[SMD]Six Channels 1500 watts! CT Sounds ATv2-150.6d Car Audio Amplifier Unboxed, Powered up
visit my site http://www.stevemeadedesigns.com/board Join today
There are lots of options with a 6 channel amp. You can run all subs with it you can run a set of 3 ways fully active with it no passive crossovers you can run mids highs AND subs...whatever you want I would have tested this amp on the Dyno but it is hard to test the entire amp all channels driven at the same time when the AD-1 Amp Dyno only has 2 channel input. Every CT Sounds amp i have ever tested has done it s rated power and then some so this one should be no different. I chose to run a set of 3 ways because that is probably what I would do with it. But you can easily run the entire system in one package if that is how you want to do it. Thanks for watching if you did
For info on this amp visit: https://www.ctsounds.com/collections/multi-channel-amplifiers/products/at-150-6d
https://www.youtube.com/channel/UCAn7KfxuoxUur8dP-lFCjdA/join
For Business Inquiries: smdbizinq gmail.com
car audio amplifier
