marcelomoti
Woofer sem estrutura traseira - Phonocar Magico
Os woofers da linha Magico do fabricante italiano Phonocar tem um design bem interessante. Eles não tem carcaça ou estrutura traseira. Algo bem inusitado ao se ver.
Olhando mais atentamente, notamos que a tela faz parte do polo central do imã e não poderá ser separado do falante.
http://www.phonocar.com/en/speakers/hi-tech/woofer//02755.html
http://www.phonocar.com/news.php?news=302
Hi-Tech Mid-Bass Magico Ø165 Full Range 200W
Article number: 02755
Product class: Woofer
Description:
No Basket
ico_nobasket.jpgThese Speakers, unique of their kind, have no basket, so that Frequencies cannot reflect and Sound-Quality remains unaltered..
High Termal performances.
Their special cooling-system is another very important feature. Passing through
the membrane-protection, the coil-produced heat is conveyed to the outside (cold part), resulting in a 10
times greater heat-dispersion than with traditional speakers.
“Sandwich”- coil, with internal and external windings
bobina_sand.jpgThanks to the “sandwich”- coil, with internal
and external windings, the whole system benefits from a higher Efficiency.
Power Full Range 100 RMS - 200 MAX
Power with Crossover 60 Hz HPF 150 RMS - 300 MAX
Sensibility 95 dB
Impedance 4 Ohm
Voice coil “SANDWICH” 38 mm
Frequency Response 90 ÷ 8000 Hz
Packed 2 pcs.
Cone-Lacquering on both surfaces, in order to reduce the resonance.
