Woods
Preparação Sl10 (vortec 2.2)
Ae galera
to ajeitando uma SL10 .. suspensao feita .. lata impecavel .. pneus 265 atras e 245 na frente .. tah baixa!!!
Mas agora to procurando dicas pra preparacao de motor .. pq eh fo** ter torque mas nao ter final fala ae!?!?
Se alguem tiver dicas de sites e experiencia com Vortec .. manda ae
aceito ofertas de Vortec 6cc
abraco
Woods
sua S10 é vortec 4.3 V6 ou 2.2 4 cilindros?? fico meio confuso o topico...
se for a V6 eu faria um escape bem livre com um 6x2 bem feito...mexia no chip... mais um bom filtro conico e ja deve fica bem interessante...
Production 1994–2004
Engine(s) 2.2L 120 hp I4
The Vortec 2200 (RPO codes L43 and LN2) is a straight-4 truck engine. It is entirely different from the Iron Duke. The 2200 uses an iron block and aluminum 2-valve pushrod cylinder head. Output is 120 hp (89 kW) and 140 ft·lbf (190 N·m). Displacement is 2.2 L (2189 cc) with an 89 mm bore and 88.00 mm stroke. 2200s were built in Tonawanda, New York.
LN2 applications:
Chevrolet S-10/GMC Sonoma (base models)
Chevrolet S-10 Blazer/GMC S-15 Jimmy
The 2.2 L version was revised in 1992 as the 2200 with multiport fuel injection, a new intake manifold, and larger valves pushed by a revised camshaft. This version increased power to 110 hp (82 kW) with 130 ft-lbs of torque, and allowed the idle rate to drop to just 600 rpm. Incremental improvements in engine power were made until the end of its life, with output reaching 120 hp when it was last used in 2002.
é uma vortec 2.2 4 cilindros .. mas eh mecanica .. rs
to fazendo escape e colocando filtro esportivo e vela tripolar ..
chip nao vi nada ainda .. tem alguma sugestao fora isso?
tem uma diferenca basica pro 6cc srsrs..
ENGINES Vortec 2200 (LN2) Vortec 4300 (LF6)
Cylinders 2.2L L4 4.3L V6
Cubic-Inch Displacement 134 262
Bore and Stroke (mm) 89.00 x 88.00 101.60 x 88.39
Compression Ratio 9.0:1 9.2:1
Bem nas antigas lí na revista Auto e Mecânica um S10 nacional 2.2 que o cara meteu um compressor no motor.
Segundo ele o investimento foi menor do que se fosse colocar um turbo e a bichina tava andando mais q as 6 caneco.
Falow.
Acho que um turbo nesse motor é meio sem mistério, deve ser meio parecido com o família II, talvez mudando pouca coisa... se for mesmo, a preparação não fica cara.
