e tempo isso não será possível. Vou mandar tratar as portas e instalação na melhor loja da cidade, pelo menos parece ser a melhor, pois é única que vende equipamentos importados como focal, JL e outros. O cara da loja esta cobrando R$120,00 para tratar as portas, achei pouco perto de outros orçamentos que o pessoal escreveu aqui no forum. Ele disse que a porta do A3 ela já é bem fechada então não tem necessidade de colocar manta nela apenas na parte interna (lata) e em volta do Mid. esta correto? Ele usa uma manta de 3mm auto adesiva, será instalada com ajuda de um soprador. O TW VAI SER INSTALADO NO LOCAL ORIGINAL DA PORTA. Obrigado pela atenção abs Henrique
  20. Valeu Rickfvb, sua informão e sugestão foram de extrema importancia... muito obrigado, apos instalados eu posto os resultados abs
  21. Acho que vo atenuar o tw e -3, sera que fica bom? Tava pensando tambem caso eu não goste dor tw trocar o tw tipo o do morel tempo, vifa ou seas. Oque vc acha? essa troca é facild e fazer? posso usar o cross do kit
  22. Vou usar so o soundstrean para o set inteiro, ele tem 4x150 em 4 onhs, vi um user comparando ele com Mc440 e disse que são bem parecidos, qualidade muito boa. Mais obrigado pela sua opinião
  23. Boa Noite pessoal do SQ. Finalmente finalizei meu SET: HU: Kenwood excelon x994 KIT: MB Quart PVF 213 SUB: JL10W1v2 AMP: Soundstrean reference 4.920 RCA: Knuconceptz Kristal CABO SPEAKER: Knukonceptz CL3 e KBlue. Oque vcs acha? Vai ficar Bom? Mudariam alguma coisa? Depois de instalar posto mimha opinião. Abraços
  24. Obrigado pela ajuda de todos.... Comprei hoje o amp, comprei no ebay um soundstrean reference 4.920. Ouqe vcs acham?? Obrigado
  25. Pretendo gastar ate 500 dolares, pois vou comprar tambem na woofersetc. Se for comprar por aki, pretendo gastar ate 900,00 Obrigado
