Wesleyhns
Vendo JL AUDIO 900.5
Amplificador 5 canais JL Audio HD900/5
Valor.2500,00
Nota:9/10 por ser usado,mas daria 10 pois não tem nenhum risco.
Produto Usado,sem nenhuma avaria,nunca reparado,acompanha caixa.
Segue link do mercado livre: Amplificador 900/5 Hd Jl Audiohttps://produto.mercadolivre.com.br/MLB-958323161-amplificador-9005-hd-jl-audio-_JM
Tenho outros itens que retirei do carro,pois vendi o carro não montarei som por agora,qualquer duvida só chamar no whatssap-61.99581-1010
Thanks to its ability to act as a "one-box solution", the HD900/5 is ideal for installations where space is at a premium and sound quality is the paramount goal.
While extremely compact, this amazing amplifier will comfortably drive a complete high-performance car audio system: that is, four satellite speaker systems and a subwoofer system... with a very serious 900 watts of power!
Using our Single Cycle Control switching design and R.I.P.S. technology, the HD900/5 delivers 100 W x 4 to its four main channels, plus a very meaty 500 W to its subwoofer channel. Thanks to R.I.P.S., high power can be delivered over a wide range of load impedances, while the tight power supply regulation keeps distortion down, maximizing sound quality. From a pure sound quality perspective, we invite you to compare the real-world, in-car performance of this amplifier to any other amplifier on the market, of any type, at any price.
This amplifier features a brushed aluminum finish with black powder-coated cast alloy heat sinks and bottom panel. A black powder-coated, gasketed cover is also provided to protect the controls.
Main Channels @ 4 O 100 W RMS x 4
Main Channels @ 3 O 75 W RMS x 4
Main Channels @ 2 O 75 W RMS x 4
Main Channels @ 1.5 O 75 W RMS x 4
Main Channels - Bridged @ 8 O 200 W RMS x 2
Main Channels - Bridged @ 4 O 150 W RMS x 2
Subwoofer Channel @ 4 O 500 W RMS x 1
Subwoofer Channel @ 3 O 500 W RMS x 1
Subwoofer Channel @ 2 O 500 W RMS x 1
Subwoofer Channel @ 1.5 O 500 W RMS x 1
Frequency Response (Main Channels) 12 Hz - 28 kHz (+0, -1dB)
Frequency Response (Subwoofer Channel) 12 Hz - 10 kHz (+0, -1dB)
S/N Ratio, referred to highest rated power (Main Channels) >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio, referred to 1 W (Main Channels) >88.2 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Damping Factor @ 4 O >400 / 50 Hz
Damping Factor @ 2 O >200 / 50 Hz
THD+N @ Rated Power (Main Channels) <0.03% @ 4 O
THD+N @ Rated Power (Subwoofer Channel) <0.05% @ 4 O
Input Voltage Range @ RCA Inputs Switchable from 200 mV - 2 V RMS (Low) to 800 mV - 8 V RMS (High)
Min.Copper Power / Ground Wire Gauge Accepts up to 4 AWG wire
Fuse Rating 60 A (AFS, AGU or MaxiFuse)
Filter Mode(s): Channels 1 & 2 (front) High-Pass only
Filter Slope(s): Channels 1 & 2 (front) 12/24 dB/octave
Filter Frequency Range: Channels 1 & 2 (front) 50 Hz - 500 Hz
Filter Mode(s): Channels 3 & 4 (rear) High-Pass only
Filter Slope(s): Channels 3 & 4 (rear) 12/24 dB/octave
Filter Frequency Range: Channels 3 & 4 50 Hz - 500 Hz
Filter Mode(s): Subwoofer Channel Low-Pass only
Filter Slope(s): Subwoofer Channel 12/24 dB/octave
Filter Frequency Range: Subwoofer Channel 50 Hz - 500 Hz
Detented, Calibrated Filter Freq. Potentiometers Yes
Filter Defeat Function Yes
Infrasonic Filter: Subwoofer Channel 30 Hz, Defeatable
Remote Level Control Optional (HD-RLC)
Remote Level Modes Sub Ch. only
Channel Input Mode Switch Yes (2/4/6 ch.)
Pass-Through Preamp Output None
Source Channel Selection for PreOuts N/A
Height (H) 1.93 in / 49 mm
Width (W) 10.74 in / 273 mm
Depth (D) 8.29 in / 211 mm
Net Weight 6.85 lb / 3.11 kgw02IXHI.jpgr6GI3Bh.jpgnkJTyfk.jpgQS9SxO6.jpgZIpwZms.jpgb4W1pM1.jpg
Editado por Wesleyhns
Alerta de anúncio sem foto
ATENÇÃO
Peço que dê uma olhada nas regras deste sub-fórum de classificados:
A venda de produtos deve obrigatoriamente conter FOTOS para evitar problemas de pós venda devido a imperfeições no produto
Favor editar sua primeira mensagem
Veja o por quê nas regras:
Obrigado pela compreensão.
Até mais!
Marcelo S. Motitsuki
Administração autoforum.com.br
marcelo@autosom.net
ATENÇÃO
http://autoforum.com.br/index.php?showtopic=14972
Até mais!
marcelo@autosom.net
Por algum motivo toda vez que tento colocar a foto da erro,por isso deixei o whatssap para enviar as fotos aos interessados.
Visitante
