Modulo bem conservado, sem datelhes. Qualquer duvida entrar em contato.
Valor: 1.000 pelo ML ou 1.200 no anuncio sem juros.
https://produto.mercadolivre.com.br/MLB-1312158806-modulo-phoenix-gold-sd-13005-5-canais-_JM
SD1300.5 SPECIFICATIONS
Frequency Response: ± 1dB from 20Hz to 20kHz
Signal to Noise Ratio: >100dB
High Pass Crossovers: 12dB per Octave
Low Pass Crossover: 18dB per Octave
High Pass Crossover Range: 15Hz to 250Hz
Low Pass Crossover Range: 30Hz to 300Hz
Bass Boost @ 45Hz: 0 to +18dB
Low Level Input Range: 200 millivolts to 8 volts
Front and Rear Channels Lowest Load: 4 ohms Bridged or 2 ohms Stereo
Subwoofer Channel Lowest Load: 2 ohm
Typical Efficiency: 70%
Damping Factor: Greater than 200
RMS Power 14.4Vdc =1% THD:
80 x 4 @ 4 ohms Stereo
125 x 4 @ 2 ohms Stereo
250 x 2 @ 4 ohms Bridged
Sub chanel
500 x 1 @ 4 ohms
800 x 1 @ 2 ohms
Recommended Fuse Size: 100 amp
Power/Ground Wire Size: 4 gauge
Dimensions (Includes Terminals): 380mm L x 176mm W x 51mm H
Editado por Fabaum_ITB
