*Arctic*
Se é Pra Bater.... Faça Direito !
quem manja ingReis, ve ae o cunhado dele comentando sobre o acidente e como ocorreu (+ - pq nem o motorista sabe direito)
What you see is what you get, i.e. there was no cutting of the vehicle prior to the pictures being taken.
It is my brother-in-law that you see holding the mobile phone, he honestly doesn't know the speed that he was going at but wasn't near as fast as he has done in the past on that particular part of the road.
Although the road was completely dry he said that it felt he was on ice and the car just careened into the tree. He actually called the emergency services and climbed out of the car by himself, he spent only a couple of hours in hospital, apart from a few minor scratches he got a bandage around his little finger, I told him if he's not already religious he should take it up ASAP!
The car WAS a pristine RS6 ABT, I was supposed to pick it up that very day to borrow it from him for a week as I've always wanted to try out the ABT version. He really should have simply told me that he didn't want me to drive his car I'm so happy he is alive and all in one piece.
I have referred him to this forum.
http://www.station.lu/newsDetails.cfm?id=16233
por***
RS6 - já é enjooada pra cara*** como se não bastasse ainda recebu algumas malcriaçoes da ABT ainda ...... o cara deve te abraçado o poste a muitos km/h
essa do "não sabia a que velocidade estava" é pra rir
carajo......... mentira que ta vivo
segundo consta a historia do cunhado:
ele costumava ir por essa mesma estrada mais rapido ainda, e nao sabe como bateu o carro.
nem a que velo estava.
mas disse que a pista, mesmo estando SECA, ele sentia como se estivesse no GELO e pimba com o carro na arvore.
a piadinha, fica por conta do cinhado, que dissse que gostaria de "testar" a versao RS6 ABT e pegaria o carro naquele dia pra ficar com ele uma semana, e se ele nao quisesse emprestar o carro era so dizer.
seca seca nao tava, com certeza ta com cara de que estava garoando um tempinho antes, dai nao molha nem lava a pista, deixa suja e transforma num sabao.
cagado esse gordinho....
kct..mas quanto fio tem isso por dentro hauhahuauhahuauahuauha
imagina o cara derrepente ta num carro conversivel huahauuhahuaauahu
comedia...mas deve te sido TEEENNSO na hora
não é cagado não viu, se a arvore que ele bateu estivesse 30 cm a mais pra esquerda ele perdia o braço! hahahaha
ng tirou foto do painel? com ctz ele ta la travadinho indicando a velo que tava na hora da batida.
caralh** mais essa po*** num tem air bag até no c.u??? :blink: pq só abriram dois????????????? :huh:
e se pelo que vi ele estava sozinho... então não para ter acionado o airbag do passageiro......... só se ele tinha alguma coisa em cima do banco.....
me corrijam se eu estiver errado..... [^]
Pelo pouco que eu sei, bateu os air-bairg abrem, independendo de ter ou não algum por exemplo no banco do passageiro.
Pq desintegro o resto do carro... se torceu tanto a lata imagina os air bag laterias!!
Air bags tem sensores em baixo do banco q fazem ele abrir na velocidade q o banco levemente se desloca para abrir no tempo certo.. provavelmente os sensores nao detectaram deslocamento de massa nos outros bancos alem do proprio banco e nao abriu as bolsas de ar....
o cara levou uma puta sorte nessa ai hein....
Alguem pode traduzir essa po***!?!?!?
Fiquei curioso!!
