Nulo
Dual 12" Audiobahn
estou montando um novo som pro mu carro, e estou com dúvidas, gosto de graves profundos e macios, e ví esse KIT
Dual 12" Audiobahn AW1251T Subs + Box + Amp
Especificaçoes
BRAND NEW PAIR OF AW1251T SUBWOOFERS
12" High Performance Subwoofer
45 OZ. Strontium Magnet
2" 4 Layer Black Aluminum Voice Coil
400W RMS Power Handling Per Sub
800W RMS Power Handling Per Pair!
24Hz - 1kHz Freq. Response
92.1dB Efficiency
Awesome Flame Design!
Bumped & Vented Polished T-Yoke
Poly Coated 2 Layer Non Pressed Paper Cone
Lug Lock Terminals
Dual 4Ω Voice Coils Per Sub
1 Ohm or 4 Ohm or 2 Ohm Stereo Operation
Rubber Gasket & Magnet Mesh Cover
5-1/4" Mounting Depth
AMPLIFIER
Brand New Ultra Linear UL2600D 1200w Car Amplifier
MOSFET Class A/B Circuitry
DC To DC Circuitry
Power / Protection LED
Low / High Level Inputs
Line Level Outputs
Chrome Plated Screw Terminals
Thermal / Short / Overload Proection Circuitry
Variable LPF / HPF Crossover
Adjustable Input Sensitivity
2Ω Stereo Stable
Bridgeable
Tri-Mode Operation
2x 25A Fuses
Frequency Response 20 - 20KHz
S/N Ratio > 90 dB
Dimensions: 10"W x 2-1/2"H x 12"D
1200W Max Power
300W x 2 RMS @ 4Ω
450W x 2 RMS @ 2Ω
600W x 1 RMS @ 4Ω
esses audiobhans são bons pro que eu quero ?
ou entao eu estava pensando em comprar esses 2 aqui
Audiobahn AW1206T 12" 1100W RMS Chrome Flame Q Subwoofer
Brand New Audiobahn AW1206T 12" Subwoofer
12" Dual Voice Coil Subwoofer
1100W RMS / 2200W Peak Power
Dual 4 Ohm Voice Coils
Protective Chrome Finish
2.5" 4-layer Voice Coil
Vented Back Plate For Cooler Operation
Stamped & Balanced Aluminum Cone
Flame Q Design in Basket, Magnet and Cone
Double Stacked 120 oz. Strontium Magnets
2" Foam Surround For Linear Cone Travel
20-500Hz Frequency Response
96.4dB Sensitivity
Mounting Depth 6-3/4"
Cutout Diameter 10-7/8"
Multi-Connect Lug Lock Terminals
Audiobahn Window Sticker
Allen Wrench For Speaker Terminals
Wooden Gift Case
e esse amplificador
Brand New A8002V Audiobahn 2 Channel 800W RMS Intake Series Car Amplifier
Double Sided Glass Epoxy Circuit Board
High Gloss Chrome Plated Finish
Variable High/Low Pass Crossover
Variable Subsonic Filter
Bass Boost
3-Way Protection
RCA Throughout Connections
Digital Volt Meter with Cobalt Blue Illumination
Air Induction Fan Cooled
Cobalt Blue Illumination Side Stripes
2 Ohm Stereo Stable
MOSFET Power Supply
2x 400W RMS @ 2 Ohms
2x 200W RMS @ 4 Ohms
1x 800W RMS @ 4 Ohms
Dimensions: 12" x 2-1/8" x 12-1/2
agora pra voz estou seriamente em dúvidas.....
nunca ví esses kit's que vem com peuenos "falantes" com cross própros, eles aguentam o som alto ? tipo, o om vai ser pra ficar dentro do carro mesmo, mas vai que estou num lugar e a galera quer curtir um somzim tambem....
gostei desse, ví ele na mao e gostei muito
Audiobahn ABC525T 5.25" Matched Component Speakers
Brand New 5.25" Matched Components
120W Continuous Power Handling / Pair
240W Maximum Power Handling / Pair
35HZ - 25KHZ Frequency Response
90dB Sensitivity
15 Oz. Magnet Structure
Honey Comb Cone
Butyl Rubber Surround
2 Layer Hi-Temp Voice Coil
1" Silk Dome Tweeter
Soft Dome Tweeter w/Neodymium Magnet
Surface or Flush Mount Tweeters
12dB/Octave Separate Passive XOvers
4 Ohm Impedance
All Mounting Hardware
Metal Grills
2-1/8" Mounting Depth
Está indo pelo caminho errado...
Morando nos EUA e querendo AudioBahn?
Ow cara, vai atraz de Kicker, Fosgate, MTX e etc...
Abraços.
Abraços.
Poxa cara , tem uns AudioBahn que meu pai do céu , tem um XMAX absurdamente enorme !
achoq ue dependo do que o cara quer gastar e VER !
Digo VER , pois AudioBahn é bem Tunning !
Concordo com o Abreu.
Não sei não, esses equipamentos muito tunados... sei lá.
Aproveita que vc ta no paraíso e traz coisa que valha a pena. Lá é mt barato.
Abraços.
Xmax não é nada Guto.
A AudioBahn usa o apelo visual para vender seus produtos, esquecendo-se da função dos mesmos, que, é bem mais do que meros enfeites.
Não que sejam produtos ruins, mas comprando com similares da Fosgate, Kicker e MTX, você vê claramente do que estou falando.
AudioBahn é concorrente direto da Boss, ambas tem alguns bons produtos, mas a grande parte, não vale o que custa. São 2 marcas que usam o apelo visual para vender.
Essa caixa por exemplo: Fica claro de cara que ela não tem volume suficiente para 2 sub-woofers de 12", mas, quem tá ligando para o volume!?
"Olha lá os sub-woofers cromados, esse acrilico na tampa e os 4 dutos na frente, nossa, é muito show, muito tuning, deve ser muito melhor que aquele JL-Audio todo preto que vimos no carro daquele outro cara..."
Kkkkk... Abraços.
Abraços.
Kkkkk... Abraços.
foi o que disse
VER = TUNING
mais Xmax é muita coisa sim hahahahahahahaha é legal de VER tb hahahaha
intao galera! me dê uma luz ai !
vou comprar meus equipementos nessa página
http://www.cardomain.com/shoptype/Subwoofers
me indiquem um sub e um amplificador bom!
Quanto quer gastar é a pergunta...
Exato...
Até quanto dolares vc pode gastar?
Abraços.
Não se esqueça q a comparação com as marcas citadas não teve influência de preço né? Pois delas, a Audiobahn é a q tem os produtos mais baratos...
Tá na gringa, quer custo x beneficio?? Não eskeça de olhar tb os DB Drive...
vamos jogar 1.500 doletas
só pra falantes e amplificadores
fora o dvd player que já comprei, com gps, aqui é impossível ficar sem
pioneer AVICN3
esse é bom ? SUB
pioneer AVICN3
esse é bom ? SUB
Hum... 1500 dolares dá para pegar coisas muito boas...
Vamos as compras!
Mas antes responda algumas perguntas:
- Você quer que tipo de som? SPL com qualidade?
- Quanto sub-woofers? Lembre-se que para 2 sub´s de 12" é necessário uma caixa com em torno de 112L livres.
- Qual o carro que vai instalar o som? (preciso saber a furação do carro, para escolher o kit 2 vias)
Seguestões:
- Fosgate P4002 -> $190 -> Para o kit 2 vias
- Fosgate P8002 -> $400 -> Para os sub-woofers
- Kit MB-Quart RVF-216 -> $255
- 02 Sub-Woofer Fosgate P312D4 -> $500
Total: $1.345,00
Lembre-se que você vai precisar de bateria extra para esse sistema.
Mas com certeza ficará MUITO forte e com qualidade excelente (se bem montado).
Tentei montar um setup com amplificadores da Kicker tambem, mas passa um pouco dos 1500 dolares. Os Fosgate estão com preço muito melhor.
Abraços.
Vamos as compras!
Seguestões:
Total: $1.345,00
Abraços.
Entao, o carro é um Mazda 3 (nao me lembro dele no brasil) axei ate uma foto com som FOTO, mas claro que o meu nao quero isso tudo, estou procurando um bom som de qualidade pra ouvir um trancezim, ou talvez um pouco de música unpluged, que dê graves gostosos e boa voz. Quero somente um sub, um L5 da kicker, 12" ? seria opçao ?
Vamos as compras!
Seguestões:
Total: $1.345,00
Abraços.
Vá então de L7...
Kicker S12L72...
Mantenha os mesmos amplificadores.
Vai ficar muito bom.
Abraços.
HIFONICS GOLIATH XX3212 12" SPL 6400 WATTS SUBWOOFER
Specifications:
3200 watts RMS power
6400 watts max power
Quad 2-Ohm Voice-Coils (QVC/2+2+2+2 Ω)
For 1/2-Ohm, 1-Ohm, 2-Ohm, 4-Ohm, and 8-Ohm Applications
18-3/4lb./300oz. Triple-Stack Magnet Assembly
4-inch Bi-Flair Black Aluminum Voice-Coils
High-Strength Composite Silver & Fiber Glass Cone
Fs = 39.63Hz
Qts = 0.37
Vas = 17 Liters
Xmax = 25mm
SPL = 98.29 dB @ 2.83v
alguem já ouviu falar nisso ?
Com certeza o Abreu te deu uma ótima opção... Corra desses subs com apelo tunning/xunning ou com esses nomes "pavorosos", ainda mais que para o objetivo que vc postou, os mesmos serão somente spl... duvido que com alguma qualidade! Esses nomes "Golias" daí me fez lembrar os " Papões " daqui :P
Specifications:
Fs = 39.63Hz
Qts = 0.37
Vas = 17 Liters
Xmax = 25mm
Esse Goliath não deve ser muito bom na qualidade, fs = 39,63, mas pra SPL deve ser muito bom, SPL = 98,29db (não é muito para um sub de 12"?) e Xmax de 25mm. Eu não aconselho um sub desse não, como o abreu disse, procure outras opções, coisa que nos EUA não está em falta. hehehe pra som né [-]
Abraços,
Gabriel
com a ajuda do abreu, comprei um dos ítens já
comprei com essa caixa já, U$ 300
Features
12" Solo-Baric L7 Subwoofer
Huge Flaired Port For Increased Output
Integrated Heavy-Duty Push Terminals
3/4" Medium Density Fiberboard (MDF) Construction
High Density Automotive-Grade Carpeting
Dual Voice Coil Subwoofer Wired For A Single 2-Ohm Load
750 Watts RMS/1500 Watts Peak Power Handling
Dimensions: 18 3/4" W x 16" H x 18" D (at bottom) to 14 11/16" D (at top)
pra casar com esse sub, o Kicker 06ZX750.1 750W Class D Mono Amplifier seria a opçao ?
Features
RMS Power: 750W x 1 @ 2 ohms
RMS Power: 375W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: <1 %
Speaker Level Inputs
Preamp Outputs
LP Built-In Crossovers
Bass Boost: 0 - 18 dB
Frequency Response: 25-200Hz
Signal to Noise Ratio: 62 dB
Advanced chassis with extruded aluminum heatsink
Efficient class D circuitry
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
Defeatable 25 Hz subsonic filter
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Included remote KickBass control
Fully CEA-2006 compliant specifications for real-world
estou olhando agora o component speaker
axei muito interessante esse Infinity Kappa 60.7CS
Speaker Specifications:
Speaker Size: 6-1/2"
Design: 2-Way Component System
Tweeter Design: Dome
Tweeter Composition: MMD
Woofer Composition: Plus One woven-fiber-glass
Woofer Surround: Rubber
Sensitivity: 95 dB
Frequency Response: 45 Hz - 25 kHz
RMS Power Handling: 90 watts
Peak Power Handling: 270 watts
Impedance: 2 ohms
Top Mount Depth: 2-3/16"
Bottom-mount depth: N/A
Cutout Dimensions: 5"
Warranty: 1-year SE
ou esse Rockford Fosgate Power T162S 6-1/2"
Product Description:
6-1/2" 2-way Neodymium component system
1.1" Inverted hard anodized aluminum dome tweeters
Hard anodized parabolic aluminum cone
Cast aluminum basket
Aluminum former
Embedded tinsel leads
Foamed rubber surround
Cast aluminum audiophile 12dB LP/24dB HP crossover
Tweeter attenuation
Multiple tweeter mounting configurations
60-22k response, 89 dB
100 watts RMS/200 watts Peak
External Crossovers Included
Grilles and hardware included
e agora ? qual dos dois ?
e para toca-los um Kicker 2-Channel Amplifier (KX200.2)
• 70 watts RMS at 4 ohms
• Protection circuitry • Speaker-level & RCA inputs
• High or low pass crossover
