marcelomoti
[VENDO] Amplificador Focal Solid 1, mono, R$700 São Paulo/SP
R$700 (comprando junto com o Focal Solid 4, fica R$1200)
localizado em São Paulo/SP
Testado, funcionando
Não acompanha nenhum outro acessório como tampa, parafusos adicionais, etc que não apareceram nas fotos
Focal Solid 1 Mono Subwoofer Amplifier
Each Focal Solid amp features low-noise inputs that let you connect to almost any receiver — even your factory stereo. Available in black or red, this clean-looking, unassuming amp features an aluminum chassis that disperses heat efficiently, so it runs cool even when you're pushing your system hard.
The power and control you need
Gain and filter controls
The Solid 1 mono amp delivers up to 470 watts RMS to your subwoofers, producing remarkably accurate and hard-hitting bass. This amplifier's controls include a phase-reversal switch, an adjustable bass boost, and low-pass/subsonic filters that shape output precisely, so you get the best possible performance from the sub and enclosure in your vehicle.
Reliable sub performance
Short-circuit, over-current, and thermal overload protection circuits ensure that this amp will reproduce your bass notes with breathtaking realism for years to come. A wired remote lets you adjust the level of bass on the fly.
Product highlights:
mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (470 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
variable low-pass filter filter (50-150 Hz, 12 dB/octave)
subsonic filter (35 Hz, 24 dB/oct)
variable bass boost (0-9 dB at 50 Hz)
wired remote level control included
Class-AB amplifier design
frequency response: 10-150 Hz
preamp- and speaker-level inputs
preamp outputs
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 25A x 2
11-13/16"W x 2"H x 7-7/8"D
20220330010945focalSolid1_15.jpg20220330010945focalSolid1_14.jpg20220330010945focalSolid1_13.jpg20220330010946focalSolid1_12.jpg20220330010945focalSolid1_11.jpg20220330010944focalSolid1_10.jpg20220330010944focalSolid1_09.jpg20220330010943focalSolid1_08.jpg20220330010943focalSolid1_07.jpg20220330010942focalSolid1_06.jpg20220330010942focalSolid1_05.jpg20220330010942focalSolid1_04.jpg20220330010942focalSolid1_03.jpg20220330010942focalSolid1_02.jpg20220330010941focalSolid1_01.jpg
Editado por marcelomoti
desconto
Visitante
