[SMD]Twin Turbo 1,000 HP Escalade on 28” Forgiatos & 6 12” Subs
Full sound system build here https://youtu.be/DSQmyD61Ak4 si HAzjqPGYWK-jIe3X
see almost everything else including the engine/turbo stuff here https://www.youtube.com/watch v iWQA9n8MYH4alist PLbHKD58RLZvVdPQzxwQ2R7xEFgOLkB57k or one of the many video s uploaded to my channel over the years.
How is it 1000hp read below.
Engine Parts List might be missing a few items
Armageddon L861000 Shortblock
Forged Pistons Rods and Crank
New Main and Rod Bearings
Total Seal Ring Set
ARP Mainstuds
Armageddon Street Fighter Cam Package
LT1 Camshaft lobe lash cap
Comp Cams Cam Phaser Limiter
Pushrods
Pac racing polished dual valve springs
PRC Viton valve seals
Titanium retainers hardened spring seats
DOD Delete Kit
Balanced and Blueprinted
Upgraded Fuel Pumps Engine and Tank
Upgraded Injectors
Ceramic Spark Plug Wires
Dual Catch Cans
Kooks Headers / Midpipe
Kooks High Flow Cats
QTP Electric Cutouts
Magnaflow 3.5q Stainless Exhaust
Fully built Tranny and Torque converter with everything you can possibly do to it
.....and more
28q Forgiato Concavo 3 Piece Wheels
Pirelli 295/25/28 Tires
Lowering kit: 1.5q Front / 3q Rear Slightly modded for more drop
Wilwood TX6R / Aero4 Big Brake Kit
Custom Powdercoat White
Front: 6 Piston Caliper / 16q Rotor
Rear: 4 Piston Caliper / 14.25q Rotor
Steel Braided Lines
Blacked out chrome trim
The system:
4 D amore Engineering qA seriesq Super High End Class A/AB 1500w Amplifiers 2 4 channels 2 2 channels doing over 3kw each and backed up by XS Power Titan 8 Lithium 14v Batteries charging at 16.4v pushed by a Mechman 400a alternator. A lithium 12v battery up front for the actual vehicle which get s it s juice via a custom voltage step-down box i made see previous video s . B2 Audio 3 ways 2 set s in each door on the highs in custom made door pods and 6 B2 Audio 12q subs on the lows in an all acrylic slot ported enclosure. Plenty of 2/0 and even 4/0 power wire from Skyhigh car audio delivering the massive power needed to push these amplifiers. These are NOT your every day Class D amps. Class A/AB is very demanding but worth it It sounds sooo good so far. Of course there will be more tweaking and tuning on my own time but you get to see the basics here.
