RsAcOlL
Buick Gsx
Motor
LS-2 Built by Wheel To Wheel Powertrain
Chassis Dyno and Computer Super Tune HiTechMotorsport
Computer / ECU Big Stuff 3
Drivetrain
Tranny 4L60E / 4 Speed w/ Overdrive Built by ATD
Converter 9.5" 3600 Stall / Built by PTC
Driveshaft Aluminum
Rear End 12 Bolt / Moser Engineering
Gears 3:73 Ratio / Auburn Posi Unit
Stock Wheels Factory 15" Buick Rallye Wheels
Pro Touring Wheels 17" Billet Buick Rallye Wheels / Newstalgia Wheel.Com
Front Tires BF Goodrich
Rear Tires Mickey Thompson Drag Radials
Cooling System / Fuel System
Radiator Aluminum Built by Ron Davis Radiators
Fuel System Stock Tank converted by Ricks Hot Rod Shop
Exhaust, Brakes & Suspension
Exhaust Torque Tech 3" Aluminized Mandral Bent w/ X-Pipe
Headers Hooker
Mufflers Flowmaster Super 40 Series
Front Brakes Wilwood Light Weight Discs
Rear Brakes Wilwood Light Weight Discs
Rear Control Arms (Upper) Edelbrock
Rear Control Arms (Lower) Speedtech Performance / Billet Aluminum
Front A Arms (Top & Bottom) Global West
Front Shocks & Springs QA-1 / Coil Over
Rear Shocks QA-1
Rear Coil Springs Global West
Interior
Seats Factory Buckets
Shifter Factory Floor Shift w/ 4 Speed Overdrive Conversion Kit
Gauges Factory Oil, Temp, & Fuel
Aftermarket Gauges Auto Meter / Temp & Oil
Tach (Outside - Hood Mounted) Factory - GSX Option
Aftermarket Tach (Inside) Auto Meter
Steering Wheel Factory GSX Sport Wheel (3 Spoke)
Heat & Air Conditioning Vintage Air
Features
Air, Tilt, Power Windows, Power 4 Wheel Disc Brakes, Power Steering, Fuel Injection, Performance Suspension
Valeu por ter me lembrado...tava esqueçendo... :legal:
