[SMD]SMD Ultra Series ANL Fuse Blocks
visit: http://www.stevemeadedesigns.com/board and join our friendly knowledgeable forum today Learn a few things teach a few things have fun We love car audio
Shop car audio at my store: https://wccaraudio.com/ Fast shipping GREAT service a Quality products
SMD Ultra series ANL fuse blocks heading out the door. A blue on black double A gloss black on black triple and a matte black over white Six spot. Tons of color combors available Double set pin design for maximum contact and holding power. Protection from while also looking like for your system. We have red blue black white yellow green black and clear acrylic for the baseplates and an almost infinite number of acrylic top trim colors to choose from. What color combo would you pick http://www.wccaraudio.com or ask your favorite dealer about them.
The SMD Ultra Single XL Fuse Block is our TOP OF THE LINE series when it comes to ANL Fuse Blocks Starting with a thick 3/4q HDPE CNC milled baseplate a giant slab of aluminum on each end with double stainless steel set pins will keep your wire tight and in place for maximum contact with the block. More stainless fasteners will keep the fuse snug in place and resist heat build up that can happen with an inferior connection. These blocks can easily accomodate 1/0 2/0 and even up to 4/0 power/ground cable. Machined recessed inlets allow the wire jacket to countersink into the block which makes for a super clean install without any unsightly copper wires showing up to 2/0 . Ultra Series ground/distro and split blocks have several inlets that are made for 4ga and 2/0 cable but you can use smaller or slightly larger wire no problem at all with them Aluminum/ABS standoffs made in house will keep the 3/16q clear acrylic lid firmly in place with 4 more stainless steel fasteners. A true masterpiece of a fuse block and the perfect addition to your masterpiece of an audio system Made with pride in Northern California USA these blocks will be sure to give you a lifetime of great service.
If you watch this channel enough you know I don t necessarily use my channel to try to sell products. I make them I use them in my builds and let the product speak for itself though. But this time I wanted to show off the latest from the SMD fuse block family. The Ultra series We make SEVERAL types of fuse blocks from basic to MASTER PIECE. Actually they are all masterpieces as we take extreme pride in everything that we build. Check out http://www.wccaraudio.com to see more of those if you got a moment. If you need a custom color for any series of block we have so many combo s to choose from it is crazy Thanks for checking out the new blocks if you did And if you are a current customer and run SMD blocks or other products let me know in the comments. Let me know where you are from
Thanks for watching don t forget to subscribe to my channel
For Business Inquiries: smdbizinq gmail.com
car audio sound
