[Nakamichi]Nakamichi NQ921B CD Receiver SPECIFICATIONS General... Power supply Requirement:DC 12V Maximum power output:50W ×4CH Spe...
243121988_3178540802382013_4585475982922644887_n.jpg?_nc_cat=104&ccb=1-5&_nc_sid=8024bb&_nc_ohc=vr87nRiWOLAAX_QMS_H&_nc_ht=scontent.fvca1-2.fna&oh=ef07eb210b2fa50932e3c1fcb4d43a06&oe=6176032D
Nakamichi NQ921B CD Receiver SPECIFICATIONS General... Power supply Requirement:DC 12V Maximum power output:50W ×4CH Sperker impedance:4-8Ohm Unit Dimensions(W×H×D):178×160×50mm Weight:1.3 kg Fuse:10A RADIO FM "Frequency Range:87.5MHz-107.9MHz(USA) 87.5MHz-108.0MHz(EUROPE)" "Channel step:200 KHz(USA) 50KHz(EUROPE)" AM "Frequency Range:530KHz-1710KHz(USA) 522-1620KHz(EUROPE)" "Channel step:10 KHz(USA) 9KHz(EUROPE)" USB Usable Audio Fromats:CD/MP3/WMA USB Port Type:2.0 USB charging:5V/1A Frequency Response: 20Hz -20 KHz S/N Ratio:60dB BT Supported Bluetooth Profiles:A2DP,AVRCP,HFP Frequency Range:2.4GHz spectrum
