[SMD]Building an Escalade Amp rack - LED Lit Acrylic, Lithium Batteries and 4 $8,000 Amps Live AMA pt.1
visit: http://www.stevemeadedesigns.com
Looking back at some of my favorite projects LIVE Ask me anything about what you are seeing I will try to explain
The A1500.4 and 1500.2 is a True Dual Stereo dual mono for the 1500.2 Design providing better stereo separation and imaging as compared to traditional stereo amplifiers - the chassis being the only thing common between channels. In an effort to provide the very best signal to noise ratio and lowest distortion possible 109 dB A-weighted and 0.027 THD N the amplifier utilizes a Mirror Image Design with positive and negative output signals of each channel generated using identically mirrored circuitry. Each of the two channels is also a mirror image of the other. A1500.4 operates the current amplifier devices in class A/B operation and the voltage amplifier devices in pure balanced Class A mode offering a realism and truth to the source never before available from a mobile power amplifier.
From a design standpoint the A1500 utilizes separate PCBs for the voltage amplification stage and each of the 2 or 4 channels has its own and current amplification stage to maximize the signal to noise ratio so that it s dead silent. It has been designed from the ground up around the highest quality components available at any cost including Nichicon Fine Goldt capacitors Nichicon Muset audio capacitors 8 On-Semiconductor complementary bipolar junction transistors per output section per channel Burr Brown Op-amp and non-inductive resistors all assembled on 4-layer heavy copper PCBs Its dual stereo channels can be wired as two single channels with double the output voltage for applications where high power is required. Finally it includes two pair of gorgeous LED output meters to indicate actual amplifier power for each of the 4 channels as well being used for self diagnostics during a fault condition.
https://www.youtube.com/channel/UCAn7KfxuoxUur8dP-lFCjdA/join
