[SMD]Building an Awesome Clear Acrylic LED Lit Amp Rack + Custom Fuse platform | 4 Amplifiers Pt.2
I know this was a long video and I was kinda jumping all over the place. But I had no choice. I could not finish the amp rack or that bottom plate until I knew where I was going to put the fuse block and ground distro. I should be able to pass wires up through those slots now. Hopefully I can make it look clean. For those that stuck around and watched all of this boring video I appreciate you
Check out the amp unboxing and some early CAD Cardboard aided design work here https://youtu.be/jMRxuDidGgg si s-k4Ba3f5UUlyciT - If you have been following my channel long enough you know I almost always qFrankenstienq complicated pieces and parts for my amp racks trim panels etc and work them until they look good before I even think about using the more expensive materials. There is probably lots of ways to do this but it s how I have always done it. There are lessons to be learned in my videos even if you don t notice them right away. Next up I am hoping to get all the amps mounted to the rack with the elevated angles and then get the bottom tray done as well. Once I have a place to mount the fuse blocks and ground bars I can start running wire Oh and like I said in the video this is only half the story right now. These amps ALL light up with thier own RGB colors It s going to look bonkers when it is done. I think Stay tuned and subscribe More on the way soon. Thanks for watching if you did
Shop for all your car audio at the SMD Store: https://wccaraudio.com/
These amps are a collaboration with DS18 Check out DS18 s site here http://www.ds18.com
XS Power Batteries can be found here: http://www.4xspower.com
for the most solid amazing boxes check out Gately Audio http://www.gatelyaudio.com and tell them you saw this video
Find the dual alt kit in this Yukon and more here: https://www.mechman.com/bracket-kits/
The number one sound deadener and my favorite http://www.secondskinaudio.com
Visit my favorite e-tailer for all your electronics here http://www.sonicelectronix.com
For Business Inquiries: info stevemeadedesigns.com
car audio amplifiers
