[RS]Alto falante Bluster 4k2 15 Polegadas 2100 Rms
alto falante de 15 4k2 https://mercadolivre.com/sec/2bou4xK
MEDIO DE 10 POLEGADAS BLUSTER https://mercadolivre.com/sec/2kawXNc
DIAMETRO NOMINAL: 15 Polegadas
DIMENSOES DO FERRITE: 220 X 110 X 25 mm
DIAMETRO DA BOBINA: 4 Polegadas
ALTURA DO ENROLAMENTO: 30 mm
ALTURA DO GAP: 15 mm
VOLUME OCUPADO NO GABINETE: 6 6 Litros
MATERIAL DO CORPO DA BOBINA: KAPTON
MATERIAL DA CARCACA: ALUMINIO
MATERIAL DO FIO DA BOBINA: CCAW
QES: 0 54
RE: 3 2 OHMS
Z NOMINAL: 4 OHMS
BL: 18 85 TM
POTENCIA MAX: 4200 WATTS
POTENCIA RMS: 2100 WATTS
Resposta de frequencia : 40 a 2300 Hz
FS: 49 HZ
QMS: 7 56
VAS: 55 L
CMS: 54 um/N
MMS: 194 7 G
SD: 0 085 SQ.M
XMAX: 11 25 MM
QTS: 0 50
NO: 1 2
1-W/1m SPL: 92 8 dB
