[SMD]New Lithium battery bank + "direct fit" under hood AGM Swap | Yukon 3.0 Sound System install
So far we have done lots of stuff in this Yukon 3.0 upgrade series. Before I can go to far on the amp rack I have to start thinking battery bank. I wasn t sure where I was going to put these until they showed up. There isn t too many places I could fit these so I chose the spot I did. I think it worked out pretty good Made with .080 aluminum it is strong enough to do the job and the center support really helps. The seat itself also will hold everything in place. Now I just need to finish the amp rack about 30 done and then run some wires. Stay tuned and subscribe More on the way soon. Thanks for watching if you did
XS Power Batteries can be found here: http://www.4xspower.com
for the most solid amazing boxes check out Gately Audio http://www.gatelyaudio.com and tell them you saw this video
Find the dual alt kit and more here: https://www.mechman.com/bracket-kits/
Shop for all your car audio at the SMD Store: https://wccaraudio.com/
The number one sound deadener and my favorite http://www.secondskinaudio.com
Visit my favorite e-tailer for all your electronics here http://www.sonicelectronix.com
For Business Inquiries: info stevemeadedesigns.com
car audio batteries
